intercooler spray..
Old May 7, 2005 | 01:28 PM
JSYEVO's Avatar
intercooler spray..
what kind of fluid am i suppose to put into the intercooler spray reservoir?
Old May 7, 2005 | 01:39 PM
evoviiiny's Avatar
anti freez is recommended, but some people put in distilled water.
Old May 7, 2005 | 01:42 PM
03BREvo8's Avatar
i know of most people using just plain ol washer fluid... during the summer you could use some ice water.. ... Me i use methanol.. only because its not and i/c sprayer anymore... smc alc/H2o injection...
Old May 7, 2005 | 02:27 PM
TrinaBabe's Avatar
Read the manual It is washer fluid.
Old May 7, 2005 | 02:34 PM
rExTuHfEr's Avatar
i use 151 and sometimes armadale...
Old May 7, 2005 | 03:22 PM
JSYEVO's Avatar
crap, ive already put water. is just regular water ok?
Old May 7, 2005 | 03:23 PM
rExTuHfEr's Avatar
reg water is ok...i do it. sometimes mix with washer fluid and sometimes alcy.
Old May 7, 2005 | 03:24 PM
03BREvo8's Avatar
the alky on the i/c isnt going to do anything... just plain water is best...
Old May 7, 2005 | 03:25 PM
03BREvo8's Avatar
for 1 the lil tiny pump isnt ment to handle alky....
Old May 7, 2005 | 03:27 PM
rExTuHfEr's Avatar
sometimes i feed it protein shakes...
Old May 7, 2005 | 03:28 PM
03BREvo8's Avatar
haha... and everclear ?
Old May 7, 2005 | 04:30 PM
Ted B's Avatar
Antifreeze is the worst thing anyone could put in the IC sprayer.
The purpose of the IC spray fluid is to evaporate and remove heat upon evaporation. A mix of methanol and water is ideally suited for this purpose, and since the composition of washer fluid is exactly this, it is recommended as IC sprayer fluid.
Old May 7, 2005 | 06:53 PM
inline4g63's Avatar
regular water has minerals and ions that may clog up the pump. Stick to distilled water or washer fluid.
Old May 7, 2005 | 07:03 PM
Robert_K's Avatar
I use just water. Manual say washer fluid so it won't freeze during winter/lower temps.
Old May 7, 2005 | 07:16 PM
Evoryder's Avatar
distilled water/with methanol mixed ...not sure if there is a low level light for the reservoir ...if there is ..straight alchy will effect it ...a mix of distilled water/alchol will net u some ponies ...just with washer fluid alone evo's dyno'd with it on and off ...showed a 10hp increase ...with it spraying ...so imagine when u put that mix on it...cool taht charge even more ...every little helps ...lower intake temps are the goals...
