WTB: Non-ACD T-case housing
Wanted
I was interested, and still would be im just not sure its the same as the evo housing. I read on another found the shaft inputs and ring is a different size. Have any specs or another thread to confirm airtrek housing is the same as the non acd 8/9?
What I do know.
1. The airtrek transfer can use the same open, lsd and wavetrac unit in the front diff carrier. I used all three.
2. The ratios are different, however you only needed the housing, so that doesn't matter. All the seals used are the same, shafts sizes are the same
