Power go's Down?
Ok this has been going on for like a year or two already but im lost with it
and BTW the car appears to have a batter to small for it since it sits like 2 inchs less than the battery space But when the cars on and for example i press the brakes the power drops from 14volts to 12 and makes my stereo skip sometimes , or when anything with power turns on it drops to 12 but then go's back up http://i269.photobucket.com/albums/j...h_MOV01850.jpg |
But my battery is very weak and its died about 15+ times on me , so i think a optima would fix that right?
you could try taking it to a place to get your battery recharged, if it can hold a charge if not than if you have warranty they should replace your battery. I have a 300 watt memphis amp running (2) 12's (comp kickers) and running a radar with two outlets to charge my IPOD...your car should be fine cause you don't have cams or pulleys
Yeah a more cost efficient way to help would definitely be just get it recharged, no need to go out and buy a high performance battery... unless you really want one :)
(I do too) lol. |
How old is the battery?
Its been on the car since i bought it in august 06
but they annoying thing is that the Stereo cuts off when the volts drop down alot |
Check your alternator too.
Originally Posted by sa town ridah
(Post 5780789)
Check for shortage, bad grounds or alternator issues. Does the battery light come ON when power drops? |
| All times are GMT -7. The time now is 04:39 AM. |
