New Cadillac CT6 will have a CADILLAC V8
AWD :)
A twin turbo hot-side, Cadillac Exclusive engine. Comes in the two different horsepower versions, although it seems like there isn't a great spread between the two. It's paired to the 10spd auto, so turbo lag/dropoff between shifts should be minimal, if any. Forged aluminum rods? (another article from Autoweek said forged steel con rods, so I don't know) http://autoweek.com/article/technolo...lac-has-new-v8 How do they manage the heat from such a configuration - yes, I'm ignorant. Some specs: 4.2-liter preliminary specs:
http://www.autonews.com/article/2018...sive-engine-v8 GMauthority has some more drivetrain details, although I think the wording is somewhat vague or proofing needed? http://gmauthority.com/blog/2018/03/...hiseled-looks/ |
Didn't they have a massacre there?
Glad to see GM is finally stepping into more modern times. Can't wait to see how this engine holds up.
Originally Posted by six40
(Post 11811220)
Love this quote from R & T "The turbos will be running 20 lbs of boost apiece, shoving air into cylinders with a 9.8:1 compression ratio"
Uuuuh??, so 40 pounds of boost, LOL!!!!!!!!!!!!!!!! |
20psi is 20psi...lol. Doesn't matter how many turbo's there are. Silly journalists.
That torque number looks nice.
(Post 11811552)
If there are two totally separate intake tracts (including into each head with two separate throttle bodies), then maybe it's not as bad as I first thought. |
Originally Posted by OX
(Post 11811586)
The more I thought about it, maybe they phrased it that way since the turbos are in the "V" of the engine.
(Post 11811592)
I would guess it would still be mostly the same if both turbo's fed one intake manifold. Its the same amount of air going into the same amount of engine :)
didn't even know that what they wrote sounds weird LOL!!! |
Ford pickups are like this, two tiny turbos.
(Post 11811740)
They're not in the valley though.
How long do the modern, (highest quality - I assume in this case) oem gas-engine turbos last?
