Good brand for fuel pump? And should fuel filter be changed? (100k 16years)
My 2003 Lancer has 100k miles, I have to crank it twice or 3 times to start (or it will start right away if I pump gas once before crank), Im thinking fuel pump is going bad or fuel filter is clogged.
I think these are cheap parts, what are good brands for these and are either known to need to be replaced (known issues?) ? |
I’m no expert, but what makes you think it’s the fuel pump and not something else? Total waste of money and time to change something that won’t really solve your problem. Try cleaning your throttle body first....then go from there.. |
Originally Posted by carlsson
(Post 11849123)
I’m no expert, but what makes you think it’s the fuel pump and not something else? Total waste of money and time to change something that won’t really solve your problem. Try cleaning your throttle body first....then go from there.. Again, I am no expert either and thats why Im here to get advice, but seeing how the issue appears to be with priming the engine, Its kind of down to it either being injectors or the pump, and pump replacement is a fraction of injectors. And if it were injectors I would think the car would have issues running... while if fuel filter is gummed up or pump is going bad then it will just work harder to compensate and may still run fine ? Dont know :/ once started the car runs like its brand new |
The fuel filter is indeed part of the pump,and yes there is no such thing as a lifetime filter. A fuel pump issue would definitely be more noticable in the higher rev range...but i guess there are other symptoms too. Nothing beats on OE part,although a bit more expensive. I saw a Denso branded one on Rockauto for $70, that would be the best replacement...they might even be the oe supplier. Fuel injectors are really expensive...i saw some shops offering fuel injector cleaning service...haven’t tried them and don’t know what they do and what they cost. Do you have this issue both on cold and hot starts? |
(Post 11849189)
The fuel filter is indeed part of the pump,and yes there is no such thing as a lifetime filter. A fuel pump issue would definitely be more noticable in the higher rev range...but i guess there are other symptoms too. Nothing beats on OE part,although a bit more expensive. I saw a Denso branded one on Rockauto for $70, that would be the best replacement...they might even be the oe supplier. Fuel injectors are really expensive...i saw some shops offering fuel injector cleaning service...haven’t tried them and don’t know what they do and what they cost. Do you have this issue both on cold and hot starts? Once car is running it seems to run great. I go up to 80MPH on the freeway pretty regularly and power/RPMs seem fine. My MPG seems normal for 2003 car, I get around 23 to 24MPG of about 75% city driving and 25% freeway. Which I think is exactly where it should be. Can tension on timing belt cause this problem? Like if its not tight enough? Or being off by 1 tooth? The reason I ask is because I was watching this video and that ended up being his problem, but thats a different car and in his case it wouldnt start at all - |
Same consumption on my lancer...If timing is off by one tooth,wouldn’t that affect the car the whole time? I think the car in the video never started after it stalled. You car runs fine after the initial 2 to 3 starts. I’m guessing it’s fuel pressure related. I know the fuel pump primes when you switch the key on to provide fuel pressure to the fuel rails...my ford does this and you can even hear it fo a few seconds. But I nevee hear thesame thing on my Lancer. Did you clean your IACV and maf sensors too? Like I said..no expert here but I do like to fix stuff myself. I wonder where the experts are? Haha. |
(Post 11849419)
Same consumption on my lancer...If timing is off by one tooth,wouldn’t that affect the car the whole time? I think the car in the video never started after it stalled. You car runs fine after the initial 2 to 3 starts. I’m guessing it’s fuel pressure related. I know the fuel pump primes when you switch the key on to provide fuel pressure to the fuel rails...my ford does this and you can even hear it fo a few seconds. But I nevee hear thesame thing on my Lancer. Did you clean your IACV and maf sensors too? Like I said..no expert here but I do like to fix stuff myself. I wonder where the experts are? Haha. Its something really subtle that isnt visible during normal running yet appears during startup. I dont think many things can do both of those. ive taken apart MAF before to try solve this and cleaned it, but it didnt make a difference (there is a chance its bad, but I think that would throw a code right? I got no codes). for IACV, is that the one under the throttle body intake? If so then no I have not taken that out or cleaned it... its probably not been removed since car assembly. I have seafomed (both spray and liquid) into my throttle body/oil/gas to try see if that will clean injectors or something else gummed up. Didnt fix the issue, and in general I think my engine and all that is pretty clean for a 16 year old car, passes all emissions and exhaust is proper looking (nothing weird about it). I really think I should try the fuel pump. Ive seen a few videos on how to replace it, seems easy. But I am still unclear which part of the pump assembly (the white plastic piece) is the filter (pump itself is obvious). Is the filter inside the pump cylinder? Or is it elsewhere in that plastic holder? And not sure where to order from. Ive looked on Amazon, but theres got to be a better place. At the same time I dont plan to keep this car for more than another 20k miles. so I dont want to spend an arm and a leg on an OEM pump, if my issue is indeed the pump then the OEM one started failing at around 60k for me. I think a non OEM will do same or better. This guy here gets good reviews and is Denso which is great, but wonder if I can get it cheaper elsewhere? -
https://www.amazon.com/Denso-950-0123-Fuel-Pump/dp/B000C5UINW/ref=sr_1_2?ie=UTF8&qid=1542713902&sr=8-2&keywords=2003+lancer+fuel+pump&refinements=p_72%3A2661618011
Edit: Lol I said f$%k it and ordered that DENSO one. Will report back on how that goes. Im willing to bet that it will fix the problem. From reading online fuel pumps last around 175-200k miles, but basically after 100k it can fail any time. So since Im just hitting 100k it seems like a good time to change it regardless for extra reliability. And some describe my symptoms as pump symptoms. Also for majority of the first 6 or 7 years when this car was brand new I drove on 1/2 or less tank of gas because it sat around a lot, weeks at a time, so I didnt want real old gas to sit in the tank for a long time. I had no idea that can actually damage the pump... so that could have accelerated its death. |
Yes the IACV is under the throttle body...but since you have no idling issues i don’t think that's your problem. I usually order from rockauto.com. Sometimes they are cheaper but it really depends because you have to factor in the shipping costs..i guess we just have to wait and see if the fuel pump cures your issues. I have 121k miles on mine and so far so good,no issues as of today...keeping my finger crossed. Keep us posted. |
(Post 11849561)
Yes the IACV is under the throttle body...but since you have no idling issues i don’t think that's your problem. I usually order from rockauto.com. Sometimes they are cheaper but it really depends because you have to factor in the shipping costs..i guess we just have to wait and see if the fuel pump cures your issues. I have 121k miles on mine and so far so good,no issues as of today...keeping my finger crossed. Keep us posted. rockauto site seems great, it has like 6 different options for that pump including this DENSO one, which would end up costing the same as Amazon even with shipping. Ill keep them in mind for future purchases. Im wondering if I should get a new gasket, becase it looks like the kit doesnt come with a new one... but maybe its ok to reuse old one? |
I think a new gasket is a good idea...the old one must be really flat by now. But shouldn’t the new pump come with a gasket? That is what’s good about Rockauto,they give you choices with regards to price and brands. What I do is compare the part numbers they have against the part number on a mitsubishi parts site so fit won’t be an issue. |
Ok, replaced plugs/wires, issue remained. Replaced pump... boom first crank start every time. Granted its been only about 5 starts in the last few days, but so far so good... will update this further if issue comes back. Also for anyone seeking info... the filter is impossible to replace without replacing the whole pump assembly, it is welded (melted plastic together) pieces that hold the filter. What I ened up doing is replacing the pump and the sock, both of those just pop out of the assembly.
So glad the issue seems to be resolved.. been bugging me for almost 6 years!!! I do have another issue now that is possibly related to plugs replacement (vibration when car is cold that goes away after warmup... but it could be because the comptuer is re-learning idle, so maybe non issue, RPM is solid during vibration.... ill make a separate post about that tho). |
Glad your problem is solved...makes you wonder why it took you six years to tackle the issue right? Knowing now that your hunch about the fuel pump is right. Happens to the best of us. Haha. Vibration when cold maybe due to worn engine mounts...if rpm is solid then your engine works fine. |
Glad the new pump resolved your issue. I'm in the same boat with my '03 Lancer (160k miles), almost everything as far as maintenance parts (sensors, starter, battery, vacuum lines etc) has been replaced over the years. I've even removed and thoroughly cleaned the intake manifold & components and I still have the intermittent starting issue. I guess that just leaves the fuel portion. Thanks for the info on the fuel pump filter being a pain to remove, I'll be getting new pump as well.
Keep us posted if the issue comes back |
Originally Posted by Ponce07
(Post 11850560)
Keep us posted if the issue comes back The ignition did definitely improve after the pump change. But it didnt get restored to how the car was when it was new. Some starts are instant like that, but some take a few seconds. The injectors could be old, and all my hoses/lines are still original. Only rubber stuff that has been replaced are the belts. I am considering taking apart the IACV and cleaning it. Since it has never been cleaned before to see if that makes every start instant. Maybe its impossible. The car is 16 years old after-all even despite 100k milage. Shes an old lady now. Average age of cars on the road is 11 years (in the US). overall I am glad I replaced the pump, it did improve things, but didnt make them perfect. And if anything the car is much more reliable now. I know the pump wont be going out on me and should last for the remainder of this car's life. |
So true Crushev...our lancers are getting older day by day..little issues here and there are normal. As long as its reliable then its fine with me. |
