- WTB: Whiteline W62951
- Wtb 03 WW hood, pass fender, and pass mirror
- WTB IX seats or SE seats
- WTB: tires 245/45/17
- WTB: 10mm Ichiba or Kics spacers
- wtt/Wtb trade s2
- hood vent ASAP
- WTT: oem TB Evo 9 wing
- WTB: Synapse DV and Walbro 255 + install kit
- WTB: Missed parts from FP Red turbo oil line kit
- WTB: Racing Hart center caps
- WTB: Omni 4 bar MAP
- WTB: Stock Valve Cover
- Evo IX MR front chassis harness fusebox
- WTB: Non ACD transfercase
- Wtb: tactrix cable for Evo 8
- WTB: Zaklee clear cam cover for IX & a few other parts
- WTB 2005 Evo 8 Factory Service/Repair Manual
- WTB fuel pressure solenoid
- Wtt ff manifold
- Need/wtb front o2 sensor evo 9
- WTB black FPR
- WTB Boost Gauge
- WTB LICP, UICP , Intercooler , Tial BOV
- Evo 8 ETS UICP
- WTB: OEM Front Aero Lip-Phantom Black
- WTB: GSC S2 Mivec cams, Perrin intake
- wtb mass
- WTB: AMS fuel rail
- wtb
- *WTB: New/Used, Black Samco or Mishimoto Lower Rad Hose for Evo IX!!*
- WTB Stock 8 turbo
- WTB TIRES 255-35-18 or 265-35-18
- WTB: Fuel pump sending unit
- WTB:NYC/LI: Evo 8 CF front lip
- Wtb oem bilstein (only front driver side)
- WTB: Brake Air Guide
- WTB: 03-04 Evo VIII ECU
- Wtb o2 dump
- WTB E9 Bad Turbo
- Buschur mini battery tray!
- wtb buschur mini battery tray
- WTB: Spoolin Up Evo 9 COP
- Zeitronix Gauge
- WTB: Fuel Pump Connector
- WTB: 5 Speed Tranny Bell Housing(NY)
- WTB: stock rear speakers for evo 8/9
- WTB: 2.0 Evo8 Block
- WTB - 17x10 rpf1 38mm - (2)
- WTB: AEM oil pressure gauge
- wtb evo 9 seats
- WTB Rear brake caliper
- WTB: evo X throttle bodies
- Wtb oem evo 9 turbo lines!
- WTB: front left ABS sensor
- WTB: trunk interior parts
- WTB: Evo 9 Turbo W/O exhaust housing
- WTB rear LSD unit
- WTB 1.3 tactrix cable
- WTB: Test Pipe
- WTB: A Bunch of Evo 8 Stock Parts
- WTB - AWD Aluminum Drive shaft
- WTB: Missing Fuel Pump Parts
- WTB: fluidampr harmonic balancer
- WTB: tactrix Cable 1.3
- LF , WTB : A/C compressor
- WTB: AMS F1-I intake manifold
- WTB: OEM 8 oil cooler duct
- WTT: BB FP Red for.....
- WTB o2 dump ASAP and full TBE
- WTB Evo 9 turbo W/ 9 pipe
- Wtb: fog light button
- WTB:Front Lower Control Arms Both Sides!
- WTB: Quaife LSD
- WTT: Greddy Full Titanium Racing Exhaust
- WTB: Evo 8/9 BBS Wheels
- WTB: AEM series 2 for evo 9 mivec
- WTB: A Evo 9 Shell
- WTB: GG Hood and pass frnt fender
- Wtb: Evo 8 valve cover
- WTB: Evo 9 OEM SE Lip
- WTB: HVAC Panel
- WTB Stock IX Parts
- WTB: GG hood and pass fender
- Badly needing the following parts.WILL BUY SOON!!
- WTB(NY) oem evo 8 stock exhaust
- wtb: buschur 65mm throttlebody
- OEM Ex Mani w/ SAS provisions 678 - WTB
- WTB: oil pump drive pulley ASAP
- WTT: EF3 with less than 1500 miles what does every1 have to trade me? Turbo's only
- WTB Starter
- WTB: Tubular exhaust manifold
- WTT: HKS SSQ + pipe for Tial BOV
- Fuse cover under hood-driver side-evo8/9
- WTB Evo 8 272 Cams, and coilovers
- WTB: Rexpeed air ducts and evo 8 front frame backet
- WTB: .020 Pistons and rods
- WTB: 3 or 4 bar map sensor
- Evo 9 bilstein coils and defi gauges
- WTB: Crank Position Sensor
- WTB Evo 8 Block!
- wtb 1 eagle rod
- WTB: trunk parts and sun visor
- WTB: Tial QR, UICP, Intake Mani, TB
- WTB: Evo 8 Trans
- WTB: Your Evo VIII SHELL
- Wtb hks air box
- WTB : Evo 9 aftermarket in/ex cam
- WTT: Tial Q for Tial QR
- WTB: Stock Lower Cubby
- Xenon Ballast Connector for OEM Xenons
- WTB Evo 8 TB factory wing
- WTB tactrix, timing belt, uego cable etc.
- WTB: white driver side window switch connector thingy!
- WTB Evo 9 Valve Cover
- wtb: evo 9 turbo ASAP !
- WTB: AWD Aluminum Driveshaft and Buschur Lightweight Parts...
- WTB: Alot of misc... parts
- WTB 750cc+ injectors for Evo 8
- WTB IAC for VIII
- WTB: Wedge Collar
- Need Clip for Throttle Position Sensor Wiring Plug
- WTT my SSL seats for SE or reg 9 seats SoCal
- WTB: Upper plastic steering wheel piece
- Wtb exedy twin disc
- WTB: 10.5 hot side ASAP!!!
- WTB: 5 Speed Tranny with problems(NY)
- WTB: Magnus Cast mani
- WTB: Spoolinup for Evo 9
- WTB: Evo running engine or good condition Short Block
- WTB: Fuel pump hanger parts or whole assembly
- WTT: Seibon hood for WW hood
- Wtb: transmission case
- WTB Wideband
- wtb: black aem analog boost gauge
- WTB: Non acd RS LSD Tcase
- WTB: RPF-1 Center Caps
- WTB: Clutch master cylinder
- WTB: 3gauge a pillar pod/ jdm double din
- WTB JB Fp Black Turbo
- WTB: 4 bolt housing .82 AR for 35R
- wtb aftermarket intercooler-- no ebay
- WTT Acer Iconia A500 Tablet for a FMIC
- WTT: Aftermarket AS lip for stock one
- WTB (MD): GrimmSpeed EBCS, gently used
- WTB: 10.5 Hotside
- WTB: RR wing evo 8 or 9
- WTT: my Evo 9 trunk and wing for CF trunk
- wtt full t3 kit for stock evo 9 turbo
- WTB evo 8 turbo WGA, OEM trunk, dash panel
- wtb: 2000cc injectors, synapse
- WTB : Evo 8 stock cat
- WTB: tactrix, timing tool, belts, etc.
- WTB Evo IX spark plug cover & exhaust manifold heatshield
- WTB: Evo IX Lip and Undertray
- WTB 4'' intake for MAF
- WTB: evo 9 stock fuel rail,injectors
- WTB: 6speed front console!
- WTB: stock rear speakers and covers
- WTB: Cobb AP for evo 9
- wtb ix bov
- WTB EVO 9 TURBO or BETTER
- WTB: Stock 9 DV
- wtb buschur mustache bar
- Wanted : Evo 9 j-pipe (turbo->intercooler pipe)
- WTB 6 Speed Shifter BOX with Cables x2
- WTB: OEM Cam Trigger Wheel
- WTB: tactrix cable
- WTB forge bov!
- WTB: Forge BOV
- WTB stock 560 injectors
- WTB: evo 8 cross member motor mount
- WTB: 5 speed console!
- Wtb: Gtx3576r
- WTB: HVAC control unit
- Turbo RS 10.5 HRA - WTB
- WTT: My full 3" RMR ceramic coated DP for dp that better clears my croxx plate
- wtb: factory airbox inlet scoop
- Wtb ets licp
- WTB: 2.4 LR block
- WTB: ETS I/C Piping & Intake
- WTB: OEM Front Engine Mount
- Wtb : Jdm evo 7 red tail lights
- WTB Evo 9 MR Center Console Piece
- WTB T3 tubular manifold & turbo to downpipe piece
- WTB EVO 8 block for rebuild
- Wtb: Antenna base
- WTB: Testpipe 3" & Downpipe
- WTB Wheel wells
- WTB 10.5 hotside for Evo 8 turbo
- wtb: shields behind cams
- WTB: Carbon Fiber Side Spats
- Wtb evo 8 lip asap
- WTB: Rexpeed Rear Bumper Extenders (for JDM IX Bumper)
- wtb: evo 8 front passenger axle with abs ring
- WTB tatrix cable!
- WTB: HeadLight Harness/Adapter HELP! LOOK INSIDE.
- WTB: Full Engine Wiring Harness!
- Wtb aem wideband gauge
- WTB: main housing from ACD transfer case
- WTB: BR bullet muffler SCCA exhaust and Spoolin up COP
- WTB: EVO 9 MIVEC Head - SoCal
- WTB exhaust
- WTB: Apex Silver trunk or CF in NC
- WTB: stock VIII or IX wheels
- WTB: 272 cams, FP,BBK,EF Turbo, Twin disk,ETC
- WTB: Evo 9 Bov *bay area*
- WTB Invidia 02 housing
- WTB: Tarmac Black (TB) OEM Rear Bumper and side skirts
- WTB - Help me de-rice my new EVO! I NEED EVO 8 Recaros!!!
- wtb: Evo 8 Block...what's u got?
- N.j.-n.y. ---->wtb evo 8 oeom front bumper
- WTB: 1 Falken Azenis RT-615 265/35/18
- CA: WTT 2006 Evo IX SSL Electric Blue CLEAN TITLE/75k miles /Close to stock bolt on's
- WTB: linea corse lemans +17
- WTB: Evo IX Valve Cover
- wtb: evo9 front grill
- WTB: Stock IX Wheels or Rotas
- WTB Misc nuts and bolts, t bolt clamps
- WTB: FP BLack turbo
- WTB GG Rear Bumper Cover & Reinforcement
- WTB: T3 kit
- WTB: Evo 9 Stock Cat
- WTB: Electronic boost controller
- WTB: Adjustable Cam Gears In California
- WTB Tactrix OpenPort 2.0 or 1.3
- WTB Evo 9 BOV
- WTB: JDM Rear Bumper BBY(where can I find)
- Wtb AMS Fuel surge tank
- wtb: rexpeed type-c carbon fiber
- WTB Trunk, Quarter panel and more
- WTB: Evo 9 forge or buscher wastegate actuator
- WTB: Lightweight Parts!
- WTB: Deck mechanical lip for EVO 9.
- WTB: 17x9 +35 wheels
- Wtb: evo 9 gsc s3
- WTB: condensor and evaporator for A/C
- evo 9 cams
- Wtb stock Evo 9 head in Tri-state area ASAP
- WTB, 'Coltspeed', 'Garage HRS' triple gauge fascia.
- WTB: OEM Car Cover
- WTB Tactrix Cable
- WTB: BC Racing BR Coilovers for VIII/IX
- WTB: Evo VIII Stock ECU and CAS
- WTB: Cobb Accessport for EVO 9
- Wtb: Jdm rear bumper gg
