-   Lancer Troubleshooting (https://www.evolutionm.net/forums/lancer-troubleshooting-60/)
-   -   A'PEXi S-AFC (https://www.evolutionm.net/forums/lancer-troubleshooting/33287-apexi-s-afc.html)
stygiosracing Aug 1, 2003 02:04 PM
A'PEXi S-AFC
hey everyone, i just installed my S-AFC, and i am having a rough idle. i am idling at about 590-690 rpms. the settings are default, so im not sure what the problem is. im almost guessing the the ECU has to learn about the new hardware. any advice would be awesome.
ryancb Aug 1, 2003 02:09 PM
*shakes head* you need 2 tune it there is no defult setting or at least not on mine if u leave everything 0 u will slowly wreck your motor
stygiosracing Aug 1, 2003 06:34 PM
yes, the only reason i hadnt had it tuned right then is because i hadnt had the time. it is now tuned, and still idles roughly.
ryancb Aug 1, 2003 06:58 PM
then your not tuned a safc tuned right will not run rough unless you damaged something like your mas or wired it wrong mine runs smooth as can be
pjal84 Aug 1, 2003 07:48 PM
That idle strikes me as a shade to low...try going to about 700~ RPM. Make sure you're not leaning out to much at idle as well. Run searches by other members (uranium9v and rhyzin off the top of my head) for some of their numbers.
hel_if_ino Aug 1, 2003 07:56 PM
umm.. this maybe be a dumb question, but did you set it to karmen vortex? i think that is the type of aif flow meter our car uses right?
HobieKopek Aug 1, 2003 09:47 PM
[Ed MacMahon]That is correct, sir![/Ed MacMahon]
bahamut Aug 1, 2003 09:51 PM
Alway Karmen.
If you are stumbling at idle, drop the low setting a bit. Too rich. If you have a digi O2 meter, it should be boucing beyond 1.000 . . . at .996, the motor will stumble.
airlinevomitbag Aug 2, 2003 06:03 AM
From the list of mods, catback and SRI, you have nothing to tune for and you ought to leave it alone. If you need an excuse to use your AFC (like me) start fooling with the MAS, the set screw and the restrictor plate (Rhyzin has had some success with the plate) just dont ruin it, it comes apart just be nice but be prepared for some really crazy settings. Before all that I had no numbers bigger that +-6% After the adjustment of the screw my idle (1000 low) is like +19% now and it goes down from there, there is'nt a whole lot of leaning to do on High Throttle cuz you are already pulling more air than stock.
stygiosracing Aug 2, 2003 03:09 PM
well guys, i found out what the problem was. BAD WIRING! the guy who did the install didnt secure it well. i went back through, reconnected everything, and it works fine now. {pcfreak}
rhyzin Aug 2, 2003 03:45 PM
Woohoo!
stygiosracing Aug 2, 2003 09:04 PM
hey rhyzin, im likin the mount on the apexi. you should see where i mounted it, perfect place. i wish i had a pic, but its right inside the compartment below the head unit. fits perfectly.
ryancb Aug 2, 2003 09:36 PM
1 Attachment(s)
u mean like me.....
rhyzin Aug 2, 2003 10:23 PM
thats a great place for show, but i was thinkin(tho i haven't done it yet) was to loosen the right screw that holds the gauge window in place and use the hinged mount that came with the safc and mount it to that so it its a little above and to the right of the steering wheel.
this piece is a great addition anywhere you put it...
ryancb Aug 2, 2003 10:25 PM
i auctually tried that but it didnt hold 2 wheel when ever i would launch hard itd tend 2 slip out even with tape or tighitng it
