- tranny and tc removal
- non-invasive resistor pack bypass.
- adjust shifter cable?
- Which exhaust out of these 3!?!?!
- Stock PSI on a 2006 IX ?
- installing my turbokit, help w/ vac lines please
- Forge Type RS never Fluttered
- maybe fuel cut off?
- Getting compressor surge & part throttle bucking in high gear
- loss of boost on 9 mr
- Problem....
- Service Enginge Soon Light On?
- Help Quick, GREY OIL! Blown head gasket???
- SlowBoy Racing GT35r Any good????
- Dirty air filter = 70 whp!
- Head Gasket Work
- Metal scraping noise?
- HKS BOV Question ... yes another one
- Flutter at WOT
- Buschur Racing fuel system solutions....
- Do I have the least powerful IX w/ mods and tune???
- can i use this ignition setup on the stock ecu
- First time at the track: Race gas & broken clutch
- new tilton (rebuild) AMAZING
- just installed a new turboback and have trouble with it
- Greddy E-manage + 50Trim....??
- just got my BR37r, need coolant lines
- Snow Performance Meth kit. Questions and help
- best/most accurate gauges ?????
- Fluids and dealer stuff
- ? for Nisei FMIC owners
- normal driving ?
- Cams and the effects on boost taper
- TME 6.5 turbo vs IX stock turbo.
- clicking sound stock?
- Car slower after clutch install???
- Anyone ever change a knock sensor?
- How accurate is Blitz I-colors dyno
- trans chatter noise
- ultimate racing downpipe
- Clanking vibration from tran?
- Update on 2.3 build with pt67 turbo (PICS)
- Is it tuned rigorously & conservative ?
- just out of curiousity. let me know please :)
- Clutch bearing noise ACT??
- Just had my SES codes checked, got 5 of them.
- Forge UNOS MBC HELP!
- Dc sports turboback??
- intercoolers
- clutch install question
- Where to buy just a TME compressor wheel?
- Need a new clutch, any info on what not to get and what to get?
- Crank Question
- GSC 280's installed with dynosheets
- cams
- short shift kit????
- Wastegate Question
- HKS Carbon-Titanium exhaust worth it??????
- Fluid spitting out of my exhaust with a little rougher idle.
- 20g TME turbo?
- Is this the "50 trim" that everyone's talking about?
- Evo Xi
- poped out of gear
- Shift Alignment?
- Aftermarket parts for sale new and used
- Lightened flywheel or not?
- A1000 in the trunk... good ?
- buschur intake require tune?
- Power potential for IX
- 4g63 supercharger?
- evo 4g63 viscous crank damper
- need help oil inside the maf sensor and pipe
- bushur racing tbe problems
- For those using synchromesh.
- WHAT WHP will stock clutch hold
- V Band O2
- HKS DL2 Dyno Gains?
- Engine Oil Temps
- TME Turbo with 9.8 Housing on 2.3 Stroker
- fluids please !
- EVO longblock weakness???
- evo ix benefits?
- ANYone with a T88?
- Head Flow Testing
- Boost Leak test with upgraded Wastegate question
- EVO8 Bolt-on GT Turbo with Housing
- Built 2.0 or stroker? Opinions/facts wanted
- Quick ACT question.
- Invidia Manifold
- Manual boost controller on stock engine?
- Hey 05 Evo Viii Owners!!!!
- Brutal oil leak...bad
- tilton problem!!!!!
- buschur tbe question
- Only 12 PSI! What is wrong?
- Blox Cams
- evo 8 clutch
- Less vacuum line = Less boost?
- hks bov
- Cannot decide on universal muffler...
- which bearing?
- idle/boost prob?
- 4g63 block differences
- shoot flames
- Twin scroll GT3076 Vs. GT35. 93octane
- Question about wastegate spring strength and drivability
- turbo upgrade for the IX. a few ??
- BR stage one?
- TBE Question.
- compression numbers...
- XS Engineering DP and Nesei LICP on IX
- Tranny flush after 2k, and look what I found...
- New twin scroll dynos with Comp280+
- want to install Ti T.M.E. Turbocharger
- Overvolting the fuel pump
- Buscher intake?
- Cosworth EVO IX Cams - who sells them?
- tbe
- My clutch is finally ****ed!!
- Camshaft sensor broke - Is the EVO 8 same as EVO 6? HELP!!
- Smooth shifter?
- Short Throw Shifter For Evo MR's??
- Super Fast clutch Install w/pics!
- Whats new with the new 20g
- CLutch pedal....high engagement
- wastegate problem.Need help
- HKS has new stuff for 4G63
- valve cover gasket
- 2 very wierd probelms
- ? for stock ecu
- Perrin catback...What does it sound like?
- What is Wrong with my EVO 8?
- Expected bhp of a gt37, on a 2.3ltr
- biggest baddest turbo for 03 stock internals
- BR cast manifold
- couple problems after the track
- pics of forge mbc installed
- Forge WGA Maybe? - Boost issue.
- Denso Fuel pump part # ?? 255lph?
- compression test on evo 9
- Should i Heat Wrap my...
- a need 4 forge dv?
- clutch help!
- Red Line need help
- Turbo upgrade questions...
- Speed Source lower intercooler pipe for IX?
- Buschur Racing Or HPF GT35R Kit? HELP!!!
- just installed DC sport dp..
- Need heat shielding for the under side of the hood...
- help!? what gaskets are needed when putting in a new engine?
- Draining coolant?
- Syncromesh in Transfer Case
- How to get more appreciable gains from stock turbo?
- Stalling After 3" Intake - Resolved???
- Driveline Fluids??
- POLL: Transmission Rebuilt yet?
- A1000 positioning
- Ordering my GT35R Kit tomorrow.
- 3" exhaust resonator?
- Anyone test the limits of stock exhaust?
- IC piping hoses for just the connection to the IC?
- Megan Racing Intercooler
- Purchasing SBR 30r kit tomorrow!!
- 06 MR overboosting....
- 5th gear scratch
- Newb Question Please Help :)
- any pics of br-fp3065
- clutch opinions
- Hesitation at 6k?
- cryo2 worth it or not
- HELP!!! Boosting insanely
- My Turbo XS FMIC Review & Data
- just changed diff fluid.
- Stroker Kit Vs Rebuilt 2.0
- DIY "Gus Mod" Switch Questions
- The click click from hell
- Blow off valve location?
- ALS Plugs???
- drivetrain shock
- F&F Exhaust
- noob DV/Boost Leak Test Question
- Oversize bearings? machined crank
- Crower 272 Cams Help
- greddy profecb spec 2 (EVo8)
- wht is a good evo 8 turbo header ??
- surge problem
- Ebay FMIC's actually perform well?!
- mbc problem
- just installed evo 9 turbo...
- Can't decide which cams to get. HELP
- EVOM Cam Guru's! Enter here
- TurboTrix HP61 picutres and time...
- Anyone have pics of an EVO starter?
- clutch clunk noise, HELP!
- For those of you that think you dont need a retune after a fp install!
- us 5 or 6 speed
- potential blown engine. seeking Evo Mechanic
- jdm ix gt turbo
- help please!
- Swapping injectors...Question
- Low rpm acceleration not smooth
- How do I make the Greddy EVO2 10136630 exhaust fit on my 2006 MR?
- Length of T Belt Tensioner
- Need help on wastegate
- fumoto oil drain valve trouble
- grind going into 2nd gear
- engine blew!
- 20G9 or Meth
- Horrible Valve-train noise!
- Ebay O2 turbo outlet
- is this a good order?
- Bypass Valve Touble.
- Another 2.3 stroker but by RRE!!!
- My Buschur 2.3l is alive!!!
- small radiator
- Are IX sparks plugs longer than VIII?
- civic radiators
- what cams are these
- Clutch install question.
- Tranny help
- Is this a good deal on exhaust?
- Need help with ignition/security!
- Question: Under WOT Engine pauses at 5.5k and Makes a thud noise
- Sun auto Hyperforce Ignition
- stock biss screw setting.....
- 50Trim vs Garret30
- aem wide band
- 2-STep
- Quick- PWR/Koyo Radiator with AMS 3076 kit?!
- Comp Cams warning
- Please help me out blowoff problem
- PEAKBOOST turbo kit users!!!!!
- whoops
- Pulled the tranny today
- CEL Codes P69 and P113
- Trying to decide which ebc
- BPR7ES plug condition
- Knock sensor hook up
- Double clutching and clutch spring
- Evo 8 to Evoi IX motor swap completed today at Pruven
- Magnus Special Race Intake Manifold???
- Need Help Flooded Engine!!! Engine seized??
- Anyone making pistons for the 94mm?
- exedy stage one
- New Clutch Time..??
- does this sound like a bad fuel pump
- gt3567??? please
- Used turbo concerns?
- ACT Clutch burnt smell at 1000miles?!?!
- Timing belt at 60k okay?
