PDA
View Full Version : General Engine Management / Tuning Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28
  1. Differences between black and silver ECU+ versions?
  2. FC Datalogit vs FC PRO software kit
  3. GT35R maf readings..
  4. power fc info needed
  5. Plug and play flash at home for the IX?
  6. Are your AFR's supposed to change??
  7. wideband O2 meters: TUNING TOOL FOR MY GARAGE?
  8. Relocating the Battery?
  9. PowerFC + Commander Manual for CT9A
  10. Problems with my eevo need some help
  11. '03 with 3076 tuned
  12. Tuners & Knock
  13. What IX Plugs for meth
  14. nu b q
  15. When does race fuel go bad?
  16. AMS Meth. Question. about the light. simple Q!
  17. cobb ecu
  18. CEL code reading w/ Tactrix cable ?
  19. Cammed EVO with stock exhaust
  20. Plese help me
  21. New all-in-one graph view
  22. careful w/ launch control!
  23. Will there be problem's?
  24. what gain does SAFC tune make vs. stock?
  25. Has anyone used MoTec's Plug and Play
  26. 100 octane = ? boost
  27. Need a new Air temp sensor!
  28. Experiance with ScanGauge II?
  29. Need so help got bad dyno numbers
  30. Some detailed pics on 02 simulator install?
  31. Power FC tuner for evo
  32. Cobb AP for Evo's
  33. Tuning Expectations?
  34. Any one got Stock 3rd gear pulls?
  35. UCC Knock Column
  36. TunerPro knock light anomaly
  37. HELP! Trouble codes
  38. Which Rpm is best for the 2-step on the stock turbo?
  39. Ecutek and Sheetmetal intake manifold?
  40. Got the EVO on the Dyno finally
  41. HELP PLS Knock threshold setup and phantom knock question
  42. blue emanage problem
  43. SAFC-II readout after turing car off.
  44. evoscan with aem wideband? help
  45. WTB - Used Utec Lite
  46. Injector scaling: If ECU scaled 780cc, can I use 750cc?
  47. question for the powered gt35 evo
  48. LMA-3 / Auxbox - RPM Connection
  49. dyno graph for baseline and just tune on an 05 evo
  50. Are custom tunes always better than any mail-in flashes???
  51. hks f-con
  52. apexi power fc for the evo ix
  53. New views selector
  54. Log file trimming
  55. COBB is making Access Port for Evo
  56. Help this HAWAIIAN reach 400ehp on pump gas
  57. whats the best wideband to go with?
  58. ecu flash dyno tune results
  59. Need tune with bolt-ons?
  60. Fuel MPG
  61. Game over for AEM EMS?
  62. Coming Back To The ECU+ World.
  63. Flash? SAFC? I can’t decide. Yes I’ve searched, this is a intelligent question.
  64. Anybody experienced with Exede and ECUFlash?
  65. O2 sensor feedback
  66. Ready to be flashed jsut have questions.
  67. Running on MS 109 race gas, didnt feel power gain over 91...
  68. RPM Signal??
  69. Life after UTEC, couple questions
  70. car tuning models & auto parts
  71. Need 3 wire EGT gauge recommendation
  72. Free ecu flash! No one talking about it yet?
  73. Terrible tunes by well-known tuners???
  74. UTEC w/mapswitch & map sens on ebay, NO RESERVE!
  75. Initial Mod Review
  76. XEDE, EcuFlash, AEM...etc???
  77. New features in the last week or so
  78. Knock sensors and knock detection
  79. Issue following TurboXS tune
  80. Issue following tune
  81. evo timing question
  82. avcr setting help
  83. Achieving a stable and strong idle with cams
  84. Running rich
  85. "flood clear" wideband calibration?
  86. MAF voltage peak-peak
  87. custom tune in connecticutt
  88. Tuning
  89. 14 Psi still causing knock!!!!!
  90. Can't tune the UTEC
  91. Installed hallman MBC
  92. Engine Management options for the EVO 9?
  93. UTEC on EVO 9?
  94. utec vs. dyno tune
  95. OBD II port simulator
  96. OBD-II Switch and Plug N Play harness
  97. Need to design a failsafe for alcohol
  98. What Spark Plugs?
  99. ecu+ + ecuflash and other question
  100. Evo MR 2005 Dyno numbers
  101. plan on buying an ecu but need your help
  102. Evo timing...
  103. another UTEC for sale
  104. Stock Injector Resistance...
  105. throttle point setting
  106. Would a leaky BOV cause this?
  107. trying to sell UTEC with map switch
  108. Question about U tec anyone that knows good
  109. optimum battery voltage at idle
  110. EcuTek compatability
  111. Middle- and Longterm Experience with ECUTEK
  112. Utec with remote map switch and DTEC Map Sensor $600 shipped
  113. at what point are bigger injectors needed?
  114. Cool ECU+ picture
  115. Help with bad idle.
  116. ECU + Help with dyno Pull
  117. can anybody help with dsmlink
  118. TurboXS Utec 4 sale
  119. New P0300 fix beta available
  120. Need to Tune!! My Options....
  121. Difference??? ECUFLASH & ECUTECK
  122. power off function on SAFC-II?
  123. Found out something really interesting today
  124. For those running a GM Maf
  125. Who owns a tune? The customer or the tuner?
  126. Looking for a custom tune in the Birmingham area...
  127. New Owner needs help!!! SAFC/ECU
  128. Evo IX reflash w/stock exhaust
  129. Problem with UTEC
  130. EVO V Ralliart ECU, programable by user?
  131. ECU + Question
  132. I was told not to relfash...
  133. Can a MAFPro be used to trim fueling using an output from a meth inj flow sensor?
  134. Hardcore Idle Surge after installation of MAFT Pro (2G DSM)
  135. Timing Control anyone?
  136. Setting ECU+ TO stock
  137. Need a tuner, NY/NJ/CT
  138. Which reflash
  139. Which EMS?
  140. SM4 & 500R ignition problems
  141. At what point is tuning necessary or at least recommended.......
  142. Should I keep the SAFC-II
  143. questionHere are my time slips and my dyno sheets
  144. Datalogit read all error 84 & 88
  145. Evo 8 (stock) worth an SAFC-II?
  146. ECU + Questions
  147. Cobb accessport for evo 8&9.....
  148. EcuTek ECU "lock" discussion
  149. SAFC II pin layout....
  150. Do you have a PFC and larger than standard injectors?
  151. what to use???
  152. A couple questions....real quick.
  153. Electronic Gizmo Stupid; Please help
  154. ECUTECH support 600 whp?
  155. safc2 install on EVO IX
  156. eta on evo 9 power fc
  157. Boost controler hook with PFC
  158. fs: tuner,map selector, map sensor
  159. Boost fluctuating
  160. HKS eids+ UTEC
  161. Used Tuner Pro Install
  162. Hydra Vs. EMS Physical Comparo
  163. Coil-on-plug
  164. Stay with AVC-R or go with Blitz SBC-I color??
  165. Power FC and Precision Turbo Injector specs: needed
  166. installed AFC2 and problem occured
  167. Ivey tuning(retuned)
  168. oil low and only miles????
  169. I am in the bay area should that effect purchase
  170. Best Engine Management for Turbo Upgrade
  171. Ecutek moods
  172. PFC knock reading is high - please help !
  173. A/F Numbers with Al's Mail in Flash
  174. ATI Fluid Super Dampner
  175. Another Noob Question
  176. DTEC help
  177. Need a EMS - how easy is the PFC compared to AEM
  178. Should i go ECU flash or SAFC controller?
  179. maf
  180. Too high AFR after tune?
  181. Flash with and without mods
  182. MPG and diffrent octane......
  183. Basic Necessary Gauges
  184. Dyno calculation
  185. Cant connect
  186. ECU+ is in, how accurate is the dyno?
  187. At my wits end.. help solve my stalling!
  188. Aem Ems
  189. utec nub question
  190. cutting out problems here help
  191. mappro and meth for a 35r?
  192. 06 Evo 9 MR tuned, good numbers
  193. Pocketlogger Help
  194. Suggestions about future mods, with tech question.
  195. Evo IX ECU+ Update
  196. MAF options..
  197. Yellow Top Injectors: Lag Times..
  198. S-AFC II vs. S-AFC Neo
  199. Utec tuners
  200. IX specific thread
  201. FS: Tuner Pro w/ VW O2 Sensor
  202. how to read real time data graphs???
  203. TPS Volts Needed
  204. APEXi PFC tunner around Tampa,FL
  205. Best EM? What are people using
  206. ecu flash
  207. Mbc
  208. To Flash or not to Flash.......kinda confused on the whole thing????
  209. My experience, and where is an AFR Graph?
  210. where do i get the 3in maf sensor harness from?
  211. Aem or Flash for me?
  212. Screenshots
  213. Open Loop Fueling always on? Need some help
  214. AVC-R? settings for EVOVIII MR
  215. palmnstein o2v(2) logging
  216. Can i just hook the wideband 02 sensor into the secondary 02 sensor hole?
  217. How do you guys like MAFT PRO?
  218. FS: utec+tuner lite
  219. attn: pocketlogger users
  220. wat did i blown in the motor car wont go start shaking after 2000rpm
  221. 4 hour old autronic PnP board for sale
  222. FS: UTEC + Tuna Pro
  223. Newbie Utec Question
  224. What is the easiest way to read engine timing
  225. knock voltage datalog
  226. ecu+ ?
  227. custom tunes in alaska?
  228. Retiring the UTEC
  229. AUTRONIC + HKS 264 Cams
  230. BOV which one is good
  231. low power for a tuned evo?
  232. 05 Evo MR + SAFC trouble
  233. DynoFlash VS. UTEC
  234. Quick question about Flash
  235. Japanese EVO VII needs ECU..
  236. boost controller
  237. Whats going on, you mean I can tune it myself?
  238. injectors without fuel computer?
  239. MR578511, what ecu?
  240. Fuel Pump b4 Tuning?
  241. aftermarket ignitions
  242. This looks like a great option for standalone ECU
  243. MZM tuned evo 9 MR
  244. Anyone Have 2.3 Datalogs?
  245. Which one Maftpro,Utec, or ecu+?
  246. Air filter question
  247. Just got tuned on LI
  248. P2, P2e, P2R?
  249. so many utecs for sale...
  250. UTEC w/map switcher for sale..... 525 shipped
