Downpipe Question
Downpipe Question
Okay.... I'm looking to get a down pipe that can fit the stock system without modiciation... Please note that I have heard that a lot of down pipes end up hitting or causing things to relocate. I want an easy simply install with a good performing down pipe...
ANYONE with suggestions?
If you're gonna keep the stock turbo and the stock cat, then a 2.5" (or thereabouts) DP seems to be the way to go. A 2.5" DP is what's fitted to the Buschur BR330 and BR350 special editions being sold through Medina Mitsubishi.
The HKS DP is also regarded as very high quality and bolts straight on (part # 3306-SM002, 65 mm = 2.56", $445 MSRP). I'm sure you can get it for less through one of the EvoM vendors.
https://www.evolutionm.net/forums/sh...light=downpipe
https://www.evolutionm.net/forums/sh...stock+cat+size
What other mods do you have? Sorry to get off topic a bit.
People make the dp out to be a huge performance enhancer, it's really not.
I strongly suggest a cat back before a dp. I am making an assumption based on the fact that you want it to bolt up to a stock system. I am sorry if im wrong.
David Buschur and others recommend enhancing your exhaust system from the tailpipe forward. A larger downpipe will only be choked by the restrictive system downstream. This will result in little or no gain.
nala
Feb 1, 2009 08:05 AM
