View Full Version : Evo General
- Do takata Eye bolts Fit into evo factory seat belt bolt locations?
- FP Green Rebuild
- Donut Gasket
- Installing FP BLACK, TO DO LIST???
- Black with a stroker&meth? or 2.0 drop ins, built head and meth?
- EVO 8 Quiet Cams?
- burned up stock evo8 ecu
- Changed rear diff & transfer case fluids
- Evo IX lsd
- How is your APR Splitter holding up?
- Evo IX to Evo X owners, thoughts and opinions?
- First "mod," car alarm or Valentine.
- Srs light???
- help need plz
- crower rods
- Pivot shift lamp
- Ix gsr into ix mr
- where to buy??
- evo wont turn off! full power to ignition, dash lights on w/o key
- Service light came on! :(
- EVO Haynes Manual????
- Sun roof wont tilt??
- MR 6 speed shifter knob sticker
- Evo paid off
- Wheel offset question!
- datalogging for evo?
- 04 RS running very rich, not many mods..
- Pic Request Evo iX turbo next to FP Black
- Recommendations on removing breather filter
- Catch Can
- JDM/USDM Carbon fiber rear crash beam
- Quality of voltex carbon????
- Engine compression.
- upgrades
- How to ship a bare block?
- FWD evo?
- MR aluminum roof strong enough for bike rack?
- are evo's really that great in snow?
- parts for hvac relocation
- What is the benifit of having two map tunes?
- Socket in transmission
- Plugs and gap?
- New Turbo - Need Wastegate Spring Pressure #'s
- Evo 8 oil leak from lower crank area.
- Hid headlight buzz???
- UICP and Intake ?
- 06 MR 98k miles
- Tach Problem...
- Evo pedal to floor is same as half way?
- hi enoying sound on me evo is it normall
- Berk Technology high flow cat or MIL. Spec?
- Chatter/Rattling Noise??
- Flat tow short distance?
- Clutch Pedal getting stuck to floor, CEL came on next day
- Question about boost up!
- Car is back in action!
- i got evo VIII stock what do i need to run on e85 and gain about 100hp?
- Turbo Timer Clock
- Cat off??
- how many dents and dings do u have on ur evo?
- Market Research 2: Color DV
- 6-speed shifter knob
- Marketing Research - Different Color BOV
- Thinking about converting to SD
- How are they different Gsr, Se, Mr?
- How to restrict steering angle
- has anyone ever taken off the evo 9 antenna
- Reverse Lights Not Working? It's Probably the Backup Light Switch
- what to get built first? the tranny or tcase ?
- Shut off button?
- where to sell 2.4 heads
- do i need to replace my bov?
- headlight relay.. my lights turn on when car is off
- Fenders
- What boost gauge for high boost??
- BR Fabricated intake manifold or Magnus V5
- spark plug coil bolt
- Autocross stock class exhaust
- Mil.Spec throttlebody shaft seals are great!
- fp black turn around time
- tru boost
- Question about lights in hvac
- Finally Back and Running!
- ignition/idle problem(PLEASE HELP)
- ROTA wheels and your thoughts on them?
- anyone attempted tinting their own gauges?
- hks cams?
- Evo Gauge Pod Question
- Exhaust Manifold heat shield part number?
- Coolant leak
- newb gauge pod question
- NJ: Inspection
- Stroker kit that is high reving
- exedy twin disk question?
- CBRD- in the shop- whats going on?
- not another JDM Rear Bumper
- 120k service
- Evo IX Front Bumper+SE Lip=Zero Lift Kit?
- Buying an evo with an accident history
- What exactly does the A/C fan do?
- Evolution vi owners!!!!! Unite!
- Oil pressure gauge
- 255 WHP w TBE and Boost?
- MPG meters and relative accuracy.
- AEM UGEO wideband problem.HELP?!?
- Cold Start Issues
- roof racks, best places/prices?
- What is this? Help!
- Ralliart Shift knob
- Fog lights wont come on.
- OBX exhaust?
- car wont go on WOT
- question ":)
- Seat belts?
- looking at a car on the other side of the country.. good idea??
- Shakes at 40 mph
- Thread for non car related for sale items?
- Smaller ac fan?
- Gapping the spark plug
- Front bumper took it hard
- charcoal canister with high boost?
- Top Gear...Evo VII
- trustz
- Intake/Injector sizes needed?
- 6spd drain plug tool?
- 24 Hours Of Leman
- Where can I get some good information on turbos?
- Exedy twin disk question...
- No Start issue
- what gaskets/bolts do i need for fp black install?
- Help. Need Advice- Got a ticket
- Notory to register my evo???
- Windshield license plate frame
- PU Do Luck
- Misfire help? Anyone??
- Road &Track test Evo Vs Sti in rally competition
- Claercoat on CF Hood
- Video of an Evo IX blowing, what happened hear?
- Overheating??
- Evo VII ACD Pump Location
- Featured in the February Issue of DSPORT: Fortune Auto Evo
- Help: What is this plug in dash?
- AMS Test Pipe?
- Been awhile and bye bye Evo IV
- Tial bov vs synapse bov recirc
- OEM cams...
- 4 years went by fine... Now it's a prob?
- Oil Cooler Question
- Aftermarket Seat Bracket Options
- Chris Fisher
- Spray Down the Bay?
- Choice of fuels....93 w/ethanol or 91 ethanol free????
- Found an EVO for 6K but it has no title :/ 34k miles
- power problems?
- Reset ECU procedure
- front Bumper bolt?
- Bayson R side skirts?
- What's with the stock inner evo 8 lights that have no bulb inside?
- Evo + Rain = better evo ?
- Removed rear seat and now SRS light.
- What size bolt do I need to plug my Test pipe/exhaust
- Buschur Racing C.O.P question?
- Project Pikachu, on the way to Texas and the 200MPH CLUB!
- backfire popping under boost
- My car is a shop WOW
- tuning issues?
- Evo IX with rear facing car seat pictures
- AEM wideband readings going whacky
- 60k service difficulty?
- Power Inverters (Plug in not Hard Wired)
- What bolts for heat shield
- ACD Lights: Fault Code 82
- (CHECK ENGINE LIGHT) Catalyst system efficiency below threshold
- Test pipe cel question
- Tial 50mm BOV problem with Evo IX
- Are CF lips durable enough for autocross?
- Stock Fuel Rail
- Evo do-luck poly lips available again!
- E-Spec - The Review
- sooo whats broken lol (pics)
- Rev Hang
- Anyone know what position to put unorthodox racing cam gears in?
- Replacing Front Driver Side Axle
- Ebay relocation license plate bracket
- Nisei licp coupler sizes??
- evo 3 front lsd.......which one
- Pic Request
- Hood protector
- Does your evo smoke like this?
- My poor evo
- Can someone ID this engine bay part and function?
- Alternator?
- where do these plugs go
- Tranny fluid crush ring size?
- Where do i get evo 9 front bumper support brace for the top grill?
- mini battery help
- Do I Have A Right To be Upset?
- Any drawbacks to the older quartermaster twin disk?
- Found an Evo I'm trying to get...
- best fitment for 3" downpipe for 05 evo 8 (with acd)
- power steering pump
- vented oil filler cap
- cold start up?
- anyone knows what o2 dump will fit the HKS 7460r??
- AEM Oil Temp Gauge..Whats the sensor
- should i trade my fp green for a borg warner s366
- can anyone help with mini battery info
- whats this sensor for on the back of block?--PICS INSIDE?
- Anyone running Tanabe Concept G Blue with JDM Rear ?
- Anyone using the powetrain technology clutch?
- A/C blowing cold air then stops?
- Replacing HIDs
- Who makes a Good Quality D2S 6000K Bulb?
- Cam gears cheap Really cheap
- Towing with your evo??
- stuck clutch
- rear window wiper plug ?
- P0110 in traffic
- Hp.. I want some
- Help me find a shirt
- catch can install help
- Has anyone rolled back and hit a car?
- Japan Trip
- body panels
- Clutch Help
- ugh ob2 readiness ......
- 2.4 block,what crank?
- How much boost lost TB seals
- Turbo oil lines?
- Plastic Undercarriage - Regarding Radiator Flush
- New evo
- Belt snapped, safe to drive?
- "No Start" Conditions...any you can think of.
- Over Sensitive throttle!
- Is the Air Filter snorkel needed?
- Parts! Quater Panel, front clip & more
- Where can I buy
- Steering wheel not lining up!
- to all 2.4 guys
- RC Hil Mitsubishi. How to lose a customers business. Poor warranty service.
- question about green warning light
- Fuel pump problems...
- uego wideband install help....
- Build Review
- Hack 'n MOD '06 MR shifter
- Hot jet coating!!!
- service engine light
- Any benefits of running 3in upper i/c then 2.5in
- 4th Gear
- How to build a proper Evo - weighs only 850kg!! Evo Pro by Nicolam
