boom/need Tbolts and a way to clear SES light
Old May 9, 2005 | 05:57 AM
ruzs's Avatar
Hey,
I was at about 7400 rpm in 3rd when all of a sudden BOOM, SES light and total limp mode. I was lucky enough to be 1/2 a mile away from home. Anyway, the lower IC pipe I installed poped off and I think I should replace the crappy band clamps with some T bolt units. Does anyone know of a good source for these or a place I could go and buy some. I am located in Houston.
I also would like to know if there is a way to turn the SES light off without an OBD2 tool. Can I remove the battery and press the brakes or will it disapear after a few times of driving without the condition? Thanks for the help.
All that giving a friend a test drive
Sigfrid
Old May 9, 2005 | 07:48 AM
SJ EVO 8's Avatar
If you have a napa store located by you i would check there.
Old May 9, 2005 | 07:58 AM
sgplancer's Avatar
Definately check NAPA out. I am located here in La Porte, just southeast of H-Town, and there is a local NAPA that i got all of my t-bolts from. As for the ses light, I would just disconnect the negative side on your battery for a minute or two, and the light will magically disappear.
Old May 9, 2005 | 08:05 AM
ruzs's Avatar
Boom
Thanks for the information. NAPA it is and I'll disconnect the battery in a while.
Sigfrid
Old May 9, 2005 | 10:19 AM
berkel's Avatar
Hi,
NAPA may have them. You can also get them from hose techniques online, but they're kind of spendy.
Regarding the SES light, you can often clear the light by pulling the two engine fuses in the fusebox under the hood (driver's side). Look at the legend, there's a 15 and a 20 IIRC, or perhaps it's 10 and 15, but look at the fusebox cover to make sure.
This way, you don't lose station presets and whatnot.
Take care,
FB
Old May 9, 2005 | 02:10 PM
matt55's Avatar
Sigfrid
Last time i checked NAPA didnt have the smallest ones we need , turbo pipe outlet into small lower IC pipe . But they should have the rest and at a good price .
Old May 9, 2005 | 05:12 PM
BaLListic_EVO's Avatar
i went to napa and they just looked @ me like i bumped my damn head...... Dunno my napa stores here suck. I tried carquest also... no luck... i got major boost leakage @ the moment soooooo....
Old May 9, 2005 | 05:16 PM
glgz's Avatar
Find a place that sells parts for Rigs (semis) They will have the size clamp you need. I did that when one of mine popped off. It has been fine ever since.
Old May 9, 2005 | 07:04 PM
matt55's Avatar
bling-bling BTW it is the wrong size , just showing that they have them....
http://www.napaonline.com/cgi-bin/nc...8&prmenbr=5806
Old May 9, 2005 | 07:12 PM
ex-honda's Avatar
What are the sizes for the t-bolt clamps on our Evos?
Old May 9, 2005 | 07:22 PM
TRDHarrier's Avatar
check logicperformance.com. Give chris a call. he hooked up me who lots of parts. When I installed my pipings, I totally forgot to tighten one bolt. BOOM, and I stalled out. Started tje car and limped home. Came back with a blackened bumper.
Old May 9, 2005 | 07:30 PM
matt55's Avatar
There are 3 diff sizes , 3'' for the T-body ,*i think* 2.5'' for the upper ic pipes and 1/2 of the lower ic pipes and the lower ic pipes to the turbo outlet is 2'' . My NAPA didnt carry the 2'' ones.
Old May 9, 2005 | 07:33 PM
ex-honda's Avatar
Thanks
GOKOU's Avatar
I believe the throttle body is 2.75". A 3" clamp would be too big. I'm going to head to Napa to see if they have the 2.75" one.
Old May 9, 2005 | 07:34 PM
plokivos's Avatar
pepboys. cheap and works.
