-   The Loft / EvoM Car Talk Corner (https://www.evolutionm.net/forums/loft-evom-car-talk-corner-357/)
-   -   Project 2G 8's and Street Driven (https://www.evolutionm.net/forums/loft-evom-car-talk-corner/574095-project-2g-8s-street-driven.html)
TALONGT Sep 11, 2011 08:07 PM
Project Auto 2G DSM 8's and Street Driven
New project this year is to convert my 5 speed 1997 Talon AWD to an Auto, and go after that 8 second mark while keeping the car streetable. The car has gone 9.6@159Mph with the 5 speed, at 3250lbs. And when it comes to auto's the natural choice is the crew at English Racing, thanks to Lucas, Jeff, Arron, and Myles. I hope I can tuck into the draft behind you guys :) I will still be running a full sequential Spark Tech ignition system, but pretty much everything else on the car is going to be changed, and I mean everything! Going to be running Comp triple as usual on the car as it has all been an outstanding performer both in power and spool but also in durability. More to come
Video of the car going 9.6@157, and on the dyno
http://www.youtube.com/watch?v=eNEqyEsN-P4
http://talongt66.4t.com/photoshoot1.JPG
http://talongt66.4t.com/photoshoot2.JPG
http://talongt66.4t.com/photoshootmotor1.JPG
http://talongt66.4t.com/photoshootmotor2.JPG
SparkTech Sep 12, 2011 02:12 PM
3 Attachment(s)
Congrats Ron. Good move the Autos have proven themselves in a relatively short time. Of course you also have a winning combo of vendors on your side also.{thumbup}
I'd suggest adding the Billet coil protectors to prevent coil breakage.
TALONGT Sep 12, 2011 02:41 PM
Exactly I was going to go RWD untill Jeff and the English crew got that auto awd so dialed in I couldn't resist myself :) This project is going to be tons of fabrication, but I think the end results are going to be something that no one else has done before:D Stay tuned everybody
TALONGT Sep 16, 2011 07:38 AM
Sorry that was an old video here is the video of the 9.6@157Mph pass :)
9.6@157Mph
JorgeYaHeard Sep 17, 2011 07:20 AM
That is a clean car, looks like it doesn't run bad either. Good luck on getting to the 8's.
TALONGT Sep 28, 2011 03:18 PM
Whats left of my old 300M upgraded 5 speed transfer case :(
http://talongt66.4t.com/old300mtcase.JPG
And the new auto transfer case after machining for the larger 300M output shaft and re- setting clearances.
http://talongt66.4t.com/300mautotcase.JPG
http://talongt66.4t.com/300mautotcase2.JPG
TALONGT Sep 30, 2011 06:28 AM
New 6 bolt to 2G Auto adapter plate :)
http://talongt66.4t.com/2gadapt.JPG
TALONGT Oct 2, 2011 12:30 PM
So besides an all new engine, trans setup, I'm also redoing the whole chassis. Out with the 8.5 NHRA certified cage and in with the new 25.4 certified chassis. This is going to be alot of fabrication cause I'm going to do it in the car using what I can from the exsisting cage.
http://talongt66.4t.com/cert.JPG
http://talongt66.4t.com/cert1.JPG
http://talongt66.4t.com/cert2.JPG
http://talongt66.4t.com/cert3.JPG
TALONGT Oct 6, 2011 07:37 AM
More parts for the auto swap my Kiggly 6 bolt SFI flex plate, ready to bolt up :D
http://talongt66.4t.com/flexplate.JPG
TALONGT Oct 10, 2011 10:40 AM
New Kiggly HLA to help limit the amount of oil getting pushed up to the head a common problem with these motors if turned at very high RPM.
http://talongt66.4t.com/hla.JPG
TALONGT Oct 14, 2011 09:30 PM
So just recieved my new set of Wiesco HD Pistons for my 2.0L build, going to clean them up and do a few tricks and then there ready to install
http://talongt66.4t.com/pistons.JPG
6thGenJed Oct 16, 2011 12:31 PM
dope.
TALONGT Oct 19, 2011 11:50 AM
Most of the parts are at the machine shop for the short block and going to start the chassis part of the build on next days off :)
TALONGT Oct 22, 2011 11:38 AM
New rods awaiting some final machining and still need to build a jig for the bearings :) This is going to be a light weight setup as I plan to turn this motor alot higher then I have my 2.3 in the past.
http://talongt66.4t.com/rods.JPG
gwiffer Oct 22, 2011 01:25 PM
Nice rig!
