idle problems! *help! please!!!
Old May 8, 2005 | 08:55 PM
ultraflip's Avatar
o.k. everyone... i think things have quickly gone sour for me... just not sure...
cams have been installed on an evo (264/272 staggered set up)
now.. their are idle issues....
every now and then... idle dips down to 650 but then raises back up to 850 (normal...)
everything was checked, rechecked... and checked again as far as the installation was concern... rotated the crank 3x... TDC was verified as far as timing is concern...
the idle issue can be replicated by opening the hood and slamming it down to close it...
anyone know what the problem could be? please help! thanks!
-flilp
Old May 8, 2005 | 08:59 PM
03BREvo8's Avatar
will happen with 272 due to the overlap in the valves...
Old May 8, 2005 | 09:06 PM
ultraflip's Avatar
so even with a staggered set up... it'll do that?
Old May 8, 2005 | 09:36 PM
onpol's Avatar
You added cams thats all even the flavor you chose 264/272 have minor idle problems. For a like stock idle you should go 264 all the way.
Old May 8, 2005 | 09:37 PM
ultraflip's Avatar
so everything's fine...
i'm aware of a lumpy ilde... a consistent choppyness.... but the way it idles...
it runs fine for a bit... dips down... runs fine again... as if it will almost stall...
let me grab my laptop... i'll record it...
thanks for looking everyone
Old May 8, 2005 | 09:40 PM
mobounce's Avatar
add some fuel to idle...14's area...wideband it there. Its obviously running lean on idle. do you have a wideband gauge? if so, what does it read?
Old May 8, 2005 | 09:42 PM
Widebandphillip's Avatar
raise the idle to about 900-1000rpms
Old May 8, 2005 | 09:45 PM
mobounce's Avatar
after installing my intake, I had the nasty low idle problem, I adjusted the idle too 1000...and it worked for a few mins then the ecu learned it..hahah and went back down on its own...im gonna add some fuel to idle...im sure that will even it out...yay or nay? Sorry, don't mean to hijack the thread
onpol's Avatar
Mines is 272/264 and do the same thing.I have a helix intake and when the AC fan kicks it hicups a little. I read my AF ratios and found the cars is idling on the lean side thats why it is almost stalling sometimes.
Old May 8, 2005 | 10:01 PM
ultraflip's Avatar
no wideband as of yet...
fuel was added at time during tuning...
car did it earlier today...
tried to replicate it earlier... with a microphone and everything... of course... wouldn't do it again....
although... while sitting out their... i noticed a knocking noise coming from the valve cover... any ideas? thanks for all the help guys
Old May 8, 2005 | 10:03 PM
plokivos's Avatar
aftermarket cam gears with adjustment helps?
Old May 8, 2005 | 10:04 PM
onpol's Avatar
i added fuel with my afc but the ECU learns very fast
Old May 8, 2005 | 10:10 PM
ultraflip's Avatar
any more suggestions guys? heh... i dont want to have nightmares of my car blowing up
Old May 8, 2005 | 10:25 PM
timzcat's Avatar
What kind of mods do you have on it as far as intake? Slamming the hood is normally a bad MAF sensor.
Who did the cams? Were the lifters bled? Did a rocker fall off?
Old May 8, 2005 | 10:31 PM
ultraflip's Avatar
intake, TBE w/ test pipe, upper IC pipe, cams, injectors, fuel pump, safc
cams were installed @ a local shop...
lifters bled? not sure what's involved with that...
rocker falling off? not sure what that exactly means either...
everything was torqued back down to spec... i was watching the install the whole time
