MIVEC voltage?
MIVEC voltage?
This is kind of out there but I wonder if anyone knows or has taken the time to see what voltage range the MIVEC solenoid operates on. I would assume that 0* on the map is 0v, but what is full advance? 5v maybe?
Well for what I am thinking it doesnt matter what the voltage is for any voltage between 0* and 30*, I am just curious if its 5 or 12 when its at full (30*). I surmised it would be one or the other. Thanks for the help though. It seems I need to do some R&D.
Actually I am not after cam advance. There is a second load/rpm indexed map going to waste that can be used for an additional control. I am thinking that it can be used to run meth or nitrous. I am studying the pinout as we speak, but I was curious what the voltage is at full advance for running the triggers in other systems.
Originally Posted by jcsbanks
It is I believe a closed loop oil control system. So an operating condition of the solenoid valve (if that is what it is) will not tell you the state of cam advance.
absolutely right
solenoid have 2 pins out, one connect to 12V and another one connect to ECU
if you want to view cam angle, you need to compare phase between crank position sensor and intake cam position sensor.
by the way if solenoid duty = 0% cam timing will fully retard (0deg advance)
solenoid duty = 100% cam timing will fully advance xxdeg advance (except low RPM because oil pressure not enough to push cam pulley)
Originally Posted by High_PSI
12.41 @ 109.1 / 12.62 @ 111.8 / best 60' 1.707
englishracing.net
What are your mods with these runs?
englishracing.net
fireroasted
18
Nov 2, 2015 06:37 AM
jmoudry
20
Dec 31, 2006 08:01 AM
