-   Lancer Troubleshooting (https://www.evolutionm.net/forums/lancer-troubleshooting-60/)
-   -   Won't start (https://www.evolutionm.net/forums/lancer-troubleshooting/287192-wont-start.html)
Mirage2.0 Aug 3, 2007 07:00 AM
Won't start
Here is my story.
I'm driving home from work, and my rpm gauges starts to act crazy. Jumps back and forth. It dies; just rpm gauge. Right after that my car starts to jerk. When I let go the gas it's fine; I press gas to drive my rpm gauge jumps like crazy and car jerks. Finally I got home.
The next morning car won't start. It cranks fine. New battery and alternator. Voltage on afc shows fine. When it cranks, it won't start and black smoke shoots from the tailpipe. That tell me that I have no spark, but no spark don't explain nothing about the stupid rpm gauge.
I have been told that my cas is bad. I have changed that, no result.
My mechanic said that it something wrong with my ignition system?!?!
Anybody had that problem. I have checked my spark plugs 2 weeks ago and they were perfect.
Please help.
Mirage2.0 Aug 3, 2007 09:00 AM
Anybody???
senate6268 Aug 3, 2007 09:10 AM
Did you check to see that you are getting spark from the coils? Pull the plugs out and make sure they are firing when the car is cranking over.
SLVROZ_03 Aug 3, 2007 09:55 AM
Seeing that I just fixed a similiar problem with my Civic (replaced the distributor), trying replacing a coil pack. Might as well get new sparks while in there too...
Mirage2.0 Aug 3, 2007 10:17 AM
Thanks. If I'm not getting no spark from non of the plugs then tha means coil packs? What about if I'm getting spark for example in 2 of them?
sharkm87 Aug 3, 2007 10:21 AM
ha, yup, i got same issue right now with my civic(DD) gettin the distrubutor fixed as we speak so i can install wheni get back home...
Mirage2.0 Aug 3, 2007 10:46 AM
^Your rpm gauge was acting retarded too?
Where is the cheapest place you guys buy coilpacks and wires?
SLVROZ_03 Aug 3, 2007 11:01 AM
^I bet it was...cuz mine was going crazy! I bet it was the ignitor in mine; but on the lancers it'd be just the packs. Look on the boards here, junk yards, online parts sites, dealership...in that order.
Good luck!
BTW, Shark...I got a "new" Reman entire dizzy for $71 shipped. Hope the repair doesn't cost you an arm and a leg.
atilla Aug 4, 2007 02:59 PM
rockauto.com has coils for $68.79 each. i've ordered lots of things from there and they get stuff out to you pretty quick.
Mirage2.0 Aug 14, 2007 07:55 AM
Fixed.
It was cam angle sensor. CAS
