Input and output speed sensor location
Hi all,
Does anyone know where the input and output speed sensors are located on a transmission of a 2009 lancer DE? How do you reach them, do you have to remove a lot of part? Thx in advance |
Never mind, found them and replaced them.
Car accelerates a whole lot better. input speed sensor was on the frits and decided to replace the both input and output |
And?
Well...where were they? :D it would really help me out of a Jam, lol.
I found them as follow:
I removed the battery and the Air Cleaner Body . If not mistaken the input speed sensor is located on the transmission in the direction of left of the wheel, you will see a connector sticking out and the output speed sensor is almost in the neighborhood of where the Air cleaner body is on the transmission ( you have to feel around for the connector) I may have said the order of sensor wrong, but if you have the replacement you can compare their shape so you know which is which. |
Nifty. You have to replace yours due to hesitation during acceleration? It's the problem I'm having, and the mechanic is stumped.
Yes, my car would sometimes not accelerate, I had to some press the gas pedal few seconds apart for it to accelerate.
I got a quick scan that said my input speed sensor was not working, because my check engine was on, but I don't recall if I had another issue The mechanic told me that the input sensor had issue, but the out put is working fine. I decided to replace both them, so I could be done with it. Now she's accelerating perfectly without issues. Does your mechanic have a scan tool that can read transmission issue? |
Originally Posted by Dstorm7
(Post 11809134)
