Eleventy5 |
May 25, 2018 09:29 AM |
2003 OZ Rally burning up coil packs
Started it up the other day, to move it out of the driveway and she was running really rough. I popped the hood to check for vermin, or maybe an untied shoe lace that I might be able to fix, and the number 1 coil pack popped like a firecracker and white smoke started oozing out. So I killed the engine, let the coil pack cool down and pulled it off. The plug well had about half an inch of oil in it... Assuming I had found my problem I bought a valve cover gasket kit with plug seals, 2 new coil packs and 4 new NGK plugs. everything plugged back in and started her up. within a minute the new coil pack popped and smoked as well. I am at a loss. I can't see anywhere where the wiring harness has any damage (rodents are a thing out here) and it was running fine last week. Any ideas on what could be causing the coil packs to pop and burn?
