Innotech Corvette C6 Coupe
Kind of looks like a Ferrari wanna be.
General specifications
Country of origin Czech Republic
Numbers built N/A
Introduced 2009
Engine
Configuration LS3 90º V 8
Location Front, longitudinally mounted
Construction cast-aluminum block and head
Displacement 6.162 liter / 376 cu in
Bore / Stroke 103.9 mm (4.1 in) / 92.0 mm (3.6 in)
Compression 10.7:1
Valvetrain 2 valves / cylinder, OHV
Fuel feed Sequential Fuel injection
Aspiration Naturally Aspirated
Drivetrain
Chassis/body composite body panels on hydroformed steel frame
Suspension (fr/r) double wishbones, transverse composite leaf spring, monotube shock absorbers
Steering rack-and-pinion, power assisted
Brakes discs, all-round, ABS
Gearbox 6 speed Manual
Drive Rear wheel drive
Dimensions
Weight 1400 kilo / 3086.5 lbs
Wheelbase / Track (fr/r) 2685 mm (105.7 in) / N/A / N/A
Performance figures
Power 560 bhp / 418 KW
BHP/Liter 91 bhp / liter
Power to weight 0.4 bhp / kg
Innotech's Corvette lineup, starting in January 2009 with modified C6 Corvette coupe and convertible (based on 2005-2009 models), is for sports car enthusiasts seeking exotic body styling combined with great performance. Innotech Corvettes offer the best mix of unique styling, exiting performance and value for money.
Compared to a stock C6 Corvette Coupe or Convertible, Innotech's approach results in a more distinctive looking, sporting, and elegant body design, evoking an Italian lineage. Innotech Corvette features a new front and rear fascia which set it appart from competition. Combined with new Innotech rear window side louvres, the styling of the car stands out of the crowd.
There is a choice of stock or louvered hood, with other distinctive body parts coming in 2009. A wide body kit will also be available for C6 Coupe and Convertible. All new Innotech body parts are made in fiberglass or carbon fibre.
Corvette interior upgrades include fine Italian or English leather and optional carbon fibre seats with leather upholstery.
Innotech Corvette styling packages can be combined with various performance upgrades (from mild to wild).
Engines and transmissions: Corvette engines : LS2 (6.0L) or LS3 (6.2L), performance modified to 500 hp - 560 hp if naturally aspirated, or 600 hp - 1000 hp supercharged or twin-turbocharged. The engines are mated with Corvette 6-speed manual or automatic transmissions.
Performance: Innotech Corvette C6 Coupe (e.g. naturally aspirated 560 hp LS3 engine) with approx. 1400 kg curb weight has one of the best power/weight ratios available. Supercharged and turbocharged versions give extreme, but streetable supercar performance.
Several distinctive Innotech Corvette Packages and Limited Editions, both performance and luxury oriented, will be offered to discriminating buyers in 2009.
During 2009 we will create an exiting Innotech C6 Speedster, as well as customized Innotech C6 Z06 and ZR1 versions (the above mentioned Innotech rear fascia and rear window side louvres already fit Z06 and ZR1 models). - With five distinctive bodies for the sixth generation Corvette, combined with many performance upgrades, Innotech will offer more attractive Corvette choices than anyone.
Although Innotech company is based in the Czech Republic, Innotech cars will be assembled in the USA. Modified Corvette parts as well as complete cars will be delivered worldwide, while USA is supposed to become a key market for Innotech Corvettes.
Numbers built N/A
Introduced 2009
Engine
Compression 10.7:1
Drivetrain
Dimensions
Performance figures
