1000 RMS Sub Package!!
i got these off a trade but don't have the money to install these and get new headunits to match..so i'll selling these
up for offers!
Power Acoustik CK-12D Farenheit Subwoofer
12" Subwoofer 1000 Watts RMS SEALED ENCLOSURE
Kevlar Fiber, Ceramic Coated Cone
Oversize Butyl Rubber Surround
Dual Hybrid 4 Layer 4 Ohm Voice Coil
3 High Temperature A.S.V. Voice Coil
Die-Cast Basket
Ultra Stiff Flat Spider
Low Q Driver (.75~1 CUFT. Sealed Box)
Sealed, Ported, Free Air & Band Pass Configurations
Vented & Extended Pole Piece
Nickel Plated Bumped Back & Front Plate
Gold Plated Binding Posts
224 oz. Magnet Structure
Maximum Input 2000 Watts
R.M.S. Input 1000 Watts
Imp. 2 Ohm, 4 Ohm, 8 Ohm
Freq. Resp. 18Hz-1kHz
SPL 92 dB
LEGACY LA-1030 4 CHANNEL 1000 WATT BRIDGEABLE MOSFET AMPLIFIER
Four-Channel Bridgeable Amplifier
Tri-Way Mode Output
4 X 250 Watts Output
2 x 500 Watts Bridged Mono
MOSFET Pulse Width Modulated Power Supply
Fully Variable Hi/Lo Pass Crossover Network
Variable Bass/Treble Boost(0~12dB)
2 Ohm Stereo Stable
Gold Plated RCA Line Inputs/Outputs
Soft Turn On/Off Circuit
Heavy Duty Aluminum Heatsink
Discreet Wire Connections
Variable Gain Controls
Remote Turn On/Off
Speaker Terminal Barrier Strip
Power On/Protection/Clipping LED Indicator
Input Sensitivity:100Mv ~ lv Adjustable
Input Impedance:10 k Ohms
Signal to Noise Ratio:>95dB
THD:>0.04 @ RMS Power
Frequency Response:10Hz- 30kHz
Overload/Short Circuit Protection
Thermal Shutdown
Dimensions:10.5''W x 2.3''H x 17''L
up for offers!
Die-Cast Basket
SPL 92 dB
Tri-Way Mode Output
2 Ohm Stereo Stable
Remote Turn On/Off
Thermal Shutdown
