track car suggestions / discussion
Old Apr 26, 2016 | 01:00 PM
  #586
kaj's Avatar
kaj
I have a friend that ran an NA at 270 hp, with Turbo. No heat issues though.
Edit: I just remember he had a water/meth set up that he would spray once in a while if he thought it was getting hot. it was hooked up to a button on the steering wheel.
Old Apr 26, 2016 | 01:11 PM
  #587
ambystom01's Avatar
V8 swap.
No I'm not serious.
Old Apr 26, 2016 | 01:25 PM
  #588
WarmMilk's Avatar
Originally Posted by razorlab
How much did you pick it up for?
I'm curious as my Fiesta lease is up soon, and with my Evo 10 being down, I might be looking at another lease like a BRZ or some such to change it up, or a used car, maybe something like the last gen miata.
6800, sorry slipped my mind in the other post. but the condition of the car kinda reflects the price. it has rattles, it was in a small fender bender and fixed a bit on the cheap side. there's a much cleaner one for sale locally but the guy won't budge from 10k. the few others in the area are 12k+ and I didn't even look at those.
yeah, the NA and NB's are a bit better, I think in part cause they're not packaged as tight under the hood.
There's a local guy with a Kraftwerks NC that tracks his car (he's actually switching to a built 2.5 right now), and he basically needed to do every cooling mod in the book to get it to run consistently at acceptable temps. Just Koyo radiator (75/25 water/coolant mix) and oil cooler he was still seeing 260* water temps after a few laps.
Old Apr 26, 2016 | 01:27 PM
  #589
WarmMilk's Avatar
Originally Posted by ambystom01
V8 swap.
No I'm not serious.
haha, those are pretty sweet actually for the NC... but expensive.. to be honest I'd rather go built engine and turbo, then I could have the power for the street and turn down the boost to something reasonable for the track, and prolly still come out cheaper than a V8 swap
Old Apr 26, 2016 | 01:34 PM
  #590
ambystom01's Avatar
NAs and by extension NBs were designed to accommodate a larger motor from the factory, so there's lots of space in the engine bay.
I think a V8 swap would be the ultimate street bruiser, but I agree it's probably a bit much power and price wise for the track.
Old Apr 26, 2016 | 03:27 PM
  #591
kaj's Avatar
kaj
Not sure about the newer ones, but the Acura v6 fits nicely in the NA & NB. There's even an adapter for the trans. Or is that the swap you mentioned?
Old Apr 26, 2016 | 03:31 PM
  #592
ambystom01's Avatar
I was thinking V8, like LSX swap. Flyin' Miata can do it.
Old Apr 26, 2016 | 03:35 PM
  #593
WarmMilk's Avatar
I haven't heard of the V6 swap for the NC (or the prev gen for that matter), the swap I was referring to is the 2.5L 4 cyl out of any 09+ Mazda or Ford. The long block is a direct swap, just take out the balance shaft, bolt up the oil pan and crank pulley out of my car, and everything bolts up with oem parts. Although I'll get aftermarket engine poly engine mounts to control engine movement a bit better
Old Apr 26, 2016 | 03:57 PM
  #594
nemsin's Avatar
What about a K-series motor swap? http://www.roadandtrack.com/car-cult...swapped-miata/
Old Apr 26, 2016 | 03:58 PM
  #595
ambystom01's Avatar
Big money too.
Old Apr 26, 2016 | 04:16 PM
  #596
WarmMilk's Avatar
Originally Posted by nemsin
yeah, I looked into that to consider an NB miata, its something ridiculous like 7kish plus an engine
Old Apr 26, 2016 | 04:36 PM
  #597
kaj's Avatar
kaj
Gotcha. Yeah, we were going to go the V6 route because the engine is light, 300hp, AND has VTEC. :P
If I could find a cheap Miata, it would definitely be my engine of choice.
http://forum.miata.net/vb/showthread.php?t=551809
Old Apr 26, 2016 | 04:42 PM
  #598
WarmMilk's Avatar
sh*t man... where were you 2 days ago? this puts an NB in a whole new light...
Old Apr 27, 2016 | 11:48 AM
  #599
CaliMR's Avatar
Get a Legends car. /thread
You're paying for a warranty that is void if you have an issue on track or that is linked to your racing.
Unless it's a Chevy.
Old Apr 27, 2016 | 12:29 PM
  #600
3gturbo's Avatar
I couldn't own a Miata. But that's just me.
I agree completely
