a few updated EvoScan definitions
Old Sep 3, 2006 | 09:50 PM
mrfred's Avatar
I made an attempt to derive better correlations for the coolant temperature and MDP.
coolant temperature (deg F): -1.24x + 222
I got this correlation by measuring the EvoScan raw output in the morning after the engine had cooled down to ambient temperature overnight, and then assuming that the coolant temperature was around 185 F at normal operating temperature (as mentioned by a few people using pocket loggers).
MDP (bar): -0.00495x-1
Got this by measuring the raw value with the engine shut off and then with the engine idling. I correlated the values to the values on my MR boost gauge. When using this correlation, the value from EvoScan tracks my boost gauge up to 0.2 bar, and after that the boost gauge keeps going, but EvoScan stays a 0.22 bar (which is expected for the USDM ECU and pressure sensor).
Old Sep 4, 2006 | 07:57 AM
MalibuJack's Avatar
If you want, extract the DATA.XML file from my Log Analyzer for Evoscan, and update the XML, and upload it to this thread.. Or E-mail it to me.. I'll make sure both the zip and other locations are updated after you guys can verify its as close to correct as its gonna get..
Old Sep 4, 2006 | 07:59 AM
MalibuJack's Avatar
FWIW on the US car, MDP is going to be a max of 14.7psi absolute (1 bar) where an absolute vacuum would be 0psi, and sea level would be 14.7psi..
Hopefully you took that into account when you created your conversion.. The highest it should read is just over 1 bar.. since it does have some variance for slightly below sea level (and high pressure weather at the same time)
Old Sep 4, 2006 | 09:05 AM
mrfred's Avatar
Yep, my MDP correlation will read 0 bar when the engine is not running (ign ON). I'm at 300 ft above sea level.
I'm pretty sure that the MDP correlation is right on the money, but I'd like to better correlate the coolant temperature, maybe next weekend. If possible, I want to disconnect the sensor and correlate it using a pot of boiling water.
Everyone seems to be assuming that the correlations are linear functions. Is that a reasonable assumption?
Old Sep 4, 2006 | 09:46 AM
jcsbanks's Avatar
Pressure sensors on Japanese cars are usually linear.
Temperature sensors on Japanese cars are usually negative temperature coefficient thermistors (logarithmic).
Old Sep 4, 2006 | 12:31 PM
jcsbanks's Avatar
Code:
Engine coolant and intake air temperature
;*     Approximate sensor curves (temperature
;*     against ADC value, taken from MMCD). The
;*     control points in the service manual are
;*     quite close (0 to 2 degC off).
;*       ADC   ECT   IAT          ADC  ECT   IAT         ADC  ECT   IAT        ADC   ECT    IAT
;*               degC                    degC                    degC                   degC
;*       $00  158.0  184.0        $40  52.0  56.0        $80  21.0  23.0       $c0   -7.0   -7.0
;*       $01  154.4  178.1        $41  51.3  55.3        $81  20.6  22.5       $c1   -7.5   -7.6
;*       $02  150.9  172.5        $42  50.7  54.6        $82  20.2  22.1       $c2   -8.1   -8.2
;*       $03  147.5  167.2        $43  50.1  53.9        $83  19.8  21.7       $c3   -8.6   -8.8
;*       $04  144.2  162.0        $44  49.5  53.3        $84  19.4  21.2       $c4   -9.2   -9.4
;*       $05  140.9  157.1        $45  48.9  52.6        $85  19.0  20.8       $c5   -9.8  -10.1
;*       $06  137.7  152.4        $46  48.3  52.0        $86  18.7  20.4       $c6  -10.4  -10.7
;*       $07  134.6  148.0        $47  47.7  51.3        $87  18.3  19.9       $c7  -10.9  -11.3
;*       $08  131.6  143.7        $48  47.2  50.7        $88  17.9  19.5       $c8  -11.5  -12.0
;*       $09  128.6  139.6        $49  46.6  50.1        $89  17.6  19.0       $c9  -12.1  -12.6
;*       $0a  125.7  135.7        $4a  46.1  49.4        $8a  17.2  18.6       $ca  -12.7  -13.2
;*       $0b  122.9  132.0        $4b  45.6  48.8        $8b  16.9  18.2       $cb  -13.2  -13.9
;*       $0c  120.2  128.5        $4c  45.0  48.2        $8c  16.5  17.7       $cc  -13.8  -14.5
;*       $0d  117.5  125.1        $4d  44.5  47.7        $8d  16.1  17.3       $cd  -14.3  -15.1
;*       $0e  114.9  121.9        $4e  44.0  47.1        $8e  15.7  16.8       $ce  -14.9  -15.7
;*       $0f  112.4  118.8        $4f  43.5  46.5        $8f  15.3  16.4       $cf  -15.4  -16.3
;*       $10  110.0  116.0        $50  43.0  46.0        $90  15.0  16.0       $d0  -16.0  -17.0
;*       $11  107.6  113.2        $51  42.4  45.4        $91  14.5  15.5       $d1  -16.5  -17.6
;*       $12  105.3  110.6        $52  41.9  44.9        $92  14.1  15.1       $d2  -17.0  -18.2
;*       $13  103.0  108.1        $53  41.4  44.3        $93  13.7  14.6       $d3  -17.5  -18.8
;*       $14  100.8  105.8        $54  40.9  43.8        $94  13.3  14.2       $d4  -18.0  -19.4
;*       $15   98.7  103.5        $55  40.4  43.3        $95  12.9  13.7       $d5  -18.6  -20.1
;*       $16   96.7  101.4        $56  39.9  42.8        $96  12.4  13.3       $d6  -19.2  -20.8
;*       $17   94.7   99.4        $57  39.3  42.3        $97  12.0  12.8       $d7  -19.8  -21.5
;*       $18   92.8   97.5        $58  38.8  41.8        $98  11.5  12.4       $d8  -20.5  -22.3
;*       $19   91.0   95.7        $59  38.3  41.4        $99  11.1  12.0       $d9  -21.3  -23.1
;*       $1a   89.2   93.9        $5a  37.8  40.9        $9a  10.6  11.5       $da  -22.1  -24.0
;*       $1b   87.5   92.3        $5b  37.3  40.4        $9b  10.2  11.1       $db  -23.0  -24.9
;*       $1c   85.9   90.7        $5c  36.9  39.9        $9c   9.7  10.7       $dc  -24.0  -26.0
;*       $1d   84.3   89.2        $5d  36.4  39.4        $9d   9.3  10.2       $dd  -25.0  -27.1
;*       $1e   82.8   87.7        $5e  35.9  38.9        $9e   8.8   9.8       $de  -26.2  -28.3
;*       $1f   81.3   86.3        $5f  35.4  38.4        $9f   8.4   9.4       $df  -27.5  -29.6
;*       $20   80.0   85.0        $60  35.0  38.0        $a0   8.0   9.0       $e0  -29.0  -31.0
;*       $21   78.6   83.6        $61  34.5  37.5        $a1   7.5   8.5       $e1  -30.5  -32.5
;*       $22   77.4   82.4        $62  34.0  37.0        $a2   7.1   8.1       $e2  -32.2  -34.1
;*       $23   76.2   81.1        $63  33.6  36.4        $a3   6.6   7.7       $e3  -33.9  -35.7
;*       $24   75.0   79.9        $64  33.1  35.9        $a4   6.2   7.3       $e4  -35.8  -37.5
;*       $25   73.9   78.8        $65  32.7  35.4        $a5   5.8   6.9       $e5  -37.7  -39.3
;*       $26   72.9   77.7        $66  32.3  34.9        $a6   5.3   6.4       $e6  -39.7  -41.2
;*       $27   71.9   76.6        $67  31.8  34.4        $a7   4.9   6.0       $e7  -41.7  -43.0
;*       $28   70.9   75.5        $68  31.4  33.9        $a8   4.5   5.6       $e8  -43.7  -44.9
;*       $29   69.9   74.5        $69  31.0  33.4        $a9   4.0   5.2       $e9  -45.8  -46.8
;*       $2a   69.0   73.5        $6a  30.5  32.9        $aa   3.6   4.7       $ea  -47.8  -48.7
;*       $2b   68.1   72.5        $6b  30.1  32.4        $ab   3.2   4.3       $eb  -49.8  -50.6
;*       $2c   67.3   71.5        $6c  29.7  31.9        $ac   2.7   3.8       $ec  -51.8  -52.4
;*       $2d   66.4   70.6        $6d  29.3  31.4        $ad   2.3   3.4       $ed  -53.7  -54.1
;*       $2e   65.6   69.7        $6e  28.8  30.9        $ae   1.8   2.9       $ee  -55.5  -55.8
;*       $2f   64.8   68.8        $6f  28.4  30.4        $af   1.4   2.4       $ef  -57.3  -57.4
;*       $30   64.0   68.0        $70  28.0  30.0        $b0   1.0   2.0       $f0  -59.0  -59.0
;*       $31   63.1   67.1        $71  27.5  29.5        $b1   0.5   1.5       $f1  -59.0  -59.0
;*       $32   62.3   66.3        $72  27.1  29.0        $b2   0.0   0.9       $f2  -59.0  -59.0
;*       $33   61.5   65.5        $73  26.6  28.6        $b3  -0.3   0.4       $f3  -59.0  -59.0
;*       $34   60.7   64.7        $74  26.2  28.1        $b4  -0.8  -0.0       $f4  -59.0  -59.0
;*       $35   59.9   63.9        $75  25.7  27.7        $b5  -1.3  -0.5       $f5  -59.0  -59.0
;*       $36   59.2   63.1        $76  25.3  27.2        $b6  -1.8  -1.1       $f6  -59.0  -59.0
;*       $37   58.4   62.3        $77  24.8  26.8        $b7  -2.3  -1.6       $f7  -59.0  -59.0
;*       $38   57.6   61.6        $78  24.4  26.4        $b8  -2.8  -2.2       $f8  -59.0  -59.0
;*       $39   56.9   60.9        $79  23.9  25.9        $b9  -3.3  -2.8       $f9  -59.0  -59.0
;*       $3a   56.1   60.1        $7a  23.5  25.5        $ba  -3.8  -3.3       $fa  -59.0  -59.0
;*       $3b   55.4   59.4        $7b  23.0  25.1        $bb  -4.3  -3.9       $fb  -59.0  -59.0
;*       $3c   54.7   58.7        $7c  22.6  24.7        $bc  -4.8  -4.5       $fc  -59.0  -59.0
;*       $3d   54.0   58.0        $7d  22.2  24.2        $bd  -5.3  -5.1       $fd  -59.0  -59.0
;*       $3e   53.3   57.3        $7e  21.8  23.8        $be  -5.9  -5.7       $fe  -59.0  -59.0
;*       $3f   52.6   56.6        $7f  21.4  23.4        $bf  -6.4  -6.3       $ff  -59.0  -59.0
Above is from a DSM 1g commented disassembly from DSM-ECU Yahoo group.
Old Sep 4, 2006 | 01:06 PM
dan l's Avatar
Is it possible the coolant temp could be:
-1.45x + 308
Old Sep 4, 2006 | 02:05 PM
jcsbanks's Avatar
Unlikely since that is a linear equation.
Old Sep 4, 2006 | 03:38 PM
jcsbanks's Avatar
Can't seem to upload the zip of the xls or even an image file I made from the above data.
Looks like NTC.
Old Sep 4, 2006 | 04:07 PM
spm1024's Avatar
you need a cubic regression equation for those ADC>ECT values or the ADC>IAT values in that chart?? I am pretty dumb, but i might be able to come up with something.
Old Sep 4, 2006 | 05:58 PM
mrfred's Avatar
Nice. My few data points match up well with with the corresponding data points in the 1G DSM data. I fooled with a bunch of curve fits, including some customized equations. The best fit for the fewest number of fitting parameters turned out to be regular old polynomial fits.
I fit the 1G DSM coolant temperature data between 100F and 316F to keep the polynomial down to third order. It tracks the 1G DSM data nicely between 100F and 316F:
-0.0003893xxx+0.08056xx-6.5226x+315.73
The result is in Farenheit. I deal with Centigrade all day, but still have a better feel for Farenheit. Note the syntax of the equation. This is the only way I could get EvoScan to understand it. It didn't like sci notation, it didn't like "^", and it didn't like n*x*x (x*x*x*x works though).
I fit the intake air temperature from 50F to 363F. I had to use a fifth order polynomial to get a good fit. The equation is:
-0.00000003166xxxxx+0.00001425xxxx-0.002490xxx+0.2143xx-10.279x+361.01
I did some logging in EvoScan with these long equations, and the logging rate was not adversely affected. Coolant temperature settled in a 182F which is right in line with what everyone is saying. Intake air temperature was hovering around 100F when cruising along in traffic.
Old Sep 5, 2006 | 01:45 AM
jcsbanks's Avatar
Nice that you could get that equation into Evoscan, surprising!
Old Sep 5, 2006 | 08:52 AM
hondafan's Avatar
i wish i understood what's going on! how does an average joe and a bag of doughnuts like me add new definitions to evoscan?
Old Sep 5, 2006 | 10:38 AM
EvoBroMA's Avatar
the definition file is in xml, joe schmoe can edit it with notepad if he really wanted.
Old Sep 5, 2006 | 06:56 PM
dan l's Avatar
The 1g DSM uses:
-1.45x + 308
for coolant temp in MMCd which I've found to be extremly accurate:
http://mmcdlogger.sourceforge.net/#Protocol
Your multiple order equations may be more accurate (I trust your math) however. In the real world that above equation has served me well for years.
