Somebody Help. I'd Rather Not Die lexus gs300 problems
Ok. I've went looking everywhere for info on what my problem could be, but I think after 10 years, my Lexus is about to die. I'll describe my problem as best as I can.
When I first start driving there is no noticeable shake in my steering wheel, but as time goes on, it starts acting up. I've noticed that it usually starts as I go up or downhill and then once it starts it doesn't go away until I stop the car and let her sit for alittle while, but sometimes that doesn't do it either. Another thing I've noticed is that it kind of sounds like I'm running on a flat when the car starts shaking. The steering wheel shakes violently on the highway and when I get on the brakes to slow down it becomes even worse and you can actually... hear? the shaking. It's that bad. The brake pedal shakes/pulsates pretty violently as well when this happens. The thing that gets me most is, sometimes I don't get any shake or pedal vibration/pulsation at all, regardless of how long I've been driving. I'm so confused on this one. I get steering wheel shake and I can also feel vibration in the pedals. I don't understand. What could it be? Somebody please help BTW, I had my tie rods and LBJ replaced around 94K miles and I'm closing in on 136K miles as of now. I'm very low on money as I am a full time college student that's only working enough to get by. I appreciate any and all help. Thanks guys. |
Is your gas light on? Cause if it is you prolly need to fill up your tank.
No, Morgan... My tank is full, always.
check your tire's see if they are wearing out in a weird way that where you should start at.
Will do. I actually do need new tires. There's basically no tread left on them. Hope I don't have a blowout anytime soon.
sounds like you have multiple symtoms there buddy. pulsating brake pedal while braking are warped front rotors. might have to replace them, also replace your brake pads too. you possible might need to get your wheels/tires checked. make sure tires aren't out-of-round, that right there can actually make your car shake real loud and get your wheels balanced. check for bent rims.
another question i would like to ask is, does the car have a rumble sound when driving like whoos whoos sound kinda? just wanted to know because i see you drive a 2000 gs300. lift your front end of the vehicle up and shake/rock the wheel (12 and 6 o'clock position). if there are play then you will need a new hub and bearing assembly.(from previous experience...toyota/lexus technician here)
Originally Posted by mr.saechao
(Post 7939473)
pee in the gas tank
Originally Posted by bcollinstex
(Post 7939495)
pee in the gas tank
Sounds like it might be a busted engine mount.
My guess would be some sort of worn rubber bushing. When you go uphill, it hits the angle with the most play and shifts and then stays that way because by that point it is all hot and squishy. I had a similar problem with my car, turned out to be a combination of a couple worn bushings plus a slightly bent rim. This was at about 50k miles.
I blew a motor mount in the same car (at <1000 miles WTF) and it was more dependent on motor speed than road speed. |
I second the warped rotors and bad engine mount.
Have someone watch the engine while you sit in the car, put it in reverse and drive while braking and giving it gas. Switch back and forth a few times. If the engine seems to rock WAY more than it should, you have just diagnosed said concern. |
needs more mad tyte jdcm.
Originally Posted by shvc1991
(Post 7939364)
| All times are GMT -7. The time now is 06:41 PM. |
