Evo classification news in FASTRACK
Old Feb 22, 2006 | 09:35 AM
jwtodd60's Avatar
Nothing major, but should help ease confusion regarding how the Evo is listed in the Solo 2 rulebook...
from http://www.scca.com/_FileLibrary/File/06-3-fastrack.pdf:
4) Stock, ST, SP, SM, Prep, Mod: All listings for the Mitsubishi Evo (8, VIII, etc.) should read "Evo ('03+)"
5) Street Touring: the following new listing, effective immediately upon publication, has been recommended by the STAC and approved by the
SEB:
Mitsubishi Evo ('03+) STU (also on STX exclusion list)
JW
Old Feb 22, 2006 | 09:56 AM
kekek's Avatar
read that last night
pretty happy, now we (8's) can run the BOV from the 9....
Old Feb 22, 2006 | 10:04 AM
bullfrg's Avatar
Exactly what I was thinking
Old Feb 22, 2006 | 10:07 AM
racerjon1's Avatar
Does anyeon know where the X-Prepared rules are? I have the PDF file and Haven't found them, but from what is described ot me the Evo should fit there where it is a cross between street mod and prepared..
Jon
Old Mar 3, 2006 | 11:29 AM
GVR-4's Avatar
The STS rules are in the rule book. The STX, STU rules are in the Fasttrack from Dec 05 or so, with some changes in Jan and Feb 06
Mark
Old Mar 5, 2006 | 08:10 AM
evoPirate's Avatar
does this also mean we 03/04 drivers can update to the 10.5 hotside??
Old Mar 5, 2006 | 07:36 PM
tweekscratch's Avatar
Talking
who cares about the hotside? I want to put a front LSD on my 03 w/o going to SM or BSP.
Old Mar 5, 2006 | 08:11 PM
bullfrg's Avatar
+1
Edit: I am in BSP so this would be awesome because of ud/bd.
Old Mar 6, 2006 | 04:26 AM
bmw88rider's Avatar
That still won't be allowed since ud/bd is only true for SP and above. For stu and stock, you can only do a model conversion based on what is available as an option or package of the same model year. IE, you can make your GSR into an RS but you can't add a 06 turbo onto a 03 without being into the SP or above classes.
Old Mar 6, 2006 | 10:08 AM
ratt_finkel's Avatar
Unfortunately, you can't mix and match parts like that. You would have swap over everything, the turbo engine, etc.
Update/Backdate does have it's limitations.
Old Sep 25, 2006 | 03:27 AM
prostcj's Avatar
Can I run the 1G BOV and stay in BSP? I want to upgrade my upper IC pipe because it keeps blowing off at autox events but don't want to move into SM. The BR kit comes with a 1G.
Old Oct 4, 2006 | 02:50 PM
EVOlutionary's Avatar
NO. The BOV must be from an EVO, '03 and up. Buschur can make the pipe to work with the EVO recirc. BOV.
Old Oct 5, 2006 | 11:20 AM
Warrtalon's Avatar
2 things:
1) You don't solve that problem by upgrading the UICP. You have to fix the actual thing that is causing it to pop off. Hard pipes are just as likely to blow off if you don't use the right couplers or don't tighten them properly.
2) You are not bound to the 1G when getting the BR UICP. You can use any BOV you want - just let them know which one you want to use (e.g. stock).
kyoo
Apr 22, 2013 10:06 AM
GoTopless
Oct 30, 2011 07:38 AM
johnr265
May 29, 2003 07:48 AM
SS RX7 r2
Mar 27, 2003 10:19 PM
jwtodd60
Jan 2, 2003 11:22 AM
