PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Wiseco piston install questions
  2. boost creep
  3. transfar case
  4. Twin Disk Clutch Life Vs. ???
  5. Head gasket to run
  6. 264hks and ported intake manifold or 9 turbo
  7. How do you communicate with a Motec m48? PICS UP
  8. Gsc s2 and S3 cam question...
  9. GSC S2's with BC valve spings ?
  10. EVO 8 TURBO LAGG? POSSIBLE bov
  11. No waveform on MIVEC CAS, throwing P0365
  12. 800HP Egnine with balance shafts, anyone?
  13. NO 3rd or 4th gear. car will roll when pushed while in gear!
  14. Loud Flutter Noise in 4th gear
  15. Weird fuel pump issue
  16. Trying to diagnose front end clunk
  17. Help tracking down cause of engine failure
  18. Magnaflow fit in test pipe location
  19. Central transfer numbers?
  20. Evo IX Turbo going on an VIII!
  21. Need a few questions answered.
  22. Is Regular 30~40 Knocks Count Destructive?
  23. Coolant overflow
  24. Evo 8 build
  25. Ikeya shifter?
  26. Oil Pressure Sensor
  27. cam choice
  28. Fic lower seals
  29. No power to fuel pump relay (B-128)
  30. Long rod 2.0 vs standard 2.0
  31. relay wiring help!
  32. Boost gauge reading -10 at idle
  33. What should i do next
  34. Boosting high in 6th gear
  35. K1 H Beam Conrods
  36. hardwired wallbro
  37. turbo diesel engine oil in our cars!!!??
  38. Anyone ever seen camshaft wear like this?
  39. Infamous P0011 SES Light
  40. where to buy 5spd trans parts?
  41. HELP - no power to fuel pump
  42. What should I safely rev my motor to? Built 2.0 Long Rod.
  43. Engine whine maybe transmission?
  44. ef3 or fb black???
  45. Evo 8 reluctor - PLEASE HELP!!
  46. Best clutch around $800
  47. Evo 8 acceleration lock, vibrates badly
  48. hks ignition amp+ 16v cbr battery
  49. 2.4l swap for wrecked evo.
  50. shell rotella t6 5w-40
  51. Evo 4 Ecu Flash???
  52. id 1000cc problems ?
  53. Talon Manifold on Evo 8?
  54. My baby is grining first gears after rebuild
  55. Insane Speed BILLET TRANSMISSION CASE PICS!
  56. just did ac delete - what size plugs to use for open holes in firewall?
  57. How much power can my fuelsetup handle?
  58. power steering rebuild?
  59. Would you use these cams?
  60. subbie rumble??
  61. Kill 2 birds with one stone
  62. Radiator hose clamps
  63. Car Runs Bad After Head Gasket Change
  64. Exhaust leak from the o2 dump
  65. Mivec line adapter
  66. Issue installing GSC S2 Cams.
  67. rpm at 70 mph
  68. TD05HR turbo shaft play.. rebuild or replace??
  69. Swapping Diverter Valves
  70. Lost oil pressure
  71. turbo choice for 2.3 stroker
  72. Acd relocation
  73. bad clutch or tranny :/
  74. AMS gt30 hta kit
  75. Electronic Oil Pressure Gauge Fitting won't fit?
  76. HELP! weird screaching noise after evo 9 turbo install
  77. knock or no knock..who knows
  78. Boost/Camshaft Problem
  79. Driver side (RHS) coil pack refuses to fire (Coil pack is not faulty!)
  80. Good trustworthy place to buy a 4g63 short block?
  81. Best turbo for my setup?
  82. WYSIWYG oil catch thinger
  83. Trade my 5 speed for a stock mr 6 speed?
  84. Radiator hoses
  85. Aftermarket ACD pump Cover?
  86. Help me identify this shortblock. Manley Pistons/Rods. Buschur?
  87. Very Unusual Noise at High Speed - Please Diagnose
  88. What boost could I run a new style FP Black at?
  89. Piston slap causing knock sensor to go off?
  90. Name this mod
  91. My Catch Can Setup
  92. AMS VSR intake removal pointers?
  93. BBK-Full DD best cam GSC s1,s2 ,Kelford??
  94. Evo 6.5 or 4-6 questions
  95. My car wont stay on at all. Bad idle problem i have.
  96. Question : driveshaft to Tcase rubber/oring
  97. Higher fuel pressure cons
  98. identifying stroker pistons
  99. O2 housing question
  100. Turbo police sound
  101. Who had there 6 spd rebuild by shep?
  102. Can anyone share a Tuning website?
  103. ACD light turned off / ABS light turned on
  104. grinding noise when selecting 1st gear
  105. twin disc clutches...
  106. We need a HTA3586 vs 6266 comparison!
  107. what head gasket for 4g64 in evo
  108. Clutch gone or do I just need to re-adjust the pedal?
  109. walbro 400lph no pressure
  110. Rear diff leaking?
  111. When does porting become "necessary"?
  112. Difference in o2 housing gaskets?
  113. Boost Cut? Spark Blowout? Fuel Cut? Bad Coils?
  114. knock and p0172 code Help
  115. Tial 50mm Wich spring??
  116. Sanity check..
  117. i finally blew up my motor
  118. 02 and downpipe sizes ?
  119. need help! p0300 code and rough idle
  120. Is buying used cams a good idea?
  121. Part Numbers for transfer case components ALOT of digging to find these.....
  122. EGT/ active sas
  123. ETS Turbo Kit Install ?
  124. WBO2 > LSU Sensors 4.2 vs. 4.9
  125. Turbo spool
  126. Manley Forged crank question
  127. BBK-B BB release date?
  128. HELP with HKS GTII 7460R SURGE Issues
  129. EVO 9 spark plugs 40 psi?
  130. fuel pump wire with high/low voltage circuit
  131. Can't get engine and tranny separated.
  132. Bbk turbo
  133. Wtf! About to part this piece out!
  134. Interesting Info from Brad Penn
  135. Shepard stage three transfer case
  136. Strange noise from passenger-side of engine bay
  137. For all you that praise Amsoil
  138. Evo ix afm pinout
  139. do you balance your cranks?
  140. Cam Set up
  141. Coolant smell
  142. FP Black Journal bearing Turbo whistle?
  143. 4G63 2.2L discuss
  144. Injen short ram intake questions
  145. Turbo discussion, does flow equal power?
  146. White smoke at wot and its causes?
  147. AFR Question
  148. Time for new spark setup?
  149. Tranny not aligning to engine
  150. Best power potential of Mag 71 turbo ?
  151. car wont start.
  152. best upgrade for GT3076.63 A/R
  153. Long Route UICP -vs- Short Route UICP??
  154. Something burned up... Advice?
  155. fp red evo 8-help please
  156. thud when I hit the gas after cruising or coasting
  157. What turbo should I get
  158. should i go with oversized valves?
  159. Boost Actuated Exhaust Cutout or O2 Dump
  160. how many have a 6spd with tranny rebuilds
  161. ETS Front Facing Turbo Kit
  162. BOOST Taper QUESTION.
  163. Dumb question- Head bolt socket size?
  164. Diagnose my engine noise
  165. Camshaft Suggestion for Evolution 7 ?
  166. lowest weight/MOI clutch?
  167. Evo engine builders
  168. Car won't start after cam install help!!!
  169. fp black or fp red
  170. If this happened to your motor would you...
  171. sparkplug recc for 450-480whp
  172. Flywheel Bolts for Twin-Plate Carbonetics Clutch...
  173. next mod advice
  174. Input shaft bearing???
  175. What do you suggest???
  176. Reuse Head Gasket?
  177. Turbo guru please help and ya'll with AMS turbo kit
  178. Clutch Question
  179. how big is the evo thermostat?
  180. Question about DBB FP-RED??
  181. 05 Evo 8 FP Red Turbo Question.
  182. CEL and no code
  183. Intake debate, gruppeM vs Arc suction box
  184. USDM EVO add AYC rear diff
  185. evo 9 turbo 0n evo 7
  186. Pic reqeust :full-race foward facing turbo manifold for evo 7-9
  187. Cool Vid. Clutch Exchange.
  188. 4g64 into Evo 8, parts?
  189. Thought this was interesting....Sharing
  190. Removing oil dipstick?
  191. Motor Mount Issue need help
  192. Service engine soon light blinking
  193. Sporadic High Idle – Possibly the TPS?
  194. Kinugawa 25g turbo thread
  195. tbelt tensioner
  196. HKS purging fast repeatedly at half boost?
  197. Civic Mishimoto or 53mm Civic Koyo Half Rad
  198. O Ring Cylinder Head
  199. Horsepower hungry
  200. Looking for a new clutch setup
  201. Steering Problem
  202. What exactly am I looking at here...?
  203. next upgrade suggestions?
  204. throttle body
  205. CBRD 2.3RB and LMP turbo kit-- inside-
  206. TOXIFAB O2 DUMP fitment?
  207. Take apart Manley rods
  208. Trans Bushing
  209. Transmission question
  210. Blowing multiple coil packs road racing...co-incidence or issues??
  211. handmade exhaust with Dynomax bullet?
  212. Oil Cooler Bracket Bolt Sizes?
  213. exedy vs tilton
  214. Evo sputtering, evoscan log attached
  215. 272/272 Camshafts
  216. is the injen kit any good?
  217. Stock or thicker headgasket? OEM
  218. Is it possible to pull the engine/tranny/transfer together?
  219. Innovative Tuned, BUFFALO NY
  220. Slim Fan ?
  221. HELP! my Evo consumes more oil then my RX-7!
  222. Oil in the Spark plug cover area
  223. Ams down pipe needed
  224. Speedomter/Odometer not working
  225. Exedy Twin Rebuild Worth it??
  226. 2.6l 4g64?
  227. Redline 10w30 oil review
  228. Am i overboosting?
  229. Rear axle stuck!!
  230. whats the torque spec for L19 headstuds?
  231. Why a turbo timer is NOT useless
  232. help puttin a hose back
  233. Buschur racing 02 housing cracked...
  234. 2,4 Long Rod!?
  235. power steering pump....RHD LHD compatible?
  236. axle backs
  237. BUTTER in my engine bay? ? ? please help
  238. Help me Identify these two pieces please?
  239. ams f1-i and solenoids?
  240. Going Back to Stock
  241. Stock Turbo Removing Exhaust Housing
  242. Buschur Front Cross Member
  243. need some advice, few issue after double pump install.
  244. Crazy AF ratio numbers.
  245. AWD Motorsports aluminum driveshaft reviews...?
  246. Apparently Bellhousing Bolts are Overrated
  247. breaking in new shortblock ** couple questions on rings seating**
  248. Dropped the T-case and found this, WoW
  249. ID2000's overkill?
  250. Air Filters: How to evaluate
