5pt harness with stock seats
Old Apr 17, 2006 | 10:58 AM
wi_whoami's Avatar
Ok, this might sound like a dumb question, but is it possible to cut the lower seat cushion for a 5pt harness or is there bracing in the way to run the belt? I have a harness bar and 4 of the 5 points right now (just for autocross) and want to add the 5th point. I drive the car on the street daily and want to use the stock seat belts so a race seat doesn't really work well (since the stock belt won't work). Anybody do this yet?
Old Apr 17, 2006 | 12:06 PM
EVIL_EV0's Avatar
Construct a bar that goes between the front two floor seat bolts. Put a loop or a bracket of some kind in the center of the bar and bolt the submarine belt to the bar.
Old Apr 17, 2006 | 01:04 PM
wi_whoami's Avatar
But you want it to come up through the seat, not around the front. So did you just cut a slit in your seat?
Old Apr 17, 2006 | 01:17 PM
nubby's Avatar
Registered User
I run stock belts with a race shell, you just use the stock seat belt receiver that mounts to a tab on the seat base, here's a thread with some info:
https://www.evolutionm.net/forums/sh...d.php?t=179674
And you could attach both the 5-point lap belt and the stock receiver to the same tab, if you wanted to run both.
Old Apr 17, 2006 | 02:40 PM
EVIL_EV0's Avatar
I didn't cut my seat. That would be silly. I just ran it around the front of the seat. Its only there to hold the 4 point down.
Old Apr 17, 2006 | 03:22 PM
WarmPepsi's Avatar
ditto. you can see my stock belt clips.
Old Apr 17, 2006 | 03:47 PM
racerjon1's Avatar
Bad idea. It is there ot keep you from submarining. If you pull the 5/6th out, you give your body room to slide down, and get hurt.
Jon
Old Apr 17, 2006 | 04:26 PM
kekek's Avatar
so Warm Pepsi, what was your final seat/rail/harness/bar setup?
Old Apr 17, 2006 | 04:36 PM
WarmPepsi's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=174613
with simpson harnesses and an autopower roll bar.
Old Apr 17, 2006 | 08:11 PM
kekek's Avatar
Nice! I thought about those seats, but I really wanted to sit in something before I purchased. Loving my Pro2000.
Did you happen to weight the autopower rollbar? Did you mount the substrap with a welded backup plate in the floor?
Old Apr 17, 2006 | 08:14 PM
ddubb's Avatar
I was looking into harnesses with the same situation you have. I saw that Shroth makes a 6 point where the 2 sub belts bolt to the 2 stock front bolt on the seat mount/floor. all the other mount points are the same as other harnesses, stock side mounts and harness bar or C&D rear seat bolts.
Old Apr 17, 2006 | 08:29 PM
WarmPepsi's Avatar
weigh, no, i wanna say with all of it, it's 45-50 lbs.
I didn't weld in the substrap, but instead made a mounting setup (bolt through with solid steel plates/bushings)
ie: it's not going anywhere, i sandwiched the floor in multiple spots and used a grade 8 bolt as a stud for the strap.
RA11226
Evo X How Tos / Installations
120
Jun 24, 2022 03:19 AM
qbzescobar
Feb 22, 2012 02:10 PM
boomn29
Midwest Region
Mar 5, 2009 01:33 PM
fstclyz
Feb 25, 2009 07:45 AM
SpoolnEvo
Feb 6, 2009 09:04 PM
