05 Sti cheaper 500-550hp daily driver than Evo 8/9?
Stock frame turbo's won't make 500whp on pump gas. A T3 kit is needed. You don't need a big 6466 though. A gen2 5558 would do it.
I would go the Evo route. You basically need a turbo kit and supporting mods (for now). Depends on the mileage of the engine and how it was previously maintained. Nothing lasts forever at 500hp anyways.
Also, there are many more costs to replacing the short block than just the cost of a short block assembly. Gasket kit, going through the cylinder heads, fluids, shipping (not cheap to ship engines), etc..
I've owned an 04 STI, and for the price you posted, at $12,500, you are looking at a high mileage 05.
My STi had 3,000 dollars worth of maintenance done to it, to make it "reliable" as a daily and it was still pissing oil and burning oil and doing weird stuff all the time.
I have owned 5 evo's and currently have an EVO IX SE.
I have dozens of friends who own subarus. multiple dozens and only TWO, out of probably 50 different subarus i know, have NOT had to replace their block. TWO!!! Everyone else had to replace a block or do a rebuild. That's insane. And they were all stage 1 or stage 2, around 300-350whp.
A lot of them have built motors now and are STILL having issues and blowing stuff up. And this is with very reliable tuners.
I will never own another Subaru again, at least not a turbo'ed one.
The subies seem ok with bolt ons if you break it in right and know how to maintain them and have a good tune. I see them at autocross and the track sometimes and when they are running they are fairly competitive with the evos. The evos are always faster though. ALWAYS.
The highlight of the subaru is the 6 speed tranny is super strong. Otherwise, they are junk.
And it wont cost you 1500 to rebuild rear diff or 500 to rebuild transfer case.
Dont bother with transfer case until it's an issue. They don't always pop. If you have a good clutch and don't launch your car and drift your car everywhere, they handle power fairly ok.
I restacked the rear diff on my IX and found it to be very very loud, clunky and also seemed to not enjoy long runs with the car. It would get really hot and feel like it would bind more.
I ended up sending the diff to Shep for a 12 plate rebuild and it's much better and has no issues, ever. Also, nice and quiet and would be better for a daily driver. Not that i daily my evo, but still. I wouldnt want to daily the restacked diff i had.
It didn't cost me 1200 bucks either. It was like 500 dollars to have shep do 12 plate upgrade and HD cover plate.
If i was buying a used evo or sti, at the price you listed, they would be high mileage. I don't trust any high mileage STi or WRX. You don't know how they were broken in and even worse, will probably already have issues you will have to deal with.
I had my power steering pump go (very common) on my 04 STi and the fluid ran down into the timing belt/water pump area, so i had to replace those as well! And it was right after i did the timing belt and water pump already.
Then i had a piece of plastic break off randomly from somewhere and get stuck in the variable valve timing actuator and the car was misfiring and running on 2 cylinders.
This happened twice! How the hell does that even happen?!
The car leaked oil, it burned oil, it smoked from the turbo gasket, it smelled like gas allllll the time. Sucks when you use the car as a daily and get to work smelling like you fell into a pool of gasoline and failure.
The inside of the car always smelled like burning gas and oil.
Spark plugs are annoying to change, since they are basically under the damn motor.
I had to retorque the rear hub axles because they liked to come loose every handful of months.
I use to occasionally have boost creep and boost spike.
I had shaft play in the turbo.
The only thing i enjoyed about the car was the seating position was lower than the evo, which made it feel sporty, the rumble of the exhaust, the big rowdy hood scoop on front and the interior had a certain plush-ness that the evo didnt have. The tranny was also nice and solid and crisp. But, i have zero complaints with my 5 speed EVO tranny...sooo...who cares?
Otherwise, **** that car. Never again.
The evos, knock on wood, all 5 of mine, have been the best cars ive ever owned, reliability wise. The only time ive had issues with evos was minor or due to someone messing something up that i had to fix. Also minor.
But, some subaru owners really love their cars...because ive seen owners replace their motors like 5 times and they still havent sold their car...how? i have no idea.
Just my experiences and 2 cents as a huge car enthusiast, autocross, track racer, forum goer, drag racer, etc.
We had a poster this forum who filled the rear diff with I don't remember what gear oil and was having drivability issues he thought - it started acting making noise from binding and releasing. He just wanted to know what was wrong with his car - lol. This with the USDM version of the rear diff - not restacked. Diaqueen fixed the problem. So, the USDM version rear diff can decide to function. Restacked, depending on the lubricant used, maybe much more so.
L888Apex
50
Oct 9, 2010 11:20 AM
pheonix991
14
Apr 21, 2010 12:39 AM
tsidrift1
24
Jan 29, 2010 11:56 AM
EVO Neil
Mar 20, 2006 02:51 PM
Willie
Aug 2, 2004 09:21 AM
