another question about camber
Old Mar 5, 2006 | 10:20 PM
nicka117's Avatar
Also, I'm going to bump the neg camber on my stock settings for the track. Can stock adjust enough or do I need to get some camber plates put on. I'm taking it up to Road Race Engineering in a week and I want to get as much stuff done there as possible.
Old Mar 13, 2006 | 07:12 PM
ReallySlow's Avatar
Bump^
Old Mar 14, 2006 | 09:53 AM
992gnt's Avatar
You should be able to get just under -2.0 using the stock camber bolts in the front. If that's not enough for your tires or your setup, you'll need camber plates. RRE can set you up once you tell them what you want.
