CEL after radiator install
Old May 9, 2005 | 06:58 AM
Tsurara's Avatar
Last week I installed a Koyo radiator. While I was flushing the radiator I got a CEL thrown. I installed the new Koyo, and the CEL light still remained on. Yesterday I reset my ECU by unplugging the battery for 10 minutes or so. When I turned the car on, the CEL dissapeared. I shut the car off and when I turned it back on about an hour later, the CEL reappeared.
Has anyone had this issue and know the fix for it? I know I should get the code pulled at AutoZone, but the only reason I am asking is because I work 8am-8pm Monday thru Friday and generally our AutoZones close at 8 or so. I will have to leave work early to get the code pulled, so I wanted to see if anyone had any ideas before I took an hour off of work.
Thanks!
Here is my mod list:
GReddy profec B spec II
Koyo Radiator
GReddy boost gauge
Apexi Power Intake
GReddy Type S BOV
Old May 9, 2005 | 07:14 AM
Ev0ikon's Avatar
what is the secret code?
Old May 9, 2005 | 07:18 AM
Tsurara's Avatar
I don't know, if you read my post I asked for ideas because it is very hard for me to get out to an AutoZone without skipping some work.
In any case, I just ran out and I think I solved the problem.
Old May 9, 2005 | 07:35 AM
Compjoc's Avatar
Hows the coolant temp while the motor is running?
Did you add any additives?
Make sure u have all electrical connections plugged in snug.
maybe u have a air pocket in the water jacket or something.
Ur best bet is to get the code read and go from there.
rjsdxm
Jan 27, 2015 07:57 PM
rjsdxm
Jan 3, 2013 11:58 AM
commandwolf
Lancer Tranny/Drivetrain Tech
18
Dec 2, 2009 03:38 PM
Knguyen228
14
Sep 29, 2008 03:41 PM
crypto
Jan 23, 2008 12:33 PM
