My car just "QUIT" so did the A/C
Old May 13, 2005 | 07:40 PM
smokedmustang's Avatar
Post My car just "QUIT" so did the A/C
was auto Xing and car came in and just "Quit" clutch to floor turned key- NOTHING lights on but nothing happening under the hood. would run fine with a push start.
here is what happened:
1. The launches at the start caused a wire to dislodge on the starter
2. The A/C connector came loose same way with harder than usual launches.
If this happens to you, dont panic, just look under the car for the wires that came loose re-connect them!!!!!
Old May 13, 2005 | 07:43 PM
03BREvo8's Avatar
hmm cant you reattatch the starter line and check all power leads..
Old May 13, 2005 | 07:47 PM
Curt@MrLed's Avatar
Former Vendor
first time i heard of this.. guess you were the unlucky one to have a factory screw up.. time to get a torque wrench, and see what else they left loose..
Old May 13, 2005 | 10:49 PM
plokivos's Avatar
your battery died? check your fueses?
check your belts?
fried the ignition coils?
Old May 13, 2005 | 10:56 PM
Compjoc's Avatar
damn, has this happened to u more than once?
Old May 13, 2005 | 10:57 PM
plokivos's Avatar
it could be your ecu fuse.
Old May 14, 2005 | 06:04 AM
No, once the connectors were reattached, problem gone!! they just came loose. Had Mitshu evo mechanic look at it, he was actually at the car show/autoX event, so he saw it when it happened.
Old May 14, 2005 | 07:36 AM
11secEVO7's Avatar
this happened to me while circuiting...
but eventually found out that my crank angle sensor was messed up
Old May 14, 2005 | 08:14 PM
Thanks,
will have them look at that also.
Old May 15, 2005 | 08:51 AM
platinumspecv's Avatar
Hehe that happend to me while installing my bushcur lower intercooler pipe. I was installing the turbo inlet pipe and the wire came loose off the starter. Took me 1 hour to figure out the problem. I checked every god damn fuse and wiring. I was having a panic attack. Lol then I saw it was the wire.
Old May 15, 2005 | 09:54 AM
Smile
I'm pretty sure its just the starter wire, it came loose again! It starts/runs fine with a push-start, so It has to be the starter wire, but then again thats what my mitshu mechanic said.
kd5byb
Lancer Troubleshooting
Sep 7, 2013 05:44 AM
StreetThisEvo
May 29, 2013 07:34 PM
Pastor DV
28
May 5, 2013 10:38 PM
slix_88
Jan 14, 2013 08:03 PM
WADADLIG_OZ
16
Jun 28, 2005 07:11 PM
