FS: 2003 Lightening Yellow Evo VIII
Car has approx. 45,xxx miles. Here are the mods done to the car:
Buschur turbo back exhaust
Buschur hiflow cat
Buschur upper intercooler pipe
Buschur lower intercooler pipe
Buschur MBC
680 injectors
Walbro fuel pump
GSC 280 cam shafts
SS O2 housing
SMC Alky injection kit
Forge RS DV
HKS RS intake
HKS turbo timer
ARP studs
Exedy twin clutch
FP 20GLT-Turbo
Zietronix wide band
Viper paging alarm
35% tint
JDM tail lights
Black out front head lights.
Also, some additional dealer upgrades
This car dynoed at 387hp/417ft.lbs. of torque at 28psi on a mustang dyno here locally. Stock Evo VIII's dyno 200-220 on this dyno. The clutch was installed back in 2004. It's now slipping and will need to be replaced. It's still very driveable as long as you don't hammer the gas pedal. You can pick up an Exedy clutch rebuild kit for under $500. Everything on this car was installed by me and tuned by me. The body is in decent shape, no rust or noticeable dings. I have never had any issues with this car except for one minor issue. The SMC alky kit is leaking and I will ship it to SMC to get the seal replace. It's common issue on this kit. This is really a great car and it pains me to have to let it go. This car gets full boost of 28lbs by 4,200 rpm. It's a blast to drive it. I'm asking $21,000 for it.
Here's another option, asking $23,000. I will include a spare Evo VIII motor with approx. 8,000 miles on it. The motor is at my cousin's house as I'm trying to work out a deal with him (pending).
Here are the additional parts with the extra motor.
Full motor excluding drive axles.(including tc and tranny)
Stock ECU (no wire harness)
Transfer shaft (goes from rear differential to tc)
Rear differential
Lots of extra spare parts should you decide you want to go all out and not having to worry about spare parts. I think this is a real reasonable deal for what I'm offering. Please pm me if interested. I will not part out or sell parts. Thanks
Buschur hiflow cat
Buschur MBC
680 injectors
Walbro fuel pump
GSC 280 cam shafts
SS O2 housing
Forge RS DV
HKS RS intake
HKS turbo timer
ARP studs
Exedy twin clutch
FP 20GLT-Turbo
Zietronix wide band
Viper paging alarm
35% tint
JDM tail lights
Rear differential
