Strange Squeal sound?
Having a strange squeal like noise coming from my 2013 lancer GT. Need help identifying this issue thanks! (The noise does seem to be coming from upfront in the engine) |
Hey, thanks for joining us on the boards:beer:
Possibly serpentine belt related? (bad tensioner?) How many miles on this 2013? Have the belts ever been changed? Possible AC belt loose? |
Thanks for the welcome!
I got about 92000 miles logged so far. I used to notice the noise more when the A/C was on when it first started happening so I was thinking bad bearing but now it does it no matter what ac on or not. |
belts have not been changed either |
Anyone got any other suggestions or had this issue before? Thanks! |
Does it do it while stationary? You could ask someone to rev the car while you look under the hood. It does sound tensioner related to me. |
Step one - change the belt - it is due.
Spin each idler pulley and listen. If you still have noise - carefully Carefully! while the engine is running, listen to each component with a long socket extension. (Did i say be careful? :) ) to identify the failing bearings. |
