- Dual Bypass Oil Filter install on an Evo
- How to install an AFC II with the harness!!!
- Hole in firewall?
- Evo stalling after tune up...why?
- I need HELP! MY Greddy boost guage is reading crazy boost
- apexi turbo timer help
- Tail Light Mod - WEBCAST
- Is There A Way You Can Take Apart The Tail Lights Without A Heat Gun???
- Cusco Oil Catch Can Install Pics (With Buschur Intake)
- How to install a small shift light into your HVAC vent
- new Evo oil change question
- Mechanical o2 Fix
- steering wheel not centered is it the alignment ?
- What COLOR is the speed sensor wire in the ECU?
- SAFC2 dimensions (will it fit in lower panel)?
- Autometer ultralite boost guage?
- free DIY better flowing stock exhaust.
- Easy & Cheap Foglamp Bulb Upgrade
- How-to: Ghetto Stubby Antenna Mod
- How-to: Color match or brighten gauge and interior lights
- need help!!!!
- Need advise on Greddy TT Install
- How do you like your GFB bov?
- Has anyone used a Raptor Shift Light
- Escort Passport SR7 Installed
- Stiff Shifter Bushings Kit Installed
- cleaning/detailing engine bay
- Cam gear install question.
- HOW tight is your SSBOV???
- lean out?????
- need tips on replacing drive belts
- How To: Evo tail light install, a must read!
- is there a "HOW TO" install and wire the MR headlights
- Mitsu. gauges
- brake pad change
- Question on Defi Boost Guage
- Apexi Turbo Timer Question?
- How To: Change your Brake Pad, or Remove Brake Dust
- Stripped Plastic Gear on Headlight!
- How to cut your undertray to fit your Hyperflow FMIC
- AEM Tru-Time Cam Gear and HKS Installation tuned by Vishnu.
- Genuine Mitsu. Fluids and parts???
- How To Blackout Taillights
- How to black out tail lights video
- **NEED HELP** HKS boost gauge
- Stock evo BOV pic
- newbie q:ECU
- looking for jdm black corner lenses
- Unofficial Tech Support Site
- How 2 remov Tail lights cluster
- How to Remove/Replace Manual Crank Window Handle
- Need a "How To"
- PWR intercooler/ Buschur piping
- vishnu exhaust
- RS owners, how do you remove the window handle???
- Car stereo question
- Oil change
- How to Drain Fuel from Tank?
- Shift Knob Removel/Installation
- How to Install Buschur Muffler Delete
- need help with power terminal to ignition switch
- Defi BF Exhaust Temp Meter
- How to plug holes after removal of CF Wing
- How to install Speed cut limiter typa A Greedy?
- Perrin Oil Catch can Installation w/ pics
- help with oil pressure gauge install
- Note when installing/using harness
- How to Bleed Clutch?
- AEM Short Ram Tips / Nightmares
- Installed paint chip protectors (warning: lots of big pics)
- Lug bolt replacement
- How-to Replace Engine Air Cleaner
- Need to kno how to wire rear speakers
- Has anyone used a Greddy 14-43 tubo timer harness with a HKS type 1?
- change fog light color
- Anyone change the bulbs on thhe stock gauges?
- Gearbox Change
- Programming a New Key
- Headlights
- EVO Clutch Install, includes t-case removal and service manual links
- How to Make your own Exhaust Shield!!!
- How to change you Exhaust Manifold
- Gauging interest for 2 new writeups: Intercooler sprayer switch and foglight mod.
- Dumb question, how to remove glove box
- how to remove rear seat?
- dynomat on the front door??
- How To Install Mr Headlight Foglight
- Which hose to tap for boost gauge?
- OIL/Filter CHANGE
- Applied dash kit, need help.
- How do I solve the stalling?
- UR/Helix Test Pipe
- Just installed A/F Gauge. Questions?
- new rotora rotors and bobcat pads w/pics
- Tachometer installation
- EVO RS Trunk Bar Install
- How do you replace trunk lids?
- Plug Wire Hard to Pull Off
- How do i install an oil press. gauge?
- How To - Install and Maintain HKS drop-in filter (or any foam filter)
- How exactly do I remove front fascia?
- How Do I remove The Clutch Spring
- perrin o2 simulator install
- How do I remove the stock airbox ?
- Need Help Installing Bov
- do you want a write up/pics on rotora rotors and bobcat pads?
- Removal of exhaust manifold
- Help! Half the lights on my instrument panel are out!
- anyone know how to install a greddy oil catch?
- Intercooler
- Air/Fuel Guage Installation HELP
- sticky situation
- Need Help!!
- Need tips on removing head
- How do you remove door panel?
- Bottomed out...Please Help (56K Warning)
- How do I remove Stock Radio?
- MR Headlight installation
- Removing the Headliner
- Torque specifications for cam install
- Battery Relocation how-to, need input/polishing
- HKS racing type two blow off valve
- Need help with Bumpers
- Coolant replacement
- How To Request: Roll your fenders
- clutch replacement
- Stock Evo Headunit has static
- Grease Joints?
- Make an EVO lighter
- Map for Evo 8w/1313/MAP sensor
- need a little help installing injectors
- swurls on the evo
- Installed helix test pipe, need help!
- How to bleed your brakes
- Stainless Steel Brake Line Install
- HKS type 2 racing BOV ...help?
- Oil Plug not coming off
- EVO RS power conversions
- Evo 6 build
- Buschur Racing Mini Battery install help!
- Evo 7 Cluster
- How to make a Cool Air Scoop
- Help with Defi control unit 2 install
- hks hi power
- HKS DB Mechanical Temperature Fix
- How to make a fiberglass gauge pod
- How to: Install AEM c2di on evo 8 plz help !
- Installing aftermarket headunit on Infinity equip'd Evo
- B&M Precision Sport Shifter Install
- Request: How to remove rear spoiler
- underbody lights
- Blitz Dtt
- HKS Chrono DB Boost Gauge - How to Use
- Has anyone installed the HKS EIDS?
- Is there any way to bypass the handbrake safety check.
- Manifold removal guidelines
- Cabin Air Filter
- 1/2 91octane 1/2 100octane
- HKS EIDs Install
- Wideband O2 sensor install
- Blitz dttx (dual turbo timer X)
- S-AFC2 User Guide
- Where is the air purifier filter?
- Evo8 Fuel Pressure Regulator Vacuum Line Size?
- Front Grille
- Installing turbo kit
- Another $10 mod (batt. kit)
- evo steering wheel
- cusco oil catch can installation
- How do you change the back lights of the boost guages ?
- Help....Stock Stereo Wiring...
- Status Lights - dont' go off
- help fast please read
- Need help w/ oil catch can
- greddy profec b spec 2 installtion?
- Vampire Taps?
- How to install autofold side mirrors
- O2 Simulator Install
- how to install head stud
- simple tt very frustrating, plz help
- request, how to: diy black tail lights
- Gauge/Profec B electronic install - help needed
- How to install 02 sim?
- Radio Removal??
- Schroth 4pt. Harness Install
- How to fix Turbo timer
- New VIS Carbon fiber trunk has big gap!! Please Help
- Turbo Timer installation costs?
- greddy front mount kit on stock turbo
- Request for missing picture of rubber suspension spacer in FAQ
- Correct Pressure and Temp. Readings - Oil, Fuel, Air/Fuel, Coolant, Etc.
- BG Syncro Shift lube
- Best method of removing fallout?
- Help!, Walbro 255lph fuel pump install
- Request: How to install Evo Radio
- Defi boost gauge install w/ pics
- HOWTO request Header Removal/Install
- How To Install Perrin Shorty Antenna Mast
- Anyone have a howto on repairing / replacing the front lip spoiler?
- OEM Orange Meter Cluster Color
- HOWTO: Clutch release cylindar push rod installation
- Clutch/Brake fluid ?'s
- UR Test Pipe Install
- Exhaust Flames/Fogger System
- Defi temp.(water) gauge
- Need help in draining gas from the tanks and/or fuel rail
- 3M chassis stiffener
- Clutch release cylindar push rod
- ?How Do You Wire The Road Lights To Stay On All The Time?
- ECU extension Harness?
- Whats the best way to lift an evo
- Help w/removing front License holder
- Anyone have How To of Back seat Removal???
- How hard is it to install?
- Alarm Wiring (Lancer and EVO)
- Rear Wing
- Rewiring Fog Lights to Work with High Beams
- Tips/tricks for fixing hazed headlights??
- manual boost controller
- How Do you Change oil in Evo??
- Best location for oil catch can
- HELP!!!! output shafts on transfer case
- Help with MBC
- Greddy intercooler install
- How to change your Brake Pads
- "How To" fix alloy wheel scrapes!
- Hardy Designs Gauge Panel
- $20 Mini Oil Trap HOW-TO
- intercooler piping
- HKS EVC with pics
- intake sucking to much air
- Turbo timer with Anti-lock brake light on
- EGT/Oil Temp
- Guys, need help installing my intake
- a-pillar removal?
- Ralliart I/c Piping
- Air Fuel, please help
- Q and A at Extreme's UK Website
- Request: Samco Radiator Hose
- Heat Extractor Removal
- Front DSM badge removal?
- Autometer Mounting
- Cusco Oil Catch Installation?
- Used Evo Guide
- HKS downpipe help
- removing restrictor on stuck clutch?
- Sunroof Motor Wire Colors???
- Defi Fuel Pressure Gauge Install
- Help with Profec e-01 install
- Profec e-01
