Rear sway bar
I just got a hold of some parts off a wrecked GTS, installed all 4 discs with calipers no problem, but after installing the rear sway bar the car is 1 inch higher on the rear right, does anyone have an idea why, is there any special adjustments????
One inch higher from where? Are you talking about the wheel/fender gap or the distance from the frame to the ground?
thanks, from the wheel to fender, I also checked tire pressure and made sure the surface was even! I didnt measure it before the stabilizer install, but I never noticed it before!
Originally Posted by ziftawi
(Post 6637339)
hey thanks, I did have the up on jacks and uneven when I installed and tightened the bar. I'll do that first thing in the morning and post the outcome.Thanks.
