PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 [224] 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. new gaskets
  2. apexi cone filter
  3. Torque spec. for the cams
  4. CEL with my setup QUESTION
  5. my car is running like crap!!!! (HELP)(HELP)(HELP)
  6. need help please.
  7. Fuel Pressure and FPR questions
  8. Comparing Bov need sound clips please
  9. 25-30hp shot of nos on evo?
  10. engine management
  11. Bushur Intercooler Problem with mounting it
  12. Finally got my Turboxs catless turboback put on.
  13. new obx evo intercooler good?
  14. Cleaning the HKS RS Filter...
  15. Installed everything in less than 3hrs
  16. How big is the stock intake manifold?
  17. Perrin Catback and delete pipe on stock downpipe
  18. Evo 4 rs rear diff
  19. HKS SSQV kit?
  20. K&N air filter sound
  21. What kind of #'z you think I will get???
  22. HKS catback question
  23. P304
  24. What EGTs do you see?
  25. running richer in higher gears... cause of load points?
  26. Borla Headers are POS's
  27. What boost to run?
  28. im tryin to get my sparkplugs out!!
  29. air fuel ratio question
  30. whining noise
  31. Stock Diverter Valve clamp problem
  32. Gauges
  33. Look what I bought.
  34. For those who have installed cams?
  35. stock boost limit
  36. How to dyno on a 2wd dyno?
  37. MOTEC MOTEC MOTEC anyone?????? READ!!!!!!!!
  38. Magnecor Spark Plug Wires
  39. Twin Exedy Break in Period???
  40. HKS EIDS install and help
  41. INJEN Pipe Kit With Pics
  42. Bigger Turbo
  43. WHat do you think I will put down?
  44. A pillar Carbon Fiber 3 gauge pod
  45. Anyone have a Guage-Tech Display for their EMS?
  46. HKS Carbon Ti
  47. Very hot and humid tomorrow. What to expect on dyno?
  48. Bad Sounds
  49. K&N drop-in filter -do I really need it?
  50. Help! SARD coolant expansion tank plumping
  51. Fuel Rail with AN fittings?
  52. MR blow off valve
  53. best SS clutch line?
  54. Make your shifting MUCH better!
  55. Bov Help???
  56. New perrin exhaust
  57. Bov Help??
  58. question on cam install
  59. Crunch in 2nd and 3rd gear
  60. Want to trade my Greddy type-s for MR bov
  61. my evo wont start....help!!!!!
  62. Anyone have pics/info on new DC Sports exhaust?
  63. what are "ECU" and "EMS" ??
  64. what do "down pipe" "up pipe" "header" do ???
  65. OIL and FILTER changes
  66. Electronic Boost Contoller
  67. Some clarification on the stock clutch please (specific failure)
  68. Questions about Buschur FMIC kit
  69. Castrol TWS 10W-60 at Super Autobacs
  70. Circular Grounding System
  71. What Intercooler Do You Prefer
  72. My clutch is gone after only 25K miles
  73. Help! Low oil psi light flickers at low idle
  74. Tranny
  75. What type of Manual Boost Controller?
  76. Vishnu X-flash review
  77. Which air intake should I get?
  78. could you guys do me a favor?? PLEASE!
  79. PARKING LIGHT problem (HELP)
  80. Oil system question
  81. Apexi Avc-r pop?
  82. First mods - What do you think?
  83. Clutch Install
  84. Spark Plug Question
  85. WOOHOO! Look what came in the mail
  86. 321 turbo back--any good?
  87. MY NEW MANIFOLD ceramic coated 2000 degree black Today, 08:14
  88. 0234
  89. clutch
  90. Are there any companies like Shep Racing that bulid up t-cases ???
  91. HKS RS Intake Users - Suction Kit, worth it?
  92. Looking for Cat shields for my test pipe
  93. Degreeing camshafts?
  94. help on clutch
  95. aftermarket clutch or tranny problem?
  96. Slightly OT ... but can I install an Evo 7/8 4g63 into a 2g DSM?
  97. SAfc fix k&n typhoon power loss?
  98. Problems after clutch install HELP!
  99. Turbo GLOWING like a night stick
  100. 3.5" Exhaust??
  101. 4th Gear 5k - 7k RPM Shifting Grind
  102. clutch
  103. Post clutch change decel noise louder
  104. Exedy Single plate clutch
  105. HP increase from these mods...
  106. excedy hyper single clutch
  107. BR 4 Stage No good times at all (HELP!)
  108. To cam or not to cam that is the question.
  109. I got smoother shifts - never touched tranny
  110. Turbo Timer
  111. REV Limit
  112. Anyone with an aftermarket FPR?
  113. Setting Boost?
  114. TROUBLE w/ Clutch ???
  115. Anyone getting a P0107 CEL Code?
  116. code P0420: Cat Efficiency
  117. hks cams
  118. installed JIC exhaust manifold & Helix o2 housing
  119. Help! Oil filter question...I serached!
  120. which clutch is the best bang for the buck??
  121. RNR Exhaust Gets good review.
  122. Br 500 ???
  123. the rubber thing on the intake pipe
  124. Clutch pedal/rod adjustment
  125. Greddy Profec B Spec II backlight color
  126. what you can do to a stock EVO with $1000(performance)
  127. how much psi does the stock evo has
  128. Lancer Evo Fuel Injectors Question
  129. Clutch is gone!!!
  130. EVO8 coolant recommendations?
  131. Evo 7 HOOD
  132. Peformance Question on a CEL. PLease advise.
  133. Differences between USDM Evo8 head and JDM Evo7 head
  134. Rod Bolts: Install Question
  135. Front LSD for US Evo 8
  136. 505 whp on pump gas
  137. Do any clutches come with warrenties...??
  138. Car trys to die...
  139. burp/hesitation/misfire?
  140. EVO clutch install
  141. Anyone try speed-source.net intake kit?
  142. Tuning for RoadRacing - This could save you thousands
  143. Tuning with Combustion Pressure
  144. Results from my ATP GT35R by TEAM D Motorsports (dyno graph incl)
  145. has anyone done a 2.3 stroker on their evo 8?
  146. Interesting...Evo engine finding
  147. Will the HKS Suction Intake work with UR Pipes?
  148. Does the Ralliart front LSD kit work in US?
  149. tranny problem??
  150. Two CEL's with HKS 264's
  151. how much is OEM clutch disk???
  152. ATP RS-bov
  153. AEM SRS vs K & N Typhoon
  154. Basic Question on Reflash and Piggyback ECU Tuning...
  155. A Question on Boost Controllers and Exhausts
  156. Sneek preview of Turbo Trix's NEW Drag Turbo
  157. QTP Downpipe...Any thoughts?!?
  158. HKS GT extension kit
  159. Read before installing AEM cam gears!
  160. Faint Drivetrain Surging??
  161. Perrin Downpipe Owners
  162. how do you install spark plugs?? (HELP)
  163. Crank Angle Sensor(Problems)
  164. Helix cat delete pipe install question...
  165. Locking out of 3rd after SS clutch line install??
  166. Mitsubishi MR diverter valve holding 28psi!!!
  167. 2.5" exhaust reducer removed
  168. What do you have/clutch
  169. Has anyone gone catless with stock downpipe?
  170. afc settings w/272 cams?
  171. Rod Bolt Install.
  172. another clutch question (already searched)
  173. RS*R GT-II a good choise?
  174. Invidia N1 or Apexi N1 cat back. Which one?
  175. What did I mess up now?
  176. Buscher IC piping
  177. Those running VTA BOV's
  178. Intake Questions!!!!!!!!!!!!!!!!!
  179. apexi gt spec exhaust
  180. buschur racing sheet metal intake manifold
  181. Normal A/f gauge readings.
  182. 02 sensor problem...help?
  183. EVOs with 300whp
  184. Downpipe Gaskets
  185. Blew My Engine Road Racing - Need a Rebuild ASAP
  186. Finally my base line dyno run and a surprise also
  187. NEED HELP with bypassing original boost valve/solenoid???
  188. just got dynoflashed
  189. Update on rear noise
  190. oil pressure sensor. Need help badly
  191. Wondering what I can run in my car.
  192. Question About Exhaust Systems
  193. New Clutch - Ungodly new whine
  194. problem with boost solenoid lines(diagram)
  195. Where is the oil pressure sender
  196. Need help fast!!!!!!!!!!!!
  197. unplugged harness behind radiator fan
  198. help me find the best IC please...
  199. Aftermarket clutch question
  200. Help Important
  201. EVO = Awesome but noisy
  202. Headgasket needed?
  203. EVO Clutch Alignment Tool TRICK
  204. MAS/MAF? Sensor question
  205. Some pics of my RnR 50 trim kit
  206. Ultimate Racing Turbo Kits
  207. Anyone using Mobile 1 75w-90 Gear Oil for Rear diff?
  208. which spark plugs??? HELP
  209. High octane gasoline
  210. Anyone know 'bout KFGroup turbo manifold
  211. Clutch is going....need a new one. Suggestions?
  212. Anyone know much about the ATP RS Valve?
  213. clunking noise when changing gear
  214. Invidia Dp Anyone??
  215. Ecu Software
  216. Hood For Evo 7
  217. Fuel pump
  218. Intercooler Upgrade Jerking at 5k at WOT
  219. Stock Clutch SUCKS
  220. 600+whp fuel system
  221. Did the SS clutch line, but all the hype??
  222. Anybody have a service diagram of the the tranny?
  223. UR cam gears
  224. Options to Cool 4G63T
  225. Car is not getting up to full boost!HELP
  226. My RNR catback with HKS carbon/ti muffler is awesome...
  227. wont go into gear in a dead stop??
  228. Slim Line Fans
  229. Humidity = Good not Bad
  230. Oil Temp ????
  231. How to do a proper compression test on Evo?
  232. TurboTrix Flash vs. Dynoflaah
  233. How do I get my Greddy BOV to "flutter" more
  234. Forced Performance Evo 8 turbo housing. 10.5cm2 worth it?
  235. Oil ???
  236. need help deciding upgrade path
  237. upto 400 HP on stock turbo???
  238. stock boost levels?
  239. Lookin for some input
  240. Exhaust Opinions
  241. Titanium DP
  242. Greddy Type S BOV installing..
  243. Evo 7
  244. GT35/40R .63 and Manifold
  245. WTB: Exedy Twin Disc.........
  246. Tunning Price/Cost/Time ????
  247. Questions about AEM EMS set-ups
  248. My impressions of the Hks EVC V
  249. Anyone using a k&n filer have their oil tested?
  250. Mitsubishi Earthing system instructions
