PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 [215] 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Problem with my GFB
  2. How hot is our downpipe?
  3. RPS twin carbon clutch impressions...
  4. Boost @ 21psi... safe?
  5. Tuning Solution Question
  6. fuel pump and test pipe
  7. Best Boost Controller?
  8. Need some Turbo advice please..
  9. Better catalytic converters
  10. Which exhaust to choose from
  11. Anybody here spraying nitrous in their EVOs?
  12. New member question
  13. BOV Outlet Adapter for Greddy
  14. Shep Tranny
  15. Why?
  16. Oil Temp Sensor Problems (Defi BF)
  17. BR 20G Update Thread
  18. Questions just bought a 2003 Evo......
  19. My new turbo
  20. Tranny Fluid or Oil leaking on DP??
  21. O2 housing question
  22. stock exhuast cat replacement
  23. Cheap transfer case fix
  24. Whatever Happened to the Buschur "Stock-Looking" Turbo Upgrade?
  25. BR440 Dragstrip Results
  26. A little help here.
  27. Exhaust rattle?
  28. any suggestions?
  29. Titanium IC Piping Kit
  30. mod suggestions... please
  31. TeamRip.com TRE spec- Transmisison and TCASE ?
  32. Broken Rod?....helpppp what should I do?
  33. Downpipe + Testpipe
  34. New to forum, not evos...
  35. This goes against everything we know
  36. Will a downpipe for evo8 fit the evo mr?
  37. Help! o2 simulator install.
  38. anybody use a VES?
  39. How do I set "gain" on my Blitz ebc?
  40. Cracked Piston #2..WTH?
  41. New Forcefed.com turbo kit!!!
  42. Stock Fuel Pressure
  43. Idling with HKS 264/264 Cams
  44. HKS hipower catback
  45. Install help on Defi Water Temp sensor
  46. Does your car ever...?
  47. P300
  48. SES P420 Code with HF Cat
  49. NEED INPUT ON MY PROBLEM! Can you help!
  50. Can't get boost under 30psi after turbo kit..
  51. Where 2 buy 10.5 T housing
  52. new gasket for installation of exhaust
  53. New filter and boost problem
  54. quick questions about the Greddy oil block adapter.
  55. when I put the gear into 5th
  56. Heat Wrapping the DP?
  57. how to use cel fix bolt
  58. Can someone post a pic of the stock DP?
  59. Intake Man. & Throttlebody Help
  60. Just had a huge oh **** moment!
  61. Greddy Injector install problem!! Anyone else??
  62. Injen intake/uip vs. hks rs and br uip
  63. Help with boost reading w/ Blitz DTT DCII
  64. Just put my APS CAI on!
  65. Intake Question
  66. Afc killling gas milege and rpm off
  67. evo slips out of second gear
  68. ebay downpipe....
  69. Is my Turbo Stock Turbo???
  70. Atp And Ams
  71. Greddy Type RS bov pic installed
  72. Which to get
  73. Buschur Racing dyno thread.....new developments.
  74. ***Help Please!!!*** CEL, very bad gas mileage
  75. standalone ecu and afc?
  76. MR downpipes and BOV's.....
  77. Problem with ACT clutch/pressureplate!!No gear engaging!
  78. P0401 - Need Help - Dumb Question
  79. turning up the boost on stock Evo
  80. Is 2.5" exhaust too small for EVO?
  81. Joe P MBC - I have boost spike!
  82. Injen Intake and Upper intercooler pipe install
  83. Helix or any 02 exhaust housing?
  84. which TT is the best?
  85. Evo Exhaust
  86. Injen Exhaust ... review
  87. Weapon*R engine damper fix
  88. Greddy Front Mount
  89. help with tt
  90. Service Engine Soon Light
  91. Help with TT...
  92. Timing Belt Install Tool
  93. What is the higest HP and best 1/4 mile time on PUMP GAS??
  94. 400whp with stock turbo?
  95. Injector O ring question??
  96. Blitz power meter i-D, who has one?
  97. twinplate t.o.b. rattle
  98. RNR GT30 Kit
  99. best ebc on the market?
  100. Service engine light on Help!
  101. bad synchro if gears stuck
  102. HELP! MBC's ball and spring lost in engine bay!!!
  103. k and n filter replacement
  104. Weird Exhaust Questions
  105. Help with AEM intake
  106. Utec or SafcII? for 400-450
  107. just installed
  108. BOV Sound?
  109. All tunners on EVOM what our opinion on road tunning?
  110. 05 downpipe?
  111. Just Installed: TRE Tranny, TRE TC, Cusco Clutch
  112. Helix vs Vishnu exhuast
  113. Intake and Exhaust for EVO...
  114. Darkhorse/Garbaldi Imagineering
  115. What is the difference between the BOVs and which works best with the EVO
  116. for those who bought used HKS cams
  117. helix exhaust rattle?
  118. peaking at 21psi and leaking to 1.2bars (17psi)
  119. 9.3sec lancer
  120. Turbo Timer? Or not
  121. EVO vs CARRERA GT
  122. where can i find this for the evo???
  123. Surge and Hesitation + misfire code
  124. Got my new TRE tranny in the car and it's sweet!
  125. Tranny
  126. Driving with a slipping clutch??
  127. Remanufactured cranks
  128. o2 and A/f readings
  129. Evo for sale parts
  130. braided clutch line
  131. auto in apexi turbo timer?
  132. Magnaflow Titanium Exhaust
  133. Evo Oil Filter Question
  134. new mushroom filter
  135. Stock IC PIPE Blowing off? fix?
  136. Is this normal???
  137. ss manifold vs cast iron
  138. Look what I got for $190!
  139. Greddy Profec boost controller
  140. knock sensitivity
  141. Ralliart grounding kit for $10.00
  142. English instructions for HKS turbo timer type 1
  143. Oil Catch Can?
  144. 3" Exhausts W/Silencers?
  145. o2 Sensor Gone Bad...
  146. Will the evo 8 turbo work on a 90 eagle talon...
  147. best turbo for daily driving?
  148. what does A/R mean?
  149. Any Tuners out there with personal experience with ECU+ ?
  150. can't get rid of flutter in greddy type s
  151. If boost gauge...
  152. Down pipe for 2005 cars
  153. tubular manifold for stock turbo
  154. Looking for IC coupler
  155. HKS 272 CAMS (Buying used)
  156. zeitronix help
  157. ATP or AMS Turbo?
  158. Factory Gauge Pack question....
  159. Difference between GT3017R & GT3037S
  160. Quick parts updates....
  161. How to build for low end power?
  162. Gear Oil
  163. Power gains with cat delete pipe?
  164. manifold questions
  165. Which exhaust ?
  166. Review of Invidia Cat Back and Test Pipe...
  167. APS cold-air question
  168. turbo surge?
  169. BR440 Turbokit installed
  170. Hallman evo RX MBC install
  171. How to install EIDS type K
  172. '05 dual boost solenoids into '03s
  173. Is anyone using a colder coolant thermostat?
  174. another excedy clutch question
  175. Dyno Record
  176. Water spryer for oil cooler
  177. which specific rod bearings to buy.
  178. Problem/wierd
  179. Rps Drag Clutch
  180. need help please!!!!!
  181. flywheels
  182. stock bov/ injen intake
  183. RnR Turbo kit ..
  184. Stock engine pulley?
  185. Boost drop in 2nd, 3rd and 4th only WHY ?
  186. Installed BOV today, but is there something wrong?
  187. Dealer Replaced 3 synchros!
  188. does evo 7 and evo8 have the same block asembly.please
  189. anyone measured the size of the compressor wheel ???
  190. Exedy Hyper Single Starting to Slip
  191. anybody have AEM on EVO
  192. Acd Ecu
  193. Can a stock evo overboost, or hit fuel cut with restrictor removed?
  194. Boost Controller?+ MAX PSI
  195. 03 evo stock DP code
  196. Mitsu boost gauge vaccum reading at idle
  197. which intake do you think the best for stock evo8!?
  198. Oil filter too tight cause leaking??
  199. where i can buy EVO VIII Short Block Assembly
  200. I am Getting Apex'i INTAKE But...
  201. Big Horsepower Numbers
  202. The project started
  203. fidanza cam gears
  204. Question regarding break-in period..
  205. LS Downpipe
  206. Stoopid 18G / noob question
  207. quest for 10s
  208. Buschur Intercooler with Injen Upper Piping?
  209. How much oil will drain from filter??
  210. What is the FQ400 Garrett BB Turbo Part #?
  211. motor swaps
  212. Where to find O2 mounted wastegate or dump pipe
  213. you know anyone who is using the HKS F-Con V pro?
  214. OK, who can read this map???
  215. System too lean CEL with cams
  216. BOV question...plz help
  217. 255 part no. fitment
  218. Go Fast Bits
  219. Turbo Options
  220. Need help getting turbine housing off.
  221. Help - OEM oil filter leaking at seal??
  222. Stealth GT turbo
  223. Buschur 2.5" DP, any reviews?
  224. 3" or 2.5" DP with stock cat?
  225. K&N drop in filter suppose to be best filter under 400whp?
  226. Will i regret getting MBC?
  227. where can i buy the timing belt tensioner tool at??
  228. Whats the Best plugs
  229. Highest WHP/trap MPH for pump+stock cams
  230. MR 6spd "Feel" 600 miles later
  231. Cyber Evo
  232. who has the best tuner shop in the east coast
  233. question for buschur stage users???
  234. HKS ssq with EIDS?
  235. how much boost on ATP 3071r
  236. UR test pipe with AMS turbo back?
  237. Upper Piping Ic
  238. Back to Stock Intake
  239. 10.5 Turbo USDM only?
  240. ACD Question
  241. Walbro Fuel Pumps...
  242. Sound clips of Greddy Evo2?
  243. for those who ported the exhaust manifold/throttle body/02 housing
  244. diff MR and evo 6.5 turbo
  245. Bad Smell coming from Balancer Belt
  246. USDM, but then again...
  247. turbo compressor
  248. turbo compressor
  249. prob with install-avcr, fuel pump, hks intake
  250. Removing Transfer Case
