How much boost
Old May 15, 2005 | 01:59 PM
CeeNiK's Avatar
How much boost
I was wondering how much boost the stock turbo + fuel system can handle. Basically what i'm asking is once i get an ebc what do i set my boost at.
Old May 15, 2005 | 02:07 PM
03BREvo8's Avatar
20-21 should be ok if your not running a pump and injectors... it might taper .. depending on if you have a Safc or a flash...
Old May 15, 2005 | 02:08 PM
03BREvo8's Avatar
If you are using alky you can turn it upto 27-28... but you might want to get some new headstuds
Old May 15, 2005 | 02:12 PM
Evo11V's Avatar
Veteran: Army
On pump 93 I was running 22psi falling to 21 maybe 20.5 by redline. But yeah if you run alky you can get some serious numbers like 03brevo8 said.
Old May 15, 2005 | 03:19 PM
Jakeg97's Avatar
Originally Posted by 03BREvo8
20-21 should be ok ...
sounds good to me
Old May 15, 2005 | 04:06 PM
CeeNiK's Avatar
thanks a lot
Old May 15, 2005 | 04:53 PM
BOOSTEZ's Avatar
You can actually run around 24psi on pump. The car has more than enough fuel for the stock turbo.
-M
Old May 15, 2005 | 04:57 PM
SlowCar's Avatar
just wondering which ebc u will be getting?
Old May 15, 2005 | 04:58 PM
MRevo05's Avatar
I have a 05 MR and i have a injen intake, and HKS TI,HKS EVC... im running the boost controler at 21 than it drops to about 18-19 also im running it on 91 could the boost be set higher that 21 with out a reflash or a fuel pump?
Old May 15, 2005 | 05:26 PM
Evo11V's Avatar
Veteran: Army
From what i've heard being up at pruven for a few dynoday's with al and seeing a lot of cars on the dyno, usually 20.5psi is good with a flash you should be able to hold it to redline maybe tapering to 19-20ish. Best thing to get rid of boost fall off from my own expierences with my car is get some cams. once I got my 264/272 cams with my supporting mods I was able to run 22psi due to the reduction of backpressure.
I would definatly say not to go higher then 20 personally with the mods you have and especially with out a flash. Not worth another psi, what is it going to get you that much faster? Just not worth the chance leave it at 19 or 20 until you get it tuned.
Old May 15, 2005 | 07:55 PM
CeeNiK's Avatar
hey slowcar i'm still not 100% positive on which one..what would you recomend
Old May 15, 2005 | 08:03 PM
11secEvo05's Avatar
Yeah diff do 21-22 psi on 93 octane but i would make sure you get a fuel pump so there is enough fuel being pumped but if your on alky then you can go 25-27 psi but you do need headstuds that were mentioned above i would get a hallman manual boost controller best bang for the buck
Old May 15, 2005 | 10:32 PM
timzcat's Avatar
For EBC you want an HKS EVC V
By far the best boost controller on the market.
Old May 15, 2005 | 10:41 PM
plokivos's Avatar
Could someone run 22 psi for a bit to see if their fuel pump fails?
lol seriously, I need to find out. Just do it for like 2 months.
you'll need a fuel pump anyway, mine as well help me out before you replace it.
Old May 16, 2005 | 09:06 AM
CeeNiK's Avatar
after reading up a little i've realized that there isn't much of a difference between a MBC and an EBC besides price..so i've decided to go with the hallman mbc. I'm gonna set it up at 20 PSI. Oh, and one other thing i'll be getting a fuel pump too! Sounds good?
one more question.. how much boost can a stock car hold til redline?
