weight of stock tire/wheel combo ~45lbs! :(
I weighed my front wheel on a bathroom scale, but it is fairly accurate.
That seems pretty damned heavy for a supposedly light wheel.
I had TE37's (17*8.5 w/ 245/40/17's) and i think that combo was around 38-39lbs.
4-5 lbs per corner of unsprung weight is a fair amount.
Anyone else weigh theirs?
A few weeks back rollo weighed some stuff on his new evo:
https://www.evolutionm.net/forums/sh...ighlight=rollo
He got 45.5lbs for the wheels
Originally posted by DakarM
for light and relatiely cheap high performance street tires check out Toyo Proxes T1-S.
255/40/17 = 23.1lb
235/40/17=21.4lbs
255/40/17 = 23.1lb
235/40/17=21.4lbs
I know what I will be using for winter wheels next fall!
BTW the Toyo FZ4's have gotten mixed reviews but the T1S tires worked very well,were comparable to Michelin Pilot sports in wet and dry handling, but tread durability was much better.
255/40/17 = 23.1lb
235/40/17=21.4lbs
255/40/17 = 23.1lb
235/40/17=21.4lbs
Originally posted by limey
With a tread wear of 280 you can keep them.....the yokohama's have a tread wear of 160....need something closer to that....I think sumitomos have a low tread wear #
#1 the higher the nubmer the longer they will last
#2 you cannot compare tread wear #s from different manufacturers.
the tread wear number is only useful when comparing within the same manufacturer. comparing numbers from two different manufacturer is literally comparing apples to oranges.
