Also an electrical problem
Two Problems:confused: :confused: :confused:
1 ] The lights where my a/c, heater, as well as the lights on the gearbox don't work. the lights on my gauges work fine its just those other lights. they just kind of all went out at once. im wondering, is there a fuse for these lights? what could be the problem and how would i go about fixing it? thanx 2 ] also, my right tail light wont work. i thought it was the bulb but it wasn't. i replaced it with a new bulb and the brake light works fine [ since they use the same bulb ]. so my left tail light works, all my brake lights work, its just that one right tail light? whats the problem here and how would i go about to fix this one? thanx thanx for your help ! |
check your fuse boxes. ones in the engine bay and ones under the dash on drivers side. theres a fuse diagram in your owners manuel. check the fuses and then if not them then check the relays. there the bigger black square things in the fuse box.
as for yout right tail light...
Check the wiring. theres a possiblitiy that a line is not connected right, or there may be a short in the line. very easy to tell if your getting voltage with a meter. if you dont have a meter go to a local shop and have them hook one up to see if your getting power to that light. |
