the outside temp is not showing (08 GLS)
1 Attachment(s)
Hello i am having a problem with the outside temp sensor as its now showing in the dash here is a picture https://www.evolutionm.net/forums/at...1&d=1394018595 |
sensor or wiring to the ambient temp sensor it failed. Find the failure.
Originally Posted by CamShaft
(Post 11170817)
1 Attachment(s)
Originally Posted by The tracker
(Post 11171599)
Thank you for replying but where can i find the ambient temp sensor?
(Post 11177997)
here
thanks |
(Post 11178168)
I kept looking but it was nowhere to be found, probably the previous owner uninstalled it for some reason, is there anyway to install new one? and if i will install new one, where should i connect it to.
thanks |
'if' the PO removed it - there should 'still be' a connector behind the bumper cover...
If not - the wiring harness may still be there (but be cut). Go to Ebay/get one used with pigtail and splice the wires.... |
(Post 11179528)
Did you remove the headlight support assembly and the front bumper then look?
Originally Posted by Veronica
(Post 11179654)
1 Attachment(s)
I think i found it, it was taped to other wire, excuse the dirt ><
so what should i do now? |
Do you have a friend that would let you swap the sensor? (to see if that fixes it?)
If not - I would buy a new sensor (after inspecting the wires/connector). |
(Post 11186911)
1 Attachment(s)
I took a picture while dis attaching it, can you please make sure it is actually the ambient temp sensor
I don't know if that is it 100%. But, if that is in the area like the diagram shows, then I bet it is.
Do you have access to a multimeter? If so, the test the sensor and see what resistance it shows vs the ambient temp, use the diagram I provided in the 4th post (don't hold it in your hand while testing, this will throw the temps off) If the sensor is out of range (and the connector pins are clean and have good pin tension!!!) then I would get a sensor from mitsubishi, this is probably your only option. If you sensor is not out of the range, then you have to test the wiring from the sensor back to the dash, this will require electrical schematics and a bit of knowledge on the system. |
i couldn't test the resistance cause it only had one wire connected to it.
1 Attachment(s)
well according to the schematic, you should have two pins.
