Whats the best high flow cat that wont set off o2 engine light?
Old May 9, 2005 | 01:59 PM
bmaga123's Avatar
Question Whats the best high flow cat that wont set off o2 engine light?
Does anyone no which high flow cat to get that wont trigger the engine light. I had a helix on my 04 evo and it triggered the light so I did the anti fouler trick and it worked but I dont want to have to do that again. Thanks
Old May 9, 2005 | 03:06 PM
bmaga123's Avatar
No responses yet, I cant beleive it.
Old May 9, 2005 | 03:08 PM
Thegame's Avatar
ultimate racing i think guarantees no cel. At least for the test pipe they do. Not positive on the cat. Anyone wouldn't happen to know why it doesn't cause a cel would they?
Old May 9, 2005 | 03:09 PM
c kim's Avatar
ya, try ultimate racing. Works, AMS make hfc's too.
Old May 9, 2005 | 03:12 PM
Compjoc's Avatar
I don't think any true high flow cat is CEL free. If you flow more than the stock cat, the o2 sensor will eventually freak out and throw a CEL .
Thegame's Avatar
Originally Posted by c kim
How about the Ultimate Racing hfc.
Did you miss my original post?
Old May 9, 2005 | 03:17 PM
djmikeymike's Avatar
i have the UR HFC and i have had 2 cels since i put it on
Old May 9, 2005 | 04:01 PM
bmaga123's Avatar
Doesnt the test pipe cause your car to fail emissions? Also it seems odd that a test pipe is guarenteed but a high flow is not.
Old May 9, 2005 | 04:05 PM
mooreboost's Avatar
Just get the highest possible flowing one, so you can say you have a cat, then run the mechanical o2 fix, to keep off any CELs.
Old May 9, 2005 | 04:06 PM
Thegame's Avatar
It definatley does. From what I've heard hi-flow cats also will fail. But it's only a once a year thing, so just bolt up your stock cat till you get inspected, then throw on your hi-flow or test pipe afterwards.
Old May 9, 2005 | 04:07 PM
JDM-Spec.com's Avatar
I got the O2 Simulator:
http://www.jdm-spec.com/tepievocelfi.html
Used one (not really):
http://www.jdm-spec.com/peteticelfix.html
eliminator 429
May 12, 2016 11:52 AM
donniewn
May 12, 2016 11:21 AM
LastX
Dec 27, 2015 05:41 PM
jk_addict
37
Feb 27, 2009 12:23 AM
twinturbozs
11
Mar 21, 2007 02:31 PM
