PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 [218] 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Cold bogging issue
  2. engine oil
  3. 05 MR' mustang dyno stock
  4. AVC-R controller problems
  5. Shifter Bushings. Where to buy
  6. Factory Torque Dampers: Did Mitsu do this on purpose?
  7. Test pipe vs. Hi-flow
  8. Upgraded turbo kit w/o EMS ????
  9. What causes bov flutter
  10. MBC poll and disc.
  11. Kaaz LSD
  12. Knock Sensor Voltages
  13. HKS Titanium exhaust I saw doesnt seem right
  14. did I just detonate?
  15. EBC and boost gauge: same vacuum line?
  16. Rps Clutch
  17. 2003 VS 2005 O2 housing - Vendors???
  18. my clutch is starting to die at 2k
  19. can you convert to external wastegate?
  20. Buy this mod
  21. safcII mounting question
  22. Clutch Break-in
  23. What Intake Is This??
  24. CEL with 272 cams at idle only???
  25. SOCAL evos interested in HKS BOV
  26. What axle back would you go for?
  27. Grounding System and Earthing System
  28. clamping load with stock clutch
  29. Zeitronix zt-2 anyone using?
  30. Cold weather???
  31. Blitz BOV conversion?
  32. Topspeed PRO-1 SS manifold install
  33. Defi EGT and VSD concept quick review
  34. finish the 3071R install
  35. MBC in different temperature?
  36. intercooler pipes (fluid dynamics) any engineers?
  37. 02 sensor adaptor
  38. selling my ecu with P2 flash!
  39. What Mods, Tuning? HELP :)
  40. AFC and 2005 evo
  41. Quiet Exhaust poll
  42. Seeking fuel setup suggestions
  43. 264 Hks install?
  44. Clutch Restrictor Removal
  45. Thermal Viscocity Breakdown (Dino oil) 700'
  46. Cam gears with HKS 264's???
  47. boost needle flux @ idle = normal?
  48. Is my TC or just drivetrain noise???
  49. Question about shifting at the track...
  50. What is the best Titanium Exhaust(catback)?
  51. Greddy Boost/EGT
  52. Just installed my Invidia exhaust...
  53. 4th Gear Grind
  54. boost controler
  55. bad day at dragstrip
  56. undiagnosable boost leak, help!
  57. Happy with your buschur turbo kit?
  58. question about fuel pump on Evo
  59. Exhaust vs Dynoflash
  60. aem intake question- important
  61. HKS BOV installed. Got almost killed
  62. RNR Please Read, questions on your Turbo Kit
  63. Any tuners in CT that can tune UTEC?
  64. Bigger Throttle-body makes HP?
  65. Engine Air Flow Dynamics
  66. Shifter retainer
  67. Does the hose going to the wastegate connect to the front or rear soledoid nipple?
  68. Has anybody used Skunk2 camgears?
  69. This is driving me nuts!! looking for help
  70. Has anyone seen a "How to" on the HKS RS intake
  71. RPM in neutral ???
  72. O2 Sensors?
  73. Griffin Intercooler
  74. Larger Oil Pan?
  75. Thermal R&D
  76. Words of Advice for EGT Install
  77. HKS EIDS settings?
  78. End the rattle!
  79. ATP turbo
  80. Favorite EMS
  81. Hot! Check 4 Vac Leaks, I found 3
  82. Dynoflash and larger injectors
  83. New idea for me Is this good or bad?
  84. Dynoflash vs. SAFCII
  85. Should I buy this Flywheel? Pic inside
  86. ARC Intake
  87. the most exhaust being resold
  88. Need Evo motor installer help Mechanic
  89. Oil filter housing plug
  90. best turbo kit
  91. Oil level indicator
  92. ATP 3037 turbo kit pic
  93. Gialla front W/ Buschur I/C
  94. Airtrek Turbo Mods?
  95. Best cam combo poll
  96. Best drop in filter poll
  97. Blitz induction cover
  98. Just Installed hks 272/272 cams, gears..my ..impresssion
  99. BUSCHUR, AMS very Important 2.4 block
  100. Weird Evo Problem
  101. SSAutoChrome Manifold and Performance Coatings Review
  102. Weird clutch squeek, help please....
  103. 05 front lsd into 03
  104. ATP 3037 turbo kit Dyno results
  105. 264's and emissions....
  106. HELP! Vendors! I need a replacement...
  107. boost leaking question..
  108. upper IC pipe advice
  109. Which cams?
  110. Wiseco pistons
  111. Greddy Profec B spec II probs...
  112. NEED HELP buschur DP question
  113. Intercooler coupling problems ????
  114. Installed the HKS BOV (question about re-cir.)
  115. Just installed ACT clutch. Now chatter and pedal vibration!
  116. Fujitsubo Rm01a or Works Stealthworks
  117. My Competed Exhaust (Helix - HKS)
  118. Part Number for K&N breather filter
  119. Ralliart ECU expert
  120. Trouble putting in reverse
  121. 4g63 talon vs evo help
  122. Atp Rs Bov
  123. Looking for EVO specific oil catch can pic
  124. NX Ntercooler
  125. Installed UR Test Pipe..No cutting wires for 02!!
  126. weird ass noise from tranny(not rattling)
  127. Groaning noises at 1st and 2nd gear (slow clutch release)??
  128. Tuning Poll
  129. High Flow Cat
  130. What are the symptoms of:
  131. The AMS exhaust, are these numbers possiable??
  132. 3" o2 housings?
  133. walboro fuel pump noise?
  134. Warning: Oil Pump Failure
  135. clutch slipping or ?
  136. Weird Fan Noise and Electrical Issue
  137. Turbo Timer, which one?
  138. selling Helix O2 and Megan Racing 3" Downpipe
  139. injector questions...will eclipse/talon injectors work in evos?
  140. TurboTrix tunes a 550 whp Weightless White in Tampa!!!
  141. Removing AC from my EVO
  142. Tale of 2 dyno's
  143. Weird Problem
  144. CEL when car is warmed and Hesitates
  145. engine poll
  146. need help on settings of hks evc.
  147. Heat Range 9. Good or bad?
  148. Thoughts on ATP VES?
  149. Rear O2 sensor failure
  150. Installed A Cat Delete now I got Funny Sound
  151. stock long block max hp
  152. ARC intake box?
  153. transfer case location
  154. Does anyone know how much a Shep Tranny build is for the Evo ???
  155. Does anyone have RC injectors with aftermarket or specifically VR fuel rail?
  156. Help with lower IC pipe install
  157. Quick I Need O2 Sensor Help
  158. JUST BOUGHT aatp 3071R TURBO KIT
  159. Need your advice on intakes
  160. Dynoflash and Boost Taper
  161. Any SARD dealers in the US?
  162. HELP! WTB CHEAP junk plastic BOV please!
  163. need 3" exhaust flanges
  164. Question about full exhaust....
  165. Ralliart ECU installed right now!
  166. Best price on AEM EMS?
  167. anyone tried in-cockpit hallman mbc?
  168. Leak Test...Highly Suggested...Look what I found
  169. Feedback on my BOV
  170. bov sound clips
  171. Vishnu Xede Vs. Works P2
  172. alternator fail safe on evo?
  173. how do u know if ur TC is going?
  174. I just put on a test pipe and...........DAMN!!!!!!
  175. Denso vs Walbro fuel pump
  176. stock fuel pressure?
  177. Is Toluene a better rout then Wanter Injection?
  178. BOV's and Problems
  179. Gearbox oil news
  180. Toasted Clutch or Engine Damage?
  181. Turbotrix flash results....
  182. intake poll
  183. Looking for suggestions on my A/F ratios
  184. Boost cuts...why?
  185. Those considering an HKS Carbon Ti....
  186. your thoughts on a hi flow cat
  187. Went from 300 miles per tank to 230!!!
  188. Headers or Catback
  189. 300whp
  190. HKS EVC Question
  191. WTB:Br440 kit.....
  192. Boost Problems
  193. What exhaust for my new MR
  194. Need some help! Want about 350hp to the wheels.
  195. 02 widw band question.
  196. Bar & Plate or Tube & Fin?
  197. turbo back exhaust system
  198. ALL of Injens EVO Parts Dynoed!
  199. Quieter cat back
  200. POLL: Does your DP rattle?
  201. not sure what happened, but i need help
  202. someone help!! bov problems!
  203. Has this ever happened to anyone?
  204. anyone with ssq pls help
  205. Which FMIC to test: Spearco or Greddy
  206. Help!! Timing Belt tensioner tool
  207. Boost Guage Sender Location
  208. SPEC Clutches???
  209. installing bov
  210. rps twin disk carbon carbon
  211. walboro fuel pump & perrin cel fix
  212. deep thought-----which turbo kit????
  213. do I need a new BOV?
  214. DSM Heads that fit EVO 8
  215. AMS Boost controller ?
  216. english instructions for hks type 0
  217. Anyone know this clutch???
  218. Clutch Adjustment
  219. Blitz BOV
  220. Arospeed Twin Turbo Filter
  221. wut parts do i need to hit an 11 low and still drive on the street with ease.
  222. HKS SSQV bov questions
  223. anyone know where i could find sound clips of exhausts/bovs?
  224. DTC P0122: Throttle Position Circuit Low Input
  225. boost gauge recommendation
  226. Intercooler dimensions?
  227. Evo clutch problems
  228. Buschur Alcohol/Water Injection Kit
  229. EGT Sensor Install question
  230. Denso IW22 or NGK BPR7EIX Iridium IX Spark Plugs?????
  231. supercharger, headers, exhasut installation help.
  232. Greddy R-SPL Intercooler
  233. Walboro Fuel Pump
  234. Timing off 1 tooth. How many degrees is that? I need to adjust. HELP!!
  235. defi egt install help!!
  236. Downpipes
  237. grinding 1st gear
  238. Anti-Lag
  239. anyone have a Turbochargers,com upgrade
  240. Knife's new prototype manifold..
  241. where to get a clutch put on in chicago area?
  242. turbo timer question
  243. HKS twinplate question
  244. What's the harm in taking off the line to the waste gate
  245. stock evo in need of mods
  246. Transmission and Transfer Case Fluid?
  247. Rebuild stock turbo.
  248. Problems after installing DC Sports downpipe
  249. exedy twin disk life...
  250. Twin Exedy Clutch...Not good on wear or for daily!
