What is the recommended torque specs for wheel bolts on our evo's?
Old Apr 3, 2003 | 11:32 PM
gtr's Avatar
gtr
What is the official #'s for torquing down these wheels at? Anybody knows?
Old Apr 4, 2003 | 12:24 AM
theheff's Avatar
15
Old Apr 4, 2003 | 12:35 AM
N10S's Avatar
Originally posted by theheff
15
15....what units of measure? I know the torque spec for most of the cars I have had is typically around 80-90 ftlbs.One of my most recent cars, a 337 GTI, had BBS RC's which used a lug torque spec of 85 ftlbs.
Old Apr 4, 2003 | 01:03 AM
theheff's Avatar
Haha I was just kidding around... I don't really know the specs. You can use Kg*m if you like...
Old Apr 4, 2003 | 06:00 AM
twdorris's Avatar
Yeah, in the 85 ftlb range.
Thomas Dorris
Old Apr 4, 2003 | 07:12 AM
WestSideBilly's Avatar
El Jefe
75 to 80 lb-ft (go with 80).
Old Apr 4, 2003 | 09:27 PM
gtr's Avatar
gtr
So that's 73.75-81.12 ft-lb
Pretty low towque for bolts. I know studs usually in the 75ft-lb range.
Old Apr 8, 2003 | 01:12 AM
superz's Avatar
I actually read a TSB from MItsu stating that 74 ft-lbs is the correct torque spec. It has to do with prevention or rotor warpage.
Old May 13, 2003 | 02:16 PM
mayhem's Avatar
Is 74 ft-lbs the answer? That sounds typical as my last two cars had specs of 75 ft-lbs. Like superz said, gotta get it right to help prolong/prevent rotor warpage.
Old May 13, 2003 | 02:37 PM
iodine23's Avatar
It's in the owner's manual, near the back. The page before the table with all the engine specs on it. I think it is 74 if memory serves me correctly.
Old May 13, 2003 | 03:21 PM
SRD's Avatar
SRD
depends on the bolt...
12mm 65 to 70 ft-lbs
14mm 75 to 85 ft-lbs
beleive we have 14mm bolts so, 75-85...
unless the manual does say 74 specifically ??? someone check.
Old May 14, 2003 | 11:21 AM
wtz's Avatar
wtz
The studs are 12 x 1.5.
Cheers,
Old May 17, 2003 | 01:11 PM
SmokinJoe's Avatar
From the manual..
98 ± 10 N·m (73 ± 7 ft-lb)
R0ME0
Mar 19, 2009 03:21 PM
eVosmAs2006ix
Jun 28, 2007 09:38 AM
atilla
12
Jan 10, 2007 08:27 AM
bigfishs
21
Oct 23, 2005 10:09 PM
SNapz
Jul 28, 2004 04:31 PM
