hey guys i have a problem with injen
Old May 8, 2005 | 11:42 PM
Evolutionken's Avatar
hey guys i really need some help...i just installed my injen...but when i turn my car on the "service engine soon" light comes on...anybody know what's wrong with it? or something that can cause that light to go on while installing the upper intercooler pipe and the injen intake? any help would be great...the car runs fine...do i need to re program my computer?
Old May 8, 2005 | 11:44 PM
Cash Money's Avatar
disconnect the battery for 10 mins... negative side... see if it comes back on...
Old May 9, 2005 | 12:35 AM
GREDDY's Avatar
Hopefully you didn't damage the maf when taking it apart from the stock box. I know I almost did, it was that hard. Double check and ensure that the maf wiring harness snapps to the maf. If it's not in all the way then it will automatically throw the code. Once this is done, then disconnect the battery to clear the code as cash money suggested. If the code comes back it could be a leak somewhere. If no leak anywhere, take a closer look at your maf and check for damages.
Old May 9, 2005 | 04:03 AM
MalibuJack's Avatar
Well, reset the ECU, if the code comes back, get that CEL code pulled, should reveal alot more than just "My CEL keeps coming on"
But check the wiring harness to your MAF, and other connectors, make sure all the wiring and hoses that you disconnected have been reconnected. Its probably nothing major, the pipes are a little time consuming to do, but its unlikely you damaged anything unless you dropped your MAF on a hard surface.
Also do a quick check on the pipes, check for leaks, make sure your DV/BOV is on correctly, all the basic stuff.. I'm sure its nothing but a loose connection.
Old May 9, 2005 | 04:07 AM
Curt@MrLed's Avatar
Former Vendor
and unless you do some tuning, for that new pipe youre going to lose power.. the maf is reading to much air...
Old May 9, 2005 | 04:46 AM
hey guys thanks for the tips....so i need to disconnect my battery negative side for 10 mins and put it back on? this might take the "service engine soon" light off?
Old May 9, 2005 | 04:47 AM
so i disconnect negative side battery for 10 mins attach it back and start my car? sorry im a little new to this
Old May 9, 2005 | 06:57 AM
bluetouring350's Avatar
just disconnect the negative side then pump the brake pedal a few times. this drains the remaining power in the system much faster.
Old May 9, 2005 | 01:27 PM
i got it i got it..
Old May 9, 2005 | 01:38 PM
thanks everyone for the help....!!! really really appreciated it!!
Old May 9, 2005 | 07:58 PM
it worked! once again thanks for the help
Old May 9, 2005 | 09:11 PM
Cash Money's Avatar
that's what we're here for... hehe... you prolly just turned the car over without everything tightened up... or, left your car turned to on/acc to play the radio while doing this... hehe... i know lot's of ppl that do that... myself no excluded way back in the day
tcon89
Lancer Engine Tech
Jun 30, 2011 06:40 PM
hmsevo9mr
Mar 24, 2011 09:33 AM
nonschlont
Dec 2, 2009 03:54 PM
swandog
Jul 23, 2009 06:17 PM
Boostin4g63
17
Jul 22, 2007 07:01 PM
