cel light came on
Old May 12, 2005 | 05:55 PM
sandm's Avatar
cel light came on
On my way to work this morning and my cel came on. stopped at the mitsu dealer to pick up an oil filter that I needed this weekend anyway. he read the codes and came up with a cat failure. he cleared the codes and off I went. I have a helix dp, helix high flow cat and rnr catback. I have had these installed for well over 1500 miles and the light just now went on. I just finished installing a mini battery and nwe i/c piping. I thought that the helix cat was not supposed to throw a cel or would something else have to do with it?
code was 0420-catalyst below efficiency
thoughts?
Old May 12, 2005 | 05:56 PM
plokivos's Avatar
your a/f ratio maybe the contributing fact.
that or sometime it craps out. that or your o2 sensor went bizark.
Old May 12, 2005 | 06:02 PM
bigcountry's Avatar
put 2 anti foul spark plug spacers on th 02 sensor itll go away
Old May 12, 2005 | 08:07 PM
madpacket's Avatar
My Helix HF cat w/ Xede & custom tune throws a CEL every other day....
Tried the spark plug anti-fouler, there was no way for two of em to fit like the how-to says. Tried with just one and it was hitting the underside of the car
Took it out and going to an o2 sim patched into my Xede.
Old May 12, 2005 | 08:15 PM
sandm's Avatar
how did you clear the code?
is there a way to do it without a code tool or the dealer?
Old May 12, 2005 | 09:01 PM
Jakeg97's Avatar
disconnect the battery
and then do this = https://www.evolutionm.net/forums/sh...d.php?t=114931
Old May 12, 2005 | 09:02 PM
mifesto's Avatar
is the code p0456?
