MY buddy needs help with his subaru! please help!
Hey guys,
yes i can already hear the comments, "should have bought an evo..." lol but hopefully you all can give me some insight to relay to my friend about a problem he is having with his car. He drive's an 02 WRX bugeye he recently had all of these parts installed and tuned at a local shop "DK Goodrich" in Frankfort: FP68HTA turbo GT Spec up pipe GT Spec Headers Tial 38mm EWG Gimmick motor sport turbo inlet DW 750cc injectors Hallman pro Manual Boost Controller Forge Bypass valve Perrin Short Ram Intake NGK vpower plugs gaped at .028 Here is the problem. The tuner was able to tune his car and everything worked out great. however, once tuned, the car now, will die after the engine is started. When the engine is turned on, it will start up, but then will kind of "Hiccup" (almost like it is struggling for fuel) and then die out after about 5 or so seconds. Sometimes the car will stay on for a couple minutes other times, just a few seconds till it cuts out. the tuner can tune Subaru's but doesnt know where to start to fix one. I was hoping that maybe someone on here would have some insight or suggestions on how to fix the car? any ideas on what might be causing the problem? my buddy is thinking that some sort of electric connection has come loose or maybe something with the fuel system. any more ideas? thanks guys! |
sounds like this "tuner" isnt much of a tuner it probably wasnt tuned in the lower rpms/idle cause thats one of the harder parts of the tune. whats is afrs like @ idle/cruise/WOT? thats my best guess
yeh any insight to afr, what rpms does it idle at, injectors scaled? i mean when he tuned it did it even run? was it a dyno tune or street tune? how long ago? lol more info??
the car in question is my car.
I literally have ZERO information to give you all besides what my tuner has told me. I am going to be going up to look at the car tomorrow, but honestly I dont know what to even look for. Mye bet is a fuel pump issue possibly or a loose connection somewhere in the wiring harness. I wish i could give insight to what any afrs are, but honestly i have no idea, it was a street tune though. tuned this past weekend he said he didnt start getting any issues until he was mostly done with the tune |
Originally Posted by CaseD
(Post 8802053)
none that i was aware of.
did u try nasioc? they are pretty helpful over there there might be somebody local who could look at it or help u out
(Post 8802077)
What kind of BOV does it have is it VTA or back into system, my buddies 06 sti has a big idle surge and some times dies randomly. His problem is the tial BOV is VTA and it messes with the maf(or what ever the sensor is called for the subaru owners).
sounds like this should be on NASIOC (worst acronym and website name EVER btw)
Originally Posted by ODUB
(Post 8802888)
They'll be able to help you But it sounds like the tuner messed up your idle |
Originally Posted by wtf_is_a_evo
(Post 8802878)
forge Bypass valve, so its a recirc. I have posted up on NASIOC, but I am not getting any useful replies. I will be going down to the shop today to look the car over, I am just trying to gain a list of things to look over while I am there.
i seriously feel that the car has a loose wire or a cooked fuel pump? but i have no idea? |
99% chance its tune or install related.
Sounds like timing or big leak. Ask the tuner what he did with the timing.
