Engine turns but car won't start :[
I have a 2002 Automatic Transmisson Lancer OZ that slowly powered off on me while driving. Now both my ignition coils work when I tested them but one doesn't get any power. I think its #4 ? Its the one closest to the air filter.
I narrowed it down to these three: -relay -fuses -the wire connecting to the ignition coil itself How could I check these and am I on the right track? Please help. |
Are you getting fuel?
Do you hear the fuel pump prime? Pull a fuel line off the fuel rail and put the line in a plastic bottle or something so you dont make a mess, then turn the key, no need to crank and see if there is fuel in the bottle. theres probably a better way but thats how i check. |
if you have the same fuse box i do... right by you left knee when seated in the seat. there are two fuses that control something on the motor. mine went awhile back. i was stuck for 3 days cause the coil had such a fine break. it was on the right hand side of the box. second down if i remember correctly... the panel will show where it is for reference
@Ekoy...Yeah the fuel line primes and I get gas. That was one of my thoughts.
@Joseph...i'll check the fuses and get back to you. Thanks friends |
I checked the fuses and they were fine. Ignition coil #4 (hope that's right) still isn't getting any power which in turn isnt passing power to #2. Any other ideas anyone? Please?
Try swapping the coils? If u get power then bad coil?
Yeah I swapped coils and they both work. Im hoping its not the wiring.
wiring is so easy... chances are if that is your problem it will be a break in the wire rather then a burnt wire. so check the harness. if you find a break clip it and crimp it. then find someone who can solder and have them solder it together for you. IF! that is the issue
| All times are GMT -7. The time now is 02:42 PM. |
