Mike's 3000GT VR4 Poser...
What u guys think of this 3000GT VR4 Poser? :lol:
Mike's getting his stealth twin turboed soon :D https://www.evolutionm.net/forums/at...id=46616&stc=1 |
yeah thats my Shyte
It needs some major work if u want that thing to look nice. WHat's the condition on the engine? Well, by the time ur done, might as well get a supra.. From what I heard, the VR4 engine/tranny is not reliable.
He's not using the VR4 Engine or the Tranny... he's using the stock Dodge Stealth RT (N/A) Engine.
That's one hell good project dude! Keep us updated.
I will keep you fully updated on progress. To date I have only been buying up parts. Nothing installed YET...YET!!! Parts ordered
Performance: Stock turbo manifolds stock side mount Intercoolers upper IC pipe 1gen DSM BOV stock VR4 oil cooler Intraxx 1.7" drop springs Audio: Flip out 7" monitor DVD player, TV tuner Sony Xplod CD player Infinity 350 watt amp Eclipse 8" sub w/custom box Future: shopping stock VR4 9b turbos 18" rims (not sure yet on what style but I am sure gunmetal) MAYBE upgrade the already upgraded interior speakers oil and coolant feed and return lines for turbo kit |
DON'T USE the stock turbos, get like 15's for each side. It'll be more efficient and spool JUST as fast as you have a higher compression ratio.
Seems like a lot of work. I bet you can sell that and get like a 92 Vr4 for under $10,000. Ever think about that? Also go with a FMIC if you can, it is SOOOO much better then the side mounts ESPECIALLY the stock ones. Good luck |
. I will be fast enough there Not possible ;) , you will see what I mean in the future. When boosting a car that is not meant to be boosted, there will be reliability issues that a factory turbo car will not run into. Such as A Computer that understands and accepts boost A Rising rate FPR that adds 1PSI of fuel per 1PSI of boost, pulls back fuel in a vacuum Larger/more efficient radiator to cool the motor Extra cylinder oil squirters that bring oil up and combat the higher operation temps (WAY HIGHER, turbos opperate at 1600F at WOT, if not hotter) A cooler Thermostat to take advantage of the better cooling system Bigger fuel injectors Bigger Throttle Body A better fuel pump to flow fuel needed LSD or AWD to handle the new power A stronger clutch to hold the power A Gear ratio to take advantage of the power/torque Fatter rubber from the factory to handle the power A better suspension that comes with the car to handle the power It seems like you are getting irritated by any comment added. Just trying to add some info or ideas for ya, that is why you posted this on the site right? Looks are subjective. Have fun with your project, just adding opinion. |
Originally Posted by mitsumichael7
That sounds like EVERY other Evo owner who tells the guys who want to boost on their regular lancer, "Why not just get an Evo?".....
Hilg |
Originally Posted by JNasty4G63
Then, how about you hear it from a DSM owner. I've seen quite a few NT 420A-engined DSMers try and turbo their cars. Sure, it does make some power. But, most of the time, after all the work, you have a car that isn't even as fast as a stock turbo DSM. It'd be the same with your car, like he said. You should just sell the car, and get a TT Stealth or VR-4. Less work to do, less chance for problems down the road, less hassle. If all you want is 'stock turbo' speed out of a car, get a STOCK TURBO car.
Hilg |
takes all the fun out of modifying the car. It's sorta like me telling you quit modifying your evo and sell it for a ferrarri if u wanna go balls out fast. Not completely true. Cars are purpose built in to how they need to perform. Fun? Maybe, But I doubt it will run as well as it is not designed to run a turbo. Its hard work to get it to run right, especially fuel delivery, its the key element in tuning. Again it's mu opinion, and he has his own, I just look in the long run, I can almost guarantee it'll save him money and time on repairs or just getting it to run right. I would look for a swap, I know he loves the car, I used to be the same with my olders, bt if you have a specific goal in mind with an auto, start with the better Platform. but its only my opinion |
Originally Posted by Kareem@Accolade
Just buying the car already turboed takes all the fun out of modifying the car.
Hilg |
| All times are GMT -7. The time now is 11:24 PM. |
