timing belt
My lancer has reached the 60k mark and I was wondering when would be a good time to replace the timing belt? If so how much is it usually? Mitsu dealer quoted me for $1200 everything plus change all the other belts, i.e. a/c belt, serpentine, etc... Sounds legit or not? They said I'll save $600.
Sounds like it's legit for what they usually charge. If I were in your shoes, which I will be in a few months, I'd find out what I can do and what I need them to do... and don't take it to the dealership. There are some good shops around that will do the same stuff for way less.
timing belt costs $55 and the waterpump costs $94 at mitsubishiparts.com. SO let's say I pay $160 for parts. Then the labor which costs around $450, then I should only pay around 600 to 700 total. Now for the other belts, I got quoted for 160 to 170 parts and labor. So that yields to 770 or 880 for everything. That's less than what is being charged by mitsu stealership. They will make around $320 in profits...
I paid like $25 for the belt at autozone, and $140 for labor at a little mechanics shop.
Dont go to the dealer to have it done. They just rip you off. |
I paid <$100 for all my belts and a water pump from www.mr-auto-parts.com . Bought a $3 set of pry bars from Freight Harbor. $3 can of brake clean from Auto Zone. Took out the starter, inserted pry bar, and broke the pulley bolt loose myself. Installed new belts, rigged the cam and crank out to move, and torqued the bolt back on. 11 hrs later, I saved myself 100s of $$$.
Don't go the dealership! Local shop will do a fine job, I just recommend buying the needed parts ahead of time for them. |
I'll pay $25 for the belt at pepboys and $six puck for my friend, lol.
i was quoted $300 at a shop but ended up doing it with the help of a friend. those quotes you got were waaaaaaaaay too much.
You just need to buy the belt itself, correct? You don't need to buy any special parts that has to be replaced along with it? Same goes with the water pump I guess.
Tensioners, if they are bad.
Originally Posted by initialDRacer
(Post 4691599)
