PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. stutter under WOT (with tune pics)
  2. turbo trade
  3. Help Identify this sound :( Passenger side timing area
  4. FP Green or FP Red?
  5. Engine run without water thermostat
  6. wtd axle and CV diagram
  7. Where to buy a replacement Evo 9 turbo?
  8. Trans fluid changing frequency. DD and/or tracked cars
  9. Exhaust Mani question.
  10. Not a swaybar rattle
  11. Output Shaft circlips
  12. Head welded from factory?
  13. Replacing timing belt auto tensioner with cam job
  14. P0011 (I searched)
  15. Evo 9 GSR & TTR Built 2.3L Oil Consumption
  16. 02 sensor wire extender?
  17. Ayc nightmare
  18. Is this normal? Sheptrans transmision question
  19. stock uicp install / pic request
  20. 500hp Evo 8
  21. 03 Evo 8 won't boost past 10psi, help!!
  22. 4G63 Dropped valve head repair
  23. Walbro 450 Problems with stock FPR
  24. Success with cams/springs/retainers with no head work?
  25. Evo 9 Wont Crank or Start -
  26. Anyone here dyno/track max out a 3076 non gtx?
  27. 2.0 vs 2.3 spool/powerband
  28. HKS Camshaft Identification
  29. Map Evo 9 high pressure actuator
  30. Valve spring Comparison #2- EVO VIII, Stock DSM, Manley, BC1100
  31. Valve spring comparison- BC1100, HKS, Stock 4g63
  32. Kelford Cams--Valve springs or Not
  33. Question: GSC S2s?
  34. Advise on how to start motor for the first time
  35. Evo without ACD
  36. Anyone help me with transmision oil? I have 2 quarts of redline 75 90 can i mix ????
  37. Evo wount go in gear
  38. turbo porting service ??
  39. Evo 8 worth upgrade to gsc s2
  40. map, buscher, ams
  41. Whining sound at only 3k rpm??
  42. Terrible engine rattle
  43. 4G63 Valve spring Info
  44. c.o.p cdi vs non cdi
  45. Oil port Mod for the 4G63
  46. Input shaft bearing or TOB
  47. V-Springs
  48. evo 8 camshaft ID question
  49. Block correction machining
  50. Did a Launch in my 4wd Evo 3, and then BOOM Instant Rear Wheel Drive
  51. Pulsation from rear end at speed, Evo IV
  52. Best price on Comp Stage 2
  53. Please Help! EVO 8 MR Making only 10psi boost
  54. High Output Alternator. Do you need it? Let's find out..
  55. How a 4G63 head is measured for thickness
  56. Bottommount VS Topmount
  57. gt30r or FP green, red, black
  58. Buzzing/vibration at 3k RPM at light throttle...
  59. What is the different of Higher Timing Lower Boost with Lower Timing High Boost?
  60. Injectors needed for E85.... Size matters
  61. found some cracks and windows in my tc, what to do? pics inside
  62. Boost loss after clutch install
  63. How to surface a cylinder head
  64. engine building
  65. Why NOT to have your cylinder head Belt Surfaced
  66. Looking to buy evo 9 stock turbo (good condition)
  67. Whirring noise from trans?
  68. timing belt skipped, valves kissed pistons, opinions?
  69. HELP!!! Bucking Part Throttle
  70. Weird "Standard" ACL RACE rod bearing sizes
  71. Shifter Lever pin cut in half?
  72. Evo VIII stock flywheel
  73. MAP oil feed line with fp turbo?
  74. Compressor Housing Porting ??????????????
  75. Do we need a retune after installing after market coils?
  76. ACD Transfer case
  77. Evo 8 to Evo 9 Mivec swap
  78. Help deciding on valve springs
  79. Evo 8 exhaust manifold compatibility
  80. evo 8 crank same as 7 bolt dsm?
  81. Flywheel for Comp Stage 3?
  82. Head gasket help
  83. 4G64 Build ?'s
  84. Problem with gas pedal.
  85. Wastegate Actuators: Any Real World Results?
  86. What oil do i need to fill the transfer case on my evo 9?
  87. GrimmSpeed's porting and ceramic coating service - anyone done it?
  88. Comp Turbo Evo Drop-In Turbos
  89. 1.34 bar tugging or slam feeling
  90. Clutch pedal dropped to the floor?
  91. Cams. Tomei vs Kelford
  92. Hard to get into gear when stationary
  93. headwork
  94. Rpm Rises to 2,200 rpm on idle and drops
  95. Why do I have so much clutch chatter?
  96. IX turbo question
  97. Boost dropping...Help..
  98. EVO VIII 2.3 HKS GTII acceleration
  99. test pipe dimensions
  100. Picking right size rods, pistons, bearings (help)
  101. Looking for an evo9 stock turbo
  102. Bearing Suggestion
  103. Short Shifter?
  104. Tilton Twin Disc Issue
  105. Flywheel questions...
  106. FWD Conversion?
  107. loude ticking noise
  108. Evo 9 stalls when making a turn on highway
  109. might be a dumb question
  110. New Tune need help ASAP Spark issue?
  111. Evo 6 : 5th gear and foot down
  112. Evo IX knock problem!!!
  113. Fuel pump fuse?
  114. Reverse slips on inline only...?
  115. 4g64 100mm crank fitment on 4g63?
  116. Help! CEL when turbo spools?
  117. After timing belt change loud over revving sound after 4k rpms
  118. Issue with ACD pump
  119. Competition Clutch 2 vs 3.5
  120. evo 9 turbo questions
  121. spec twin disc pressure plate torque specs?
  122. EBAY Radiator Review!
  123. How much boost can a stock bottom end hood?
  124. Looking for clutch suggestions for my Evo 9 MR! Need Help!
  125. Why stainless instead of carbon steel for manifolds?
  126. Weird Idle issues
  127. Map EF2 owners , need feedback
  128. Bad gas? Expert advice needed
  129. Removing transmission counterweight
  130. strange bov issue (speed density tuned)
  131. clutch problem??
  132. DW300 on stock wiring - Upgrade earth line only?
  133. CNC head porting
  134. The OFFICIAL Oil Filter Testing and Results Thread (4G63T/4B11T)
  135. Clutch suggestions
  136. Help! Power Steering Pump Issue...PS Pressure Sensor w. blue wire?
  137. Synapse valve flutter?
  138. ARP Rod Bolt Torque Specs?
  139. Restrictor pill
  140. Ets uicp
  141. pte 6262 or 6266 or 6466 ?
  142. need help pte6262 /6266 /6466
  143. evo 8 3rd and 4th on evo 9 trans. jdm 5th Q
  144. Competition Stg 2 Clutch Popping sound
  145. Eagle 100mm crank vs oem 100mm crank vs Manley
  146. Pls Help - AFR Deeps til 10 whenever immediate Full Throttle!
  147. Overboost question
  148. helppp plz Compression test result
  149. My coolant problem
  150. Evo idling problem
  151. Full Blown Dual Pump Hanger kit with DW300+?
  152. evo boost problems...
  153. Is my stock turbo dead? (Evo VIII)
  154. URGENT. I need the OEM part number for this (pic)
  155. HKS EVC-S instruction manual needed.. HELP!
  156. Serpentine Belt fell off??? No breaks no tears??
  157. More compressor surge after WOT?
  158. Want to "upgrade" from my 4088r?
  159. First Oil report (blackstone)
  160. Need your help ASAP
  161. Infamous low idle issue
  162. transmission swap problems
  163. did compression test...need opinions please
  164. 2.4 water pump spacer
  165. need good clutch
  166. Not sure what size flange this is...?
  167. High idle ONLY when IAC is plugged in??? SD car
  168. Who all does turbo upgrades?
  169. Evo Transmission Inquiry
  170. new build no start
  171. Anybody having trouble with their Odyssey pc680 battery?
  172. Evolution 7 Stock Intake Vs aftermarket intake
  173. Oil squirter block off kit?
  174. hole?
  175. cam angle sensor?
  176. Help with Extensive mod purchase
  177. Hks 272 vs kelford 272 for ix
  178. Does stock radiator fan fit aftermarket radiator????
  179. Exedy Twin HD Disengagement Problem
  180. Stock or aftermarket TOB?
  181. 2003 Evo 8 will not start after seat removal
  182. Evo ix advice
  183. OEM Main/Rod Bearings Size Chart
  184. Clutch chatter with ACT 6 puck unsprung clutch
  185. I think my engine just blew on the dyno. stock engine with HTA35r
  186. Need help with timing belt
  187. Help With Clutch
  188. Has anyone used one of the Kinugawa compressor housings?
  189. Honda radiator need help finding units
  190. VIDEO: AWD Motorsports Fastest Evos.. Compilation of the last 4 years!!!
  191. deleting fan module for radiator?
  192. Boost controller and cam questions
  193. Will this ETS pipe fit my JDM Evo 7?
  194. Black friday sales
  195. Is there a how to for this thing!?
  196. Cold start stall when clutch is disengaged
  197. Evo Valve Lash and Timing Marks
  198. Simple tool for waste gate actuator to flapper
  199. Question about 2.3l timing
  200. synapse bov flutter on accel.
  201. Manley Rods are contacting the sleeves 2.4LR build! Engine builders pls help!!
  202. Fork stop for?
  203. What actuator should i use
  204. Blew fuse on positive battery cable, now what?
  205. Engine Rebuilt - Oil Pressure Light HELP!
  206. Thinking of switching to a 3 port
  207. Qtp dp gasket ?
  208. HTA3582 on 2.0...Full boost at?
  209. freeze plug OEM or Rubber one?
  210. ring and pinion
  211. ATP Turbo kit!?!?!?!?!
  212. Evo 8 help with bigger injectors
  213. Torn between..engine rebuild kit or going to an even bigger turbo?? Need help!!
  214. ACT XTSS vs XTSD
  215. 2.0LR gt3582r build questions
  216. were can i get a backhousing for a gt35r that will bolt up to stock manifold
  217. squeal from serpentine belt area
  218. 2.4L swap
  219. cosworth fsl headgasket?
  220. Is This A Normal Vacuum Reading At Idle?
  221. No lift shift safe on motor?
  222. Mivec line fitting sizes?
  223. new high-Z injectors coming from FIC
  224. Engine bay firewall insulation question (removal)
  225. leak tested - blows from valve cover
  226. Main cross member removal HELP!
  227. 550+ Build Opinions, need help...
  228. Fb70mm and p0505 setting up base idle speed?
  229. AMS 3" downpipe on Evo IX
  230. Half shaft loose in diff
  231. Need help ASAP
  232. JUN BL Exhaust
  233. 4G64 Block Questions
  234. Prosport Boost Gauge Reads -2, Engine Off
  235. ACD/AYC pump nooooo!
  236. Spec Super Twin P-Trim 2012 made clutch kits
  237. Question about Transference Case - NO ACD?
  238. Hello - New to the EVO world - How much HP can I expect?
  239. best head gasket for 2.1 or 2.4
  240. Evo VII - Pulling Left
  241. Hotside pipe question
  242. Best cams for Evo 8?
  243. Quick question on main/rod bearing wear.
  244. Outer CV boot replacement how to?
  245. OBX intercooler
  246. Walbro 400 vs Walbro 416 testing
  247. QUESTION: Evo 8/9 AEM Ignition with TurboTrix coil pack
  248. Stupid question but lag in power??!!
  249. opinions on Kinugawa TD06SL2R 20G turbo
  250. evo 8 evo 9 turbo swap questions
